Arlo proj-Q
Like I mentioned, in my other thread, I am considering an Arlo for an off the shelf robot project. First question, can a functioning Arlo robot be had for less than $500?
I will be using my Create for experimentation purposes, like can you get an RPi to fit into an autonomous robot configuration, and the use of other devise and sensors.
I was looking for some data as to what the clearance between the battery base plate and the ground is. In the one picture that I saw, it was not possible to determine the dimension, but I am guessing a 1/2"?
As to the new Arlo power board, will there be a way of getting power from the individual batteries, just in case you want one battery source for the drive system, and the other for the electronics?
It is stated that the wheels have a 20lb capacity rating, any ideas as to what will be left, as it pertains capacity, if you are using a two battery system, maybe the batteries being rated at 6 Ah each.
And, is there any data available for some realistic run time values for battery capacities, how long will the robot run before it needs to head for the re-charge station?
Ray
Ray
If your up to cutting a few traces, then yes.
Ray
(1) #28960 Arlo Base Kit = $39.00
(1) #28963 MMWK2-MP (drive system) = $199.00
(2) #28961 Caster Wheel Kit = $98.00
(1) #32910 Propeller Activity Board = $50.00
(2) #29144 HB-25 motor controllers = $98.00
Total about = $484.00.
To this you'll add your own power source and charger (batteries) 12v 8.5 SLA's are the standard that we recommend - but you can use any thing you prefer. If you want to get really fancy, you can add our new Power Distribution board (which is available real soon now), or you can simply wire everything together yourself.
The @20lb rating is what the fully outfitted platform can carry...Basically, put the whole thing together (as noted above), add two 12 volt SLA batteries to the battery tray (which has a 1" clearance to the ground), and then to that fully assembled system you can add another 20lbs of "extra stuff".
During our rigorous testing phase, loaded 20 lbs of aluminum plate and drove it all over the parking lot and streets - that's how we determined it's capacity; If you need to carry more "stuff" upgrade to the aluminum Motor Mount and Wheel Kit :-)
-MattG
You can do anything you want with the way in which you connect the battery cables to your robot. You can monitor them with whatever techniques you wish. In the standard configuration it really won't make much difference because both 12 batteries are connected in parallel anyway - It's like having two car batteries in parallel - you just get more amps for the entire system (although you can run the system on only one battery and that'll last quite a long time as well).
Arlo is really an "open development" robotics research platform. Do what you want with it. Have a divided two battery system, each with it's own monitoring system...As an example, have one battery run the motors and the other battery run the electronics, and create your own charge level sensing system, and then make your add-on available to other Arlo developers?!
-MattG
Ray
http://www.radioshack.com/product/index.jsp?productId=11225092
$30 each.
Maybe Rev C, (I think they already did a Rev
Yep, I understand what you're looking for.
The "Arlo" is a base platform for robotics developers. What we wanted to produce was a cost-effective, rock-solid mechanical machine that could serve as the basis for developers (such as yourself) to start with.
Does the Arlo platform have collision avoidance capability? No,.
Can it navigate via GPS? No...
Can it go on patrol to make sure the parking garage is secure? No...
Are there Arlo platforms out there right now doing any of those tasks? Yes! ...How? Because they were enhanced by independent developers.
Arlo is not an "out of the box, fully capable, robotics solution. Arlo is designed to enable developers to get a rock-solid, high capacity mobile platform to take it in the direction that you want it to go with the capabilities you want it (him!) to have. :thumb:
-MattG
Ray
The ancestor of Arlo was "Eddie". Eddie had this for his "power distribution system".:blank:
Technology marches on :thumb:..
-MattG
Which items specifically? Maybe I can "scare" some up...
I'm currently working on the documentation for the Power Board, and some of the components aren't yet in stock for that product - should be real soon now though
-MattG
Ray
The Power Distribution Kit is getting closer...I'm in the middle of the documentation as we speak. I'll update this thread when it's available. It'll be part #28996.
-MattG
Ray
The short answer is 16 gauge, and that's what will be in the wiring kit that we're going to be including in the upcoming "Full Arlo Robot Kit"
-MattG
Didn't see this till just now, I already have 18 gauge on the way.
-JohnT
-MattG
That is why they call him "belt and suspenders" Gilliland!
