4D systems uOLED and BS2e
In a nutshell, has anyone had success with making this combination work? I'm sending serial commands at 9600 baud from a BS2e to a uOLED-128-G2.
I can make it work, but after 10 or so minutes of operation, the display just freezes.
The 4D forum seems to offer little help or have little experience with the BS2.
I suppose at this point I'm just looking for someone to say "Yes, it works fine" (some sample code would be helpful). If nobody has had much luck with it, it may be time for me to look at a different display.
John
John
You say after about 10 minutes the display freezes. Not sure what that means, but if you press the reset button on your control board, does it start working again? If so it could be a software error somewhere, but if not it could mean something is wrong in the hardware. Perhaps current draw causing a regulator to overheat or something. I would try to find out if a reset fixes everything for another 10 minutes. If so I think it's safe to say there a software problem.
