Quality audio generation — Parallax Forums
richaj45richaj45 Posts: 179
edited 2014-04-30 10:33 in Propeller 1
Hello:
What is the best audio output that has been generated with PWM and filtering.
That is approximately how many bits of accuracy can be obtained by using a PWM generator in a COG with an external filter.
The project uses a standard stereo audio input ADC but i was hoping i could get away with a PWM and filter for the output.
I would like 16-bits of precision at 10 kHz of bandwidth.
I did search the site but did not get much coherent information.
Thanks for any help.
rich
  • K2K2 Posts: 695
    edited 2014-04-24 22:07
    Post #8 on this thread is a very curious listing of some code pik33 threw together in 20 minutes that uses the video generator and dithering to improve performance. Whether there is something to it or not, I couldn't say. Perhaps if you need 16-bits of precision, you have means of measuring to that precision. If you do, you could enlighten us on this point.
    http://forums.parallax.com/showthread.php/140927-Propeller-Signal-Generator?highlight=Sinewave_v2.1.spin
  • Ahle2Ahle2 Posts: 1,179
    edited 2014-04-25 02:42
    In simplified theory these formulas gives the bitdepth for a given bandwidth/sample rate when using duty dac:
    bandwidth:
    bitDepth = log2( clkFreq / (bandwidth * 2) )
    sample rate:
    bitDepth = log2( clkFreq / sampleRate )
    For an example, this gives a bit depth of 10.8 for an 44100 Hz CD quality audio signal.
    Or in other words, ~64 times less resolution compared to 16 bits.
    Even so, a "CD track" played back from the Propeller this way sounds surprisingly good. Not Hifi in any way, but good enough for many projects.
    Btw, by using pik33´s technique you would gain a little bit more than 1 bit of resolution.
    /Johannes
  • richaj45richaj45 Posts: 179
    Thanks MarkT that is the ticket.
    Thanks much all.
    This forum is surely the best feature of the Prop.
    cheers,
    rich
