Quality audio generation
Hello:
What is the best audio output that has been generated with PWM and filtering.
That is approximately how many bits of accuracy can be obtained by using a PWM generator in a COG with an external filter.
The project uses a standard stereo audio input ADC but i was hoping i could get away with a PWM and filter for the output.
I would like 16-bits of precision at 10 kHz of bandwidth.
I did search the site but did not get much coherent information.
Thanks for any help.
rich
rich
http://forums.parallax.com/showthread.php/140927-Propeller-Signal-Generator?highlight=Sinewave_v2.1.spin
bandwidth:
bitDepth = log2( clkFreq / (bandwidth * 2) )
sample rate:
bitDepth = log2( clkFreq / sampleRate )
For an example, this gives a bit depth of 10.8 for an 44100 Hz CD quality audio signal.
Or in other words, ~64 times less resolution compared to 16 bits.
Even so, a "CD track" played back from the Propeller this way sounds surprisingly good. Not Hifi in any way, but good enough for many projects.
Btw, by using pik33´s technique you would gain a little bit more than 1 bit of resolution.
/Johannes
Thanks much all.
This forum is surely the best feature of the Prop.
cheers,
rich
