3.3V logic mosfet?
I want to build a circuit that can handle at least 10A at 12V. I'll go higher after I gain experience in controlling electrolysis current. I know I'll fry a couple propellers during the learning period. At the moment I can only dim LEDs with a pot.
Is there a mosfet designed for 3.3V logic? FETs seem to be a good way to isolate circuits. I could drive several darlingtons or ULN2803's in parallel but that's a guess. I think it's smarter just to ask for advice.
http://pdf.datasheetcatalog.com/datasheet/on_semiconductor/MTP75N03HDL-D.PDF
http://www.allelectronics.com/make-a-store/item/mtp75n03hdl/power-mosfet-mtp75n03hdl/1.html
spikes on switching.
Marty
http://it.mouser.com/Search/Refine.aspx?Keyword=irf3708
Massimo
Oh?
Marty
I've found that the more plates I use the more current it consumes. I'm hoping I can get away without using a gate driver for now. I don't have a scope so I have to be cautious and seek a lot of advice.
27Ah per mole of electrons, ie per 18g of water electrolysed assuming perfect efficiency, which is unlikely.
Ideally, you should select FETS that actually Spec a Value at the Vgs you intend to use, or lower.
eg The OnSemi ATP218 does, as does AOS AON7520
corrected
-24 A, -20 V
RDS(ON) = 0.05 ohms @ VGS= -4.5 V.
RDS(ON) = 0.07 ohms @ VGS= -2.7 V.
RDS(ON) = 0.075 ohms @ VGS= -2.5 V
Any comments?
I copied it from the datasheet and pasted into notepad and the ohm char got changed to a "W" - weird.
I can't find whether the mounting tab is connected to the drain or source...
