Activity Bot and emic2 — Parallax Forums
cskord1scskord1s Posts: 10
edited 2014-05-23 18:29 in General Discussion
Does anyone know what pins to connect the emic2 to the propellor activity bot?
Regards
Con
    edited 2014-05-23 15:28
    cskord1s wrote: »
    Regards
    Con
    Depending on what else you have connected, P0-P11 should be available for the emic2.
    For example, this code:
    http://www.parallax.com/downloads/emic-2-propeller-example-code
    uses pins P6 and P7
    Welcome to the forums!
  • cskord1scskord1s Posts: 10
    edited 2014-05-23 16:17
    Thanks that worked.
    All I need is code to drive the activity bot and ping sensor
    edited 2014-05-23 16:36
    cskord1s wrote: »
    Thanks that worked.
    Are you wanting to program in SPIN/PASM or C?
    Ideally C, but any language will do so long as I can program the bot to use the emic and ping sensors with its server.
