cskord1s wrote: » Does anyone know what pins to connect the emic2 to the propellor activity bot? Regards Con
cskord1s wrote: » Thanks that worked. All I need is code to drive the activity bot and ping sensor
Depending on what else you have connected, P0-P11 should be available for the emic2.
For example, this code:
http://www.parallax.com/downloads/emic-2-propeller-example-code
uses pins P6 and P7
Welcome to the forums!
Are you wanting to program in SPIN/PASM or C?
