Need help with PID algorithm for closed loop servo position control -- larger servos — Parallax Forums
laser-vectorlaser-vector Posts: 118
edited 2014-04-15 06:52 in Propeller 1
Hi,
It's been a good while since i have worked with the Propeller chip (and must say I'm glad to be back)!
I am using the object "Quadrature Encoder and PID Controller Driver" by Kwabena W. Agyeman to try to control some larger servos (eg&g torque systems 2520).
My issue is that the object was originally developed to control a servo at a constant velocity but i need control of its position.
i tried modifying the object last night to add some simple Spin code that attempts to control the motor's position but
its a bit buggy in some areas and works ok in others..
also i have never written a PID algorithm before (though I have used them many times).
as a note: I'm attempting to get precise positioning of my servos at lower speeds with minimal load.
So This is a modified version of This object.
And the modifications i made where i attempt to control the servo's position reside primarily within the "main()" method.
// PWM1C Proportional Integral Derivative Engine
// Author: Kwabena W. Agyeman
// Modified by: Grant Olsen
// Updated: 4/15/2014
// Designed For: P8X32A
// Version: 1.0-G_Mod
// Copyright (c) 2010 Kwabena W. Agyeman
// See end of file for terms of use.
// Update History:
// v1.0 - Original release - 10/15/2010.
// For each included copy of this object only one spin interpreter should acess it at a time.
// Nyamekye,
// Feedback Circuit:
// Motor Left - To H-Bridge, driven by the propeller chip.
// Motor Right - To H-Bridge, driven by the propeller chip.
// Encoder Left - From the quadrature encoder, driven by the encoder.
// Encoder Right - From the quadrature encoder, driven by the encoder.
CON
'THIS SECTION HAS BEEN ADDED TO ORIGINAL OBJECT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
  LED_PIN = 24
  _PGain = 27  'connected to velocity control PID (AKA original object's PID loop)
  _IGain = 16  'connected to velocity control PID
  _Dgain = 200'connected to velocity control PID
  P_Gain = 14  'connected to position control PID (AKA laser-vector's sort of PID loop thing)
  I_Gain = 8  'connected to position control PID
  D_Gain = 150 'connected to position control PID
  _encoderRightInput = 22
  _encoderLeftInput = 23
  _motorLeftOutput = 28
  _motorRightOutput = 27
VAR
  long cogNumber, positionMeasurement, deltaPositionMeasurement, speedTarget, currentError
  long posTarget 'VARIABLE HAS BEEN ADDED TO ORIGINAL OBJECT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
OBJ
  ser : "FullDuplexSerial"
PUB main | sign, PID, P, I, error, startPosition, resolution, lastTarget, maxSpeed
'THIS METHOD HAS BEEN ADDED TO ORIGINAL OBJECT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  '----initialize vars----
  dira[LED_PIN] := True
  lastTarget := 0 'used in calculating relative positions
  maxSpeed := 1000 'ticks per second limit
  speedTarget := 0 'updated by the PID loop to tell the velocity PID what speed the motor should be rotating
  posTarget := -3000 'set the target position,
  '----Start processes----
  'Start the velocity control asm PID engine
  PIDEngineStart(_motorLeftOutput, _motorRightOutput, _encoderLeftInput, _encoderRightInput, _PGain, _IGain, _DGain)
  'Start serial for debugging purposes
  ser.Start(31,30,0,9600)
  '----Main Loop----
  waitcnt(clkfreq*1 +cnt) 'Motor settling time
  repeat
    ifnot posTarget == lastTarget 'fires when the target position is changed
      lastTarget := posTarget
      startPosition := positionMeasurement
    error := ( posTarget - positionMeasurement ) 'calculate the error (can be +/- depending on direction)
    P := P_Gain * error  'High error gain
    I := ( ( || (posTarget - startPosition) - || error ) + D_Gain) * I_Gain  #> 1
    PID := P / ( ( ( maxSpeed * 100 ) / I ) #> 1  )
    PID := PID <# maxSpeed #> maxSpeed*-1
    speedTarget := PID 'write value into speedTarget for velocity control asm PID loop
    '----Debuging Spam----
    waitcnt(clkfreq/100 +cnt)
    ser.str(string("P:"))
    ser.Dec( speedTarget )
    ser.str(string(" I:"))
    ser.Dec( ( maxSpeed * 100 ) / I )
    ser.str(string(" PID:"))
    ser.Dec(PID)
    ser.str(string(" ERR:"))
    ser.Dec(error)
    ser.tx(13)
    '----Set LED to indicate when at position----
    if error == 0
      outa[LED_PIN] := 1
    else
      outa[LED_PIN] := 0
PUB VerySimpleControlConcept | x, flp
'all this does is loops forever and increments up and down the "speedTarget" variable connected to the velocity control asm PID loop
  x := 0
  flp := 1
  repeat
    repeat x from 0 to 10000 step 100
      speedTarget := x * flp
      'ser.Dec(currentError)
      'ser.tx(13)
      waitcnt(clkfreq/100 + cnt)
    repeat x from 10000 to 0 step 100
      'ser.tx(13)
    flp *= -1
PUB quadraturePosition(deltaPosition) '' 4 Stack Longs
'' // Returns the delta or absolute position of the quadrature encoder in ticks.
'' // DeltaPosition - True to get the delta position since the last call. False to get the absolute position since last call.
  ifnot(deltaPosition)
    return positionMeasurement
  deltaPosition := positionMeasurement
  result := deltaPosition - deltaPositionMeasurement
  deltaPositionMeasurement := deltaPosition
PUB quadratureSpeed(targetSpeed) '' 4 Stack Longs
'' // Drives the quadrature encoder at a target speed using proportional, integral, and derivative control.
'' // TargetSpeed - The target speed in ticks per second. The target speed should be reachable by the system.
  speedTarget := targetSpeed
PUB PIDEngineStart(motorLeft, motorRight, encoderLeft, encoderRight, PGain, IGain, DGain) '' 13 Stack Longs
'' // Starts up the PID driver running on a cog.
'' // Returns true on success and false on failure.
'' // MotorLeft - The left drive pin of the h-bridge. -1 to disable output.
'' // MotorRight - The right drive pin of the h-bridge. -1 to disable output.
'' // EncoderLeft - The left leading signal pin of a quadrature encoder. -1 to disable input.
'' // EncoderRight - The right leading signal pin of a quadrature encoder. -1 to disable input.
'' // PGain - Power of two gain for the proportional drive. (0 to 31). Where zero disables the proportional factor.
'' // IGain - Power of two gain for the integral drive. (0 to 31). Where zero disables the integral factor.
'' // DGain - Power of two gain for the derivative drive. (0 to 31). Where zero disables the derivative factor.
  PIDEngineStop
  if(chipver == 1)
    leftEncoderPin := ((|<((encoderLeft <# 31) #> 0)) & (encoderLeft <> -1))
    rightEncoderPin := ((|<((encoderRight <# 31) #> 0)) & (encoderRight <> -1))
    encoderLeft := ((motorLeft <# 31) #> 0)
    encoderRight := ((motorRight <# 31) #> 0)
    leftDrivePin := ((|<encoderLeft) & (motorLeft <> -1))
    rightDrivePin := ((|<encoderRight) & (motorRight <> -1))
    leftCounterSetup := (constant(%0_0100 << 26) | encoderLeft)
    rightCounterSetup := (constant(%0_0100 << 26) | encoderRight)
    proportionalGain := (31 - ((PGain <# 31) #> 0))
    integralGain := (31 - ((IGain <# 31) #> 0))
    derivativeGain := (31 - ((DGain <# 31) #> 0))
    errorAddress := @currentError
    positionAddress := @positionMeasurement
    cogNumber := cognew(@initialization[0], @speedTarget[0])
    result or= ++cogNumber
PUB PIDEngineStop '' 3 Stack Longs
'' // Shuts down the PID driver running on a cog.
  if(cogNumber)
    cogstop(-1 + cogNumber~)
DAT
'                       PID Driver
                        org     0
' //////////////////////Initialization/////////////////////////////////////////////////////////////////////////////////////////
initialization          mov     frqa,             #1                       ' Setup counter modules.
                        mov     frqb,             #1                       '
                        mov     ctra,             leftCounterSetup         '
                        mov     ctrb,             rightCounterSetup        '
                        or      dira,             leftDrivePin             ' Setup outputs.
                        or      dira,             rightDrivePin            '
                        mov     counter,          deltaTime                ' Setup sample time.
                        add     counter,          cnt                      '
'                       Sync
loop                    waitcnt counter,          deltaTime                ' Wait until sample time.
' //////////////////////Position Input/////////////////////////////////////////////////////////////////////////////////////////
                        mov     buffer,           ina                      ' Sample left and right inputs.
                        test    buffer,           leftEncoderPin wc        '
                        test    buffer,           rightEncoderPin wz       '
                        muxc    encoderCurrent,   #2                       ' Store left and right inputs.
                        muxnz   encoderCurrent,   #1                       '
initializeOnce          mov     encoderPrevious,  encoderCurrent           ' Initializes previous state once.
                        mov     initializeOnce,   #0                       '
                        cmp     encoderPrevious,  encoderCurrent wz        ' Update current state.
if_nz                   rev     encoderPrevious,  #30                      '
if_nz                   xor     encoderPrevious,  encoderCurrent           '
if_nz                   cmpsub  encoderPrevious,  #2 wc, nr                '
if_nz                   sumc    encoderPosition,  #1                       '
                        wrlong  encoderPosition,  positionAddress          '
                        mov     encoderPrevious,  encoderCurrent           ' Update previous state.
' //////////////////////Speed Input////////////////////////////////////////////////////////////////////////////////////////////
                        muxc    divideSign,       instructionMask          ' Flip the sign if negative.
                        rdlong  buffer,           #0                       ' Check if a second has passed.
                        cmpsub  buffer,           speedCounter wc, nr      '
if_nz_or_nc             mov     speedBuffer,      speedCounter             ' Transfer difference.
if_nz_or_nc             mov     speedCounter,     #0                       '
if_z_and_c              jmp     #divideSkip                                '
                        mov     averageCounter,   speedBuffer              ' Setup decay time for average.
                        add     averageCounter,   deltaTime                '
                        mov     divideBuffer,     #0                       ' Setup to divide. Buffer has clock frequency.
                        mov     divideCounter,    #32                      '
divideStart             shr     speedBuffer,      #1 wc, wz                ' Start divide.
                        rcr     divideBuffer,     #1                       '
if_nz                   djnz    divideCounter,    #divideStart             '
divideFinish            cmpsub  buffer,           divideBuffer wc          ' Finish divide.
                        rcl     speedBuffer,      #1                       '
                        shr     divideBuffer,     #1                       '
                        djnz    divideCounter,    #divideFinish            '
divideSign              mov     speedBuffer,      speedBuffer              ' Flip the sign if negative.
                        add     averageBuffer,    speedBuffer              ' Compute average.
                        sar     averageBuffer,    #1                       '
divideSkip              cmp     averageCounter,   speedCounter wc, wz      ' Decay average on slow down.
if_nc_and_nz            jmp     #divideIncrement                           '
                        abs     averageBuffer,    averageBuffer wc         '
                        cmpsub  averageBuffer,    #1                       '
                        negc    averageBuffer,    averageBuffer            '
divideIncrement         add     speedCounter,     deltaTime                ' Increment ticks.
' //////////////////////Feedback/ AKA /velocity control asm PID///////////////////////////////////////////////////////////////////////////////
                        rdlong  PIDCurrentError,  par                      ' Update current error.
                        sub     PIDCurrentError,  averageBuffer            '
                        maxs    PIDCurrentError,  PIDValueMax              '
                        mins    PIDCurrentError,  PIDValueMin              '
                        add     PIDCounter,       PIDCurrentError          ' Compute I.
                        maxs    PIDCounter,       PIDValueMax              '
                        mins    PIDCounter,       PIDValueMin              '
                        mov     PIDBuffer,        PIDCounter               '
                        sar     PIDBuffer,        integralGain             '
                        mov     buffer,           PIDCurrentError          ' Compute D.
                        sub     buffer,           PIDPreviousError         '
                        sar     buffer,           derivativeGain           '
                        add     PIDBuffer,        buffer                   '
                        mov     PIDPreviousError, PIDCurrentError          ' Update error.
                        sar     PIDCurrentError,  proportionalGain         ' Compute P.
                        add     PIDBuffer,        PIDCurrentError
                        wrlong  PIDPreviousError,        errorAddress
' //////////////////////Output/////////////////////////////////////////////////////////////////////////////////////////////////
                        neg     phsa,             PIDBuffer                ' Drive forwards or backwards.
                        mov     phsb,             PIDBuffer                '
' //////////////////////Loop///////////////////////////////////////////////////////////////////////////////////////////////////
                        jmp     #loop                                      ' Repeat.
'                       Data
encoderCurrent          long    0
encoderPosition         long    0
speedBuffer             long    0
speedCounter            long    0
averageBuffer           long    0
averageCounter          long    0
PIDPreviousError        long    0
PIDCounter              long    0
' //////////////////////Constants//////////////////////////////////////////////////////////////////////////////////////////////
deltaTime               long    800
instructionMask         long    %000001_0000_0000_000000000_000000000
PIDValueMax             long    536_870_911
PIDValueMin             long    -536_870_911
' //////////////////////Configuration Settings/////////////////////////////////////////////////////////////////////////////////
leftCounterSetup        long    0
rightCounterSetup       long    0
proportionalGain        long    0
integralGain            long    0
derivativeGain          long    0
' //////////////////////Pin Masks//////////////////////////////////////////////////////////////////////////////////////////////
leftEncoderPin          long    0
rightEncoderPin         long    0
leftDrivePin            long    0
rightDrivePin           long    0
' //////////////////////Addresses//////////////////////////////////////////////////////////////////////////////////////////////
positionAddress         long    0
errorAddress            long    0
' //////////////////////Run Time Variables/////////////////////////////////////////////////////////////////////////////////////
buffer                  res     1
counter                 res     1
divideBuffer            res     1
divideCounter           res     1
' //////////////////////Measurement Variables//////////////////////////////////////////////////////////////////////////////////
encoderSpeed            res     1
encoderPrevious         res     1
' //////////////////////PID Variables//////////////////////////////////////////////////////////////////////////////////////////
PIDCurrentError         res     1
PIDBuffer               res     1
                        fit     496
//                                                  TERMS OF USE: MIT License
// Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation
// files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy,
// modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the
// Software is furnished to do so, subject to the following conditions:
// The above copyright notice and this permission notice shall be included in all copies or substantial portions of the
// Software.
// THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE
// WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
// COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
// ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
and this is just the isolated algorithm (same as the one in main() from above without the comments)
    speedTarget := PID
I hope that the way i wrote this algorithm makes sense for someone to understand it, i have never written a PID function and only vaguely understand their inner workings (plus time away from the prop chip has made this a bit of a learning experience), so please try not to laugh!!
for fun i included a pic of the system im building:
And thanks for anyone's help!!
[edit]
I would also like to list some of the non-desirable behavior i noticed in it.
*the acceleration and deceleration of my PID loop seem to be dependent on the value of maxspeed, where larger values = longer accel and decel times.
*when the motor is at rest (holding at position), if the motor's shaft is forcefully rotated and held at some error value and then slowly rotated back to where error=0, the motor will continue to apply force until some "value" is reached in the opposite direction where the loop finally seems to kick in correctly. i think this is considered overshoot? however while debugging i can clearly see the value of both PID and speedTarget in my loop approaching zero and flipping signs properly. so i think this has more to do with the way im updating the parameters in the original Asm based PID loop that controls the velocity of the motor.
  • T ChapT Chap Posts: 4,249
    edited 2014-04-14 19:12
    I am curious, was this part of the original? How can the output ever reach 0? In this equation, it looks like you will have many cases of P being divided by a larger number.
    You will need the target position, and the current encoder position to derive the error. At a glance I am not sure how you' is working. Are the encoders zero'd out on bootup at a home position, such that the range must always be positive?
  • WurlitzerWurlitzer Posts: 237
    That is a lot of D gain and certainly more than I have ever used.
    In fact 90% of velocity or temperature or fill PID applications I only used P & I with great success. I simply start with P raise it until I get over shoot and back it down a bit then add I-gain until I reach SP. This usually worked even on systems which may have huge variations of the mass being controlled like critical tension/speed of large rolls of paper into a printing press were you start off with a ton or so of paper but need to control it until there is almost nothing left.
    In all honesty the only times I used D-gain was on a system where the running velocity could be changed by the operator prior to the system starting and I needed more or less gain from zero to running speed. I would pre-populate the D-gain based upon operator entered run speeds.
