SIP Connector Options???
idbruce
Hello Everyone
I just received a Propeller Memory Card which has 13 SIP for connection and I am wondering what my possible cable and connector options might possibly be.
For severals years, I have been creating my own cables for SIPs, using Molex type connectors, however this is very time consuming. I am wondering what other types of connectors there are that might speed things up a little. For instance, do they make an SIP connector for IDC ribbon cable? I have searched for them before, but never found anything.
You could also use a 26 way standard IDC (.05" pitch) and block up one row of pins. Effectively every second wire would be active.
Everyone should have some of these:-
http://www.parallax.com/catalog/cablesconverters/other
They can be used attached (eg 13 SIP) or broken off where you need to rearrange the pin order, or go to different destinations. They're really useful, and there are male-female and male-male versions too
Yea those are nice and I see that Parallax now offers a similar product.
Someone on the forum suggested these and now I use them all the time.
I now only purchase female connectors. I add extra long pins if I want to make them male type connectors.
Thanks a lot!!!!!! I like it!!!!!!!!!
Not necessarily the perfect solution, but very very close. Okay maybe it is the perfect solution.
I can't even begin to imagine how much time that would have saved me in the past or how much it will save me in the future.
That is also a good tip. It is always nice to have options, especially options that eliminate time consuming labor.
Duaune,
Nice Link!
Bookmarked!
Jim
You can break them at the length you want.
http://www.ebay.com/itm/400340721249?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
However, out of curiousity and armed with the handy connector link provided by Duane, I performed a search at Mouser for multi-color flat ribbon cables. I was surprised by the varying results.
Depending on the circumstances, I still like the option of creating my own cables, and with the wide array of options available for multi-color cables, in combination with the SIP connectors, a person could create some very nice cables for their projects.
3M has a 10 color repeat for one of their products, with upto 64 conductors.
Brown
Red
Orange
Yellow
Green
Blue
Violet
Gray
White
Black
And then there are others that have some colors grouped, like seen on eBay. Pretty interesting.
I think the final recommendation which I finally acted on, came from Loopy Byteloose. I had previously seen them recommended by schill. There's some discussion of transparent heat shrink tubing in the last link. If you're not using transparent HST, you should. It's great stuff.
Well, I did not see those links, so thank you for passing along the knowledge that others shared with you
I've used those pins and housings for years - you can also get them at Jameco...
Male pins 145358
female 100766
4-pin housings 100803
8-pin (2x4 )157438
They use a standard 10 pin IDC connector and a 10 wire ribbon cable that comes from my DIY prop board. The numbers on the sides are on both sides of the connector. The spacing between the headers is .300". That allows me to have access to 4 of the 5 holes on my breadboard. Adjacent pins are hooked together, on the board. That way I did not have to choose what side of the board I want to use.
And they allow me to unplug the prop from one project, and plug it into another without tearing apart the breadboard.
In case anyone wants a set you can order them from my shared projects at OSHpark. The price for a set of 3 is $2.65USD
LOL You are correct. Okay so what is the significance of that? In other words, why do you think they arranged their colors to correspond to the resistor color code?
perhaps to identify the pin number by color? to prevent mistakes. assuming you know the values per color (which I don't without looking them up...)
Enjoy!
I think I will share this with you Mike. My grandfather taught me years ago a little saying to remember the resistor color code. Just take the first letter of each word to get the color
Bad
Black
Beer
Brown
Rots
Red
Our
Orange
Young
Yellow
Guts
Green
But
Blue
Vodka
Violet
Goes
Grey
Well
White
tolerance bands
Get
Gold
Some
Silver
Now
None
he taught me another version, but it is not very P/C
*After drinking the vodka.......
Bad = Black, brown, or blue
Nope, floor...
