Is direct memory access supported
I don't even know what that is, but I read the Arduino duo supports if for high speed EEG data logging.
Can some one explain to me how it differs from SPI.
Has anyone use the ti ADS1299 eeg front end in a propeller project yet?
Thanks john
Thanks john
Here's a good starting point for understanding what DMA is. Hold your nose while diving in.
Propeller "at best" can do Pseudo-DMA as I described.
The waitvid command can do a long at a time, so I guess that qualifies a little on the output direction as DMA, but 4 bytes barely qualifies as DMA. DMA does not require software for the process of transferring data. DMA does require software to set up buffers and trigger transfers for outputting bytes (waitvid). DMA is usually a receiving mechanism too. There is no such receive DMA in propeller without requiring software to actually do the transfer. This is why so many of us requested SERDES operation in P2. Alas, we are destined to get another "pseudo DMA" chip.
One signature example of DMA that we've all used is any one of the the video drivers. One cog has direct access to the text data in hub RAM and cycles through it continuously to send glyphs to the video output. The program that puts the text data in RAM does not need to intervene.
Saying that this is not DMA is like saying that the Prop has no UART when --- again funcitonally -- it has nearly as many as you could want. In fact, FullDuplexSerial is not only a UART but uses DMA to buffer and unbuffer data to and from hub RAM. IOW, the main program does not need to intervene every time a serial data byte comes in or goes out.
Clearly there is no DMA into he COGs registers (except perhaps that WAITVID thing). But then I have never seem DMA into any other microprocessors registers either.
Back in the day Intel had the 8089 IO Processor chip. It was a coprocessor like the 8087 maths chip but designed offload IO. Basically DMA in software. We even designed one into an 8086 board. The 8089 did not catch on though.
http://pdf.datasheetcatalog.com/datasheets/1150/489358_DS.pdf
I'll have a shot at this one. DMA, at it's heart, is a buffering mechanism. An SPI controller can use DMA as a means of storing/retrieving it's datastream instead of a FIFO. DMA is generally considered an improvement over FIFO as the buffer length and location is definable and can be large and the driver can direct the DMA engine to any pre-formatted soft buffer it chooses. Obviously it requires more hardware to function though.
Some people prefer to label this as "bus mastering" DMA and keep the straight label of DMA for an uncommon configuration of a centralised DMA controller.
EDIT: As others have pointed out, when a Cog is running as a soft device and, as it common in the Prop, it is filling HubRAM as it's end buffer then this can be considered the equivalent to DMA.
The early computers with DMA had input and output registers, a presettable counter for the address, a down counter for the number of memory locations to load, and a counter/decoder to generate the timing pulses that controlled the hardware. Some time later the counter decoder was replaced with microcode for the control hardware and it became a DMA controller or some such appellation.
No real difference between what those microcoded DMA controllers and a cog does, so the propeller does have DMA capability.
In case it wasn't clear, SPI, Serial Peripheral Interface, is a full duplex synchronous serial data link (http://en.wikipedia.org/wiki/Serial_Peripheral_Interface_Bus). It uses four lines (not counting power): Master In, Slave Out (MISO), Master Out, Slave In (MOSI), Serial Clock (SCK), and Slave Select (SS).
I think DMA has been defined. Typically in the context of a Microcontroller, it's an onboard peripheral that transfers data from another peripheral to a block of memory automatically, saving processor cycles that would otherwise be used to read data from SPI and write it to memory. But typical MCUs don't have multiple cores or software peripherals like the Propeller.
I suppose the real question you want to ask is whether the Propeller has the throughput to support a project with the ADS1299.
Comparable to thermocouple measuring.
