Serial 4 digit, 7-segment LED display — Parallax Forums
HughHugh Posts: 362
edited 2014-05-13 00:31 in Propeller 1
Has anyone played with one of these four-digit, seven-segment LED displays with TTL / SPI / I²C interfaces? If so, do you know of any code with which I could test mine?
It should be really simple but I am not sure mine is actually working as it should ("a bad workman blames his tools").
Hugh
    edited 2014-05-07 09:29
    You need to be a little more specific since the control codes can be different depending on who makes/sells the board.
    Are you talking about the ones from Sparkfun? A link to the item would help.
    Here is some test code I used with some older Sparkfun models
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      DecPts      =  $77   ' "w" Decimal point command
      Brightness  =  $7A   ' "z" Brightness command 0(bright) - 254(dim)
      setBaud     =  $7F   ' DEL 0=2400, 1=4800, 2=9600, 3=1440, 4=19200, 5=38400, 6=57600
      ClearScr    =  $76   ' "v" clear display and set position to 1st digit
      Digit1      =  $7B   ' "{" set individual segments for digit one
      Digit2      =  $7C   ' "|" set individual segments for digit two
      Digit3      =  $7D   ' "}" set individual segments for digit three
      Digit4      =  $7E   ' "~" set individual segments for digit four
      TX_PIN        = 0
      BAUD          = 9_600
    VAR
    OBJ
      Seg7     : "FullDuplexSerial.spin"    '   : "simple_serial"                              ' bit-bang serial driver
    PUB Main
      Seg7.start(TX_PIN, TX_PIN, %1000, BAUD)      ' ignore tx echo on rx
      waitcnt(clkfreq / 100 + cnt)
      Seg7.tx(ClearScr)
      Seg7.tx(Brightness)
      Seg7.tx(4)
      waitcnt(clkfreq + cnt)
      Seg7.str(string("1234"))
      Seg7.dec(1567)
      repeat
      Seg7.stop
    DAT
      testmsg byte "testing", 0
  • HughHugh Posts: 362
    edited 2014-05-07 11:06
    Thanks Ron, your code works perfectly. I'd used the wrong settings for FDS.
    I'd intended to set the picture so it was possible to 'click through' to the spec but must have sponged that up also.
    Cheers
    Hugh
    edited 2014-05-07 13:20
    Hugh wrote: »
    Cheers
    Hugh
    Actually cutting and pasting the code screwed up the FDS settings - it should read
    Here is a video I did using a Basic Stamp
    Thanks Ron,
    It works ver well - thanks!
