USB to UART breadboard adapter $5 — Parallax Forums
tonyp12tonyp12 Posts: 1,951
edited 2014-05-28 14:25 in Propeller 1
For $5 this could be a good Prop-pdip breadboard usb programmer.
Though ebay have ftdi breakout boards I guess for ~$5 too?
The CP2104 built-in LDO does handle more power at 80-100mA, so it could power a Prop1 if you don't have many extra items also hooked up to Vdd 3.4v
RTS can be selected as open drain, so it may be connected directly to Prop reset pin, though I don't know if signal state need to be inverted first.
Warning: changing pin configuration is one-time-only thing.
http://www.mouser.com/ProductDetail/Silicon-Laboratories/CP2104-MINIEK/?qs=%2fha2pyFadujfejD%252bRRA%2f%2f0OEeKldwfXd0PIs9QzYquYOtYjKhI%2fFGQ%3d%3d
http://www.silabs.com/products/mcu/Pages/USBtoUARTBridgeVCPDrivers.aspx
  • jmgjmg Posts: 15,200
    tonyp12 wrote: »
    That's cute, and I see it includes a cable too !
    The evaluation kit includes:
    CP2104 mini evaluation board
    Mini USB extension cable
    CP2104 mini quick start card
    We use the CP2105, which is the Dual UART version for a few more cents.
    The on-chip regulator is useful for very low cost systems.
    My only grumble with Boards like this, is they forget to route
    DSR DTR DCD RI
    even to dummy pads.
