ActivityBot doesn't do anything after loading! — Parallax Forums
jajakobjajakob Posts: 1
edited 2014-05-23 11:38 in Robotics
Hey,
I've got some promlem with my ActivityBot which I don't understand. Yesterday everything worked fine, but when I started it today, it did not do anything. Then I tried to load some simple program, the loading works fine as usual (to RAM and also to EEPROM) but nothing happens. There's no output to the terminal and I can't even turn on the LED on pin 26. When I put the switch to position 2 the servos shortly move in different directions. Is there any advice anyonw can give? Thanks!
    edited 2014-05-23 08:19
    jajakob wrote: »
    Hey,
    The first thing that comes to my mind is to see if you need new batteries.
    edited 2014-05-23 09:33
    To echo Duane's comments, it's likely the batteries. After playing be sure to physically unplug the batteries. If left plugged in there can be a slow draw that can drain the batteries overnight.
    edited 2014-05-23 10:32
    Since this also came to Tech Support I will copy my reply here as well.
    This sounds like low batteries. Do you have a way to test the battery voltage at the terminals on the board?
    I'm going to buck the system and suggest that low batteries may be the culprit here.
