ActivityBot doesn't do anything after loading!
Hey,
I've got some promlem with my ActivityBot which I don't understand. Yesterday everything worked fine, but when I started it today, it did not do anything. Then I tried to load some simple program, the loading works fine as usual (to RAM and also to EEPROM) but nothing happens. There's no output to the terminal and I can't even turn on the LED on pin 26. When I put the switch to position 2 the servos shortly move in different directions. Is there any advice anyonw can give? Thanks!
The first thing that comes to my mind is to see if you need new batteries.
This sounds like low batteries. Do you have a way to test the battery voltage at the terminals on the board?
