QuickStart Eagle tempalte / library? — Parallax Forums
abecedarianabecedarian Posts: 312
edited 2014-05-10 04:33 in General Discussion
Anyone have it?
Just curious before I start trying to figure it out.
Kirk
  • homosapienhomosapien Posts: 147
    edited 2014-04-27 07:50
    Are you referring to library parts for the components used on the QuickStart board, or an Eagle layout for the entire board?
    Nate
    edited 2014-04-27 16:24
    Anyone have it?
    Kirk
    The Quickstart board was designed with Diptrace. You can find those files here:
    http://www.parallax.com/product/40000
    Under "Downloads and Documentation"
    edited 2014-04-27 18:51
    Publison wrote: »
    I'm not sure, but I think it was designed with higher end software which can export to the Diptrace format. IIRC, the name of the software starts with an A.
    edited 2014-04-28 09:49
    Duane Degn wrote: »
    Duane, You are probably right. I guess they re-published in Diptrace, because it is OpenSource, and not too many people have the software that it was done on originally.
  • abecedarianabecedarian Posts: 312
    edited 2014-04-29 12:58
    Thanks for the information, all.
  • ErNaErNa Posts: 1,851
    edited 2014-04-29 13:42
    hi abecedarian, I am also using eagle and faced a similar problem, as I wanted to make a quickstart-compatible board. I tried to find a converter from diptrace to eagle, but without success.
  • oPossumoPossum Posts: 3
    edited 2014-05-10 01:13
    Here is a basic template for a quickstart add on board. It has the mounting holes and 2x20 pin header - nothing else. It was made from careful measurement of the quickstart board, and it currently untested - no boards made yet.
    There are two versions with different size text. Both are probably too small too be readable on a manufactured board.
    Attachment not found.
    960 x 662 - 10K
    945 x 649 - 9K
  • TCTC Posts: 1,019
    I am confused, do you want the whole board? Or the individual parts?
    Also, giving a more detailed question, offers better responses.
