One of those 'passing strings' questions...
Hugh
Sorry, another silly question...
I am trying to select a number of characters from a string (to be sent via simple_debug). The code is below but instead of extracting ten characters as intended I only receive four - do commas have an impact on the way strings are handled?
I thought I'd finally got my head around strings and things but apparently not.
Any help would be really appreciated.
Hugh
PUB BTSendGPSorFF (a, b, c, prefix) | indexC , scratch
' ~Scratchpad2~ is a global long, size "[50]"
bytemove(@scratchpad2, string("$GPRMC,123519,A,4807.038,N,01131.000,E,022.4,084.4,230313,003.1,W*6A"), 50)
' Fill ~scratch~ with zeroes - anything we move to it subsequently will be zero-terminated, allowing us to treat it as a string
bytefill(@scratch, 0, 50)
'Move ten bytes of ~scratchpad2~ into ~scratch~
bytemove(@scratch, @scratchpad2 + 20, 10)
' Send the prefix (string) passed in the call to this PUB.
debug.str(prefix)
' Send ~scratch~ as a string. Because we filled ~scratch~ with zeroes it will be zero-terminated '
debug.str(@scratch)
' Send a CR
debug.tx(13)
Hugh
There's not enough code posted to determine what "prefix" is doing or pointing to. Please post all your code!
You need a second byte array in the global space.
Thank you Jonny - that fixed it. :thumb:
With comments the top files is currently 1,356 lines so I thought better of posting all of it.
My name is Jon.
Sorry. I went by your user name rather than that in your sig.
I've been trying very hard to provide more gentle responses to posts. When requesting "All the code" and receiving a response of "It's too big" is actually insulting and shows a disregard for the folks trying to help.
Please realize, I had to fill in the logic gaps by make assumptions about the code base and your programming ability which I know nothing about. Given an incomplete view of the logic I had to come up with a guess and a thoughtful response. Please keep this in mind for future posts.
I thought that the comments in the code would be sufficient but my over-familiarity with the code meant that in trying to include only that immediately relevant I omitted some information with which anyone coming to it cold would not be familiar. Sorry
As will be apparent from the attached code, my 'programming ability' is 'not a lot'; I am possibly being over-ambitious with what is the third generation of the same idea.
Hugh
FFGPS202 - New board, tacho - Archive [Date 2014.05.26 Time 18.58].zip
