Gripper or arm for Boebot
Hi all,
If there is already a thread on this topic please redirect me.
I need a gripper or simple arm that can be mounted on Boebot.
The Parallax one does not go well with Ping mounting unit so does not seem to be an option.
Can you please give me some ideas?
Silviu
Silviu
[video=youtube_share;rCj-SEX-va4]
I've also used a servo with a bracket connected to the upper standoffs. It works fine, but tending four servos and other sensors starts to overwhelm it. I added a servoPal and that helps a lot.
Nice Project,
What kind os laser sensor you use?
@ silviu
Here is an idea for alternative arm for your Robot
http://forums.parallax.com/showthread.php/149770-7-Laser-Sensor-Bulk-Buy
I want to get better reflector tape, but my job has been nuts for the past two months, so my project time has been limited.
