Need help with PID algorithm for closed loop servo position control -- larger servos
It's been a good while since i have worked with the Propeller chip (and must say I'm glad to be back)!
I am using the object "Quadrature Encoder and PID Controller Driver" by Kwabena W. Agyeman to try to control some larger servos (eg&g torque systems 2520).
My issue is that the object was originally developed to control a servo at a constant velocity but i need control of its position.
i tried modifying the object last night to add some simple Spin code that attempts to control the motor's position but
its a bit buggy in some areas and works ok in others..
also i have never written a PID algorithm before (though I have used them many times).
as a note: I'm attempting to get precise positioning of my servos at lower speeds with minimal load.
So This is a modified version of This object.
And the modifications i made where i attempt to control the servo's position reside primarily within the "main()" method.
and this is just the isolated algorithm (same as the one in main() from above without the comments)
I hope that the way i wrote this algorithm makes sense for someone to understand it, i have never written a PID function and only vaguely understand their inner workings (plus time away from the prop chip has made this a bit of a learning experience), so please try not to laugh!!
for fun i included a pic of the system im building:
And thanks for anyone's help!!
[edit]
I would also like to list some of the non-desirable behavior i noticed in it.
*the acceleration and deceleration of my PID loop seem to be dependent on the value of maxspeed, where larger values = longer accel and decel times.
*when the motor is at rest (holding at position), if the motor's shaft is forcefully rotated and held at some error value and then slowly rotated back to where error=0, the motor will continue to apply force until some "value" is reached in the opposite direction where the loop finally seems to kick in correctly. i think this is considered overshoot? however while debugging i can clearly see the value of both PID and speedTarget in my loop approaching zero and flipping signs properly. so i think this has more to do with the way im updating the parameters in the original Asm based PID loop that controls the velocity of the motor.
// PWM1C Proportional Integral Derivative Engine
// Author: Kwabena W. Agyeman
// Modified by: Grant Olsen
// Updated: 4/15/2014
// Designed For: P8X32A
// Version: 1.0-G_Mod
// Copyright (c) 2010 Kwabena W. Agyeman
// See end of file for terms of use.
// Update History:
// v1.0 - Original release - 10/15/2010.
// For each included copy of this object only one spin interpreter should acess it at a time.
// Nyamekye,
// Feedback Circuit:
// Motor Left - To H-Bridge, driven by the propeller chip.
// Motor Right - To H-Bridge, driven by the propeller chip.
// Encoder Left - From the quadrature encoder, driven by the encoder.
// Encoder Right - From the quadrature encoder, driven by the encoder.
CON
'THIS SECTION HAS BEEN ADDED TO ORIGINAL OBJECT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
LED_PIN = 24
_PGain = 27 'connected to velocity control PID (AKA original object's PID loop)
_IGain = 16 'connected to velocity control PID
_Dgain = 200'connected to velocity control PID
P_Gain = 14 'connected to position control PID (AKA laser-vector's sort of PID loop thing)
I_Gain = 8 'connected to position control PID
D_Gain = 150 'connected to position control PID
_encoderRightInput = 22
_encoderLeftInput = 23
_motorLeftOutput = 28
_motorRightOutput = 27
VAR
long cogNumber, positionMeasurement, deltaPositionMeasurement, speedTarget, currentError
long posTarget 'VARIABLE HAS BEEN ADDED TO ORIGINAL OBJECT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
OBJ
ser : "FullDuplexSerial"
PUB main | sign, PID, P, I, error, startPosition, resolution, lastTarget, maxSpeed
'THIS METHOD HAS BEEN ADDED TO ORIGINAL OBJECT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
'----initialize vars----
dira[LED_PIN] := True
lastTarget := 0 'used in calculating relative positions
maxSpeed := 1000 'ticks per second limit
speedTarget := 0 'updated by the PID loop to tell the velocity PID what speed the motor should be rotating
posTarget := -3000 'set the target position,
'----Start processes----
'Start the velocity control asm PID engine
PIDEngineStart(_motorLeftOutput, _motorRightOutput, _encoderLeftInput, _encoderRightInput, _PGain, _IGain, _DGain)
'Start serial for debugging purposes
ser.Start(31,30,0,9600)
'----Main Loop----
waitcnt(clkfreq*1 +cnt) 'Motor settling time
repeat
ifnot posTarget == lastTarget 'fires when the target position is changed
lastTarget := posTarget
startPosition := positionMeasurement
error := ( posTarget - positionMeasurement ) 'calculate the error (can be +/- depending on direction)
P := P_Gain * error 'High error gain
I := ( ( || (posTarget - startPosition) - || error ) + D_Gain) * I_Gain #> 1
PID := P / ( ( ( maxSpeed * 100 ) / I ) #> 1 )
PID := PID <# maxSpeed #> maxSpeed*-1
speedTarget := PID 'write value into speedTarget for velocity control asm PID loop
'----Debuging Spam----
waitcnt(clkfreq/100 +cnt)
ser.str(string("P:"))
ser.Dec( speedTarget )
ser.str(string(" I:"))
ser.Dec( ( maxSpeed * 100 ) / I )
ser.str(string(" PID:"))
ser.Dec(PID)
ser.str(string(" ERR:"))
ser.Dec(error)
ser.tx(13)
'----Set LED to indicate when at position----
if error == 0
outa[LED_PIN] := 1
else
outa[LED_PIN] := 0
PUB VerySimpleControlConcept | x, flp
'all this does is loops forever and increments up and down the "speedTarget" variable connected to the velocity control asm PID loop
x := 0
flp := 1
repeat
repeat x from 0 to 10000 step 100
speedTarget := x * flp
'ser.Dec(currentError)
'ser.tx(13)
waitcnt(clkfreq/100 + cnt)
repeat x from 10000 to 0 step 100
'ser.tx(13)
flp *= -1
PUB quadraturePosition(deltaPosition) '' 4 Stack Longs
'' // Returns the delta or absolute position of the quadrature encoder in ticks.
'' // DeltaPosition - True to get the delta position since the last call. False to get the absolute position since last call.
ifnot(deltaPosition)
return positionMeasurement
deltaPosition := positionMeasurement
result := deltaPosition - deltaPositionMeasurement
deltaPositionMeasurement := deltaPosition
PUB quadratureSpeed(targetSpeed) '' 4 Stack Longs
'' // Drives the quadrature encoder at a target speed using proportional, integral, and derivative control.
'' // TargetSpeed - The target speed in ticks per second. The target speed should be reachable by the system.
speedTarget := targetSpeed
PUB PIDEngineStart(motorLeft, motorRight, encoderLeft, encoderRight, PGain, IGain, DGain) '' 13 Stack Longs
'' // Starts up the PID driver running on a cog.
'' // Returns true on success and false on failure.
'' // MotorLeft - The left drive pin of the h-bridge. -1 to disable output.
'' // MotorRight - The right drive pin of the h-bridge. -1 to disable output.
'' // EncoderLeft - The left leading signal pin of a quadrature encoder. -1 to disable input.
'' // EncoderRight - The right leading signal pin of a quadrature encoder. -1 to disable input.
'' // PGain - Power of two gain for the proportional drive. (0 to 31). Where zero disables the proportional factor.
'' // IGain - Power of two gain for the integral drive. (0 to 31). Where zero disables the integral factor.
'' // DGain - Power of two gain for the derivative drive. (0 to 31). Where zero disables the derivative factor.
PIDEngineStop
if(chipver == 1)
leftEncoderPin := ((|<((encoderLeft <# 31) #> 0)) & (encoderLeft <> -1))
rightEncoderPin := ((|<((encoderRight <# 31) #> 0)) & (encoderRight <> -1))
encoderLeft := ((motorLeft <# 31) #> 0)
encoderRight := ((motorRight <# 31) #> 0)
leftDrivePin := ((|<encoderLeft) & (motorLeft <> -1))
rightDrivePin := ((|<encoderRight) & (motorRight <> -1))
leftCounterSetup := (constant(%0_0100 << 26) | encoderLeft)
rightCounterSetup := (constant(%0_0100 << 26) | encoderRight)
proportionalGain := (31 - ((PGain <# 31) #> 0))
integralGain := (31 - ((IGain <# 31) #> 0))
derivativeGain := (31 - ((DGain <# 31) #> 0))
errorAddress := @currentError
positionAddress := @positionMeasurement
cogNumber := cognew(@initialization[0], @speedTarget[0])
result or= ++cogNumber
PUB PIDEngineStop '' 3 Stack Longs
'' // Shuts down the PID driver running on a cog.
if(cogNumber)
cogstop(-1 + cogNumber~)
DAT
' PID Driver
org 0
' //////////////////////Initialization/////////////////////////////////////////////////////////////////////////////////////////
initialization mov frqa, #1 ' Setup counter modules.
mov frqb, #1 '
mov ctra, leftCounterSetup '
mov ctrb, rightCounterSetup '
or dira, leftDrivePin ' Setup outputs.
or dira, rightDrivePin '
mov counter, deltaTime ' Setup sample time.
add counter, cnt '
' Sync
loop waitcnt counter, deltaTime ' Wait until sample time.
' //////////////////////Position Input/////////////////////////////////////////////////////////////////////////////////////////
mov buffer, ina ' Sample left and right inputs.
test buffer, leftEncoderPin wc '
test buffer, rightEncoderPin wz '
muxc encoderCurrent, #2 ' Store left and right inputs.
muxnz encoderCurrent, #1 '
initializeOnce mov encoderPrevious, encoderCurrent ' Initializes previous state once.
mov initializeOnce, #0 '
cmp encoderPrevious, encoderCurrent wz ' Update current state.
if_nz rev encoderPrevious, #30 '
if_nz xor encoderPrevious, encoderCurrent '
if_nz cmpsub encoderPrevious, #2 wc, nr '
if_nz sumc encoderPosition, #1 '
wrlong encoderPosition, positionAddress '
mov encoderPrevious, encoderCurrent ' Update previous state.
' //////////////////////Speed Input////////////////////////////////////////////////////////////////////////////////////////////
muxc divideSign, instructionMask ' Flip the sign if negative.
rdlong buffer, #0 ' Check if a second has passed.
cmpsub buffer, speedCounter wc, nr '
if_nz_or_nc mov speedBuffer, speedCounter ' Transfer difference.
if_nz_or_nc mov speedCounter, #0 '
if_z_and_c jmp #divideSkip '
mov averageCounter, speedBuffer ' Setup decay time for average.
add averageCounter, deltaTime '
mov divideBuffer, #0 ' Setup to divide. Buffer has clock frequency.
mov divideCounter, #32 '
divideStart shr speedBuffer, #1 wc, wz ' Start divide.
rcr divideBuffer, #1 '
if_nz djnz divideCounter, #divideStart '
divideFinish cmpsub buffer, divideBuffer wc ' Finish divide.
rcl speedBuffer, #1 '
shr divideBuffer, #1 '
djnz divideCounter, #divideFinish '
divideSign mov speedBuffer, speedBuffer ' Flip the sign if negative.
add averageBuffer, speedBuffer ' Compute average.
sar averageBuffer, #1 '
divideSkip cmp averageCounter, speedCounter wc, wz ' Decay average on slow down.
if_nc_and_nz jmp #divideIncrement '
abs averageBuffer, averageBuffer wc '
cmpsub averageBuffer, #1 '
negc averageBuffer, averageBuffer '
divideIncrement add speedCounter, deltaTime ' Increment ticks.
' //////////////////////Feedback/ AKA /velocity control asm PID///////////////////////////////////////////////////////////////////////////////
rdlong PIDCurrentError, par ' Update current error.
sub PIDCurrentError, averageBuffer '
maxs PIDCurrentError, PIDValueMax '
mins PIDCurrentError, PIDValueMin '
add PIDCounter, PIDCurrentError ' Compute I.
maxs PIDCounter, PIDValueMax '
mins PIDCounter, PIDValueMin '
mov PIDBuffer, PIDCounter '
sar PIDBuffer, integralGain '
mov buffer, PIDCurrentError ' Compute D.
sub buffer, PIDPreviousError '
sar buffer, derivativeGain '
add PIDBuffer, buffer '
mov PIDPreviousError, PIDCurrentError ' Update error.
sar PIDCurrentError, proportionalGain ' Compute P.
add PIDBuffer, PIDCurrentError
wrlong PIDPreviousError, errorAddress
' //////////////////////Output/////////////////////////////////////////////////////////////////////////////////////////////////
neg phsa, PIDBuffer ' Drive forwards or backwards.
mov phsb, PIDBuffer '
' //////////////////////Loop///////////////////////////////////////////////////////////////////////////////////////////////////
jmp #loop ' Repeat.
' Data
encoderCurrent long 0
encoderPosition long 0
speedBuffer long 0
speedCounter long 0
averageBuffer long 0
averageCounter long 0
PIDPreviousError long 0
PIDCounter long 0
' //////////////////////Constants//////////////////////////////////////////////////////////////////////////////////////////////
deltaTime long 800
instructionMask long %000001_0000_0000_000000000_000000000
PIDValueMax long 536_870_911
PIDValueMin long -536_870_911
' //////////////////////Configuration Settings/////////////////////////////////////////////////////////////////////////////////
leftCounterSetup long 0
rightCounterSetup long 0
proportionalGain long 0
integralGain long 0
derivativeGain long 0
' //////////////////////Pin Masks//////////////////////////////////////////////////////////////////////////////////////////////
leftEncoderPin long 0
rightEncoderPin long 0
leftDrivePin long 0
rightDrivePin long 0
' //////////////////////Addresses//////////////////////////////////////////////////////////////////////////////////////////////
positionAddress long 0
errorAddress long 0
' //////////////////////Run Time Variables/////////////////////////////////////////////////////////////////////////////////////
buffer res 1
counter res 1
divideBuffer res 1
divideCounter res 1
' //////////////////////Measurement Variables//////////////////////////////////////////////////////////////////////////////////
encoderSpeed res 1
encoderPrevious res 1
' //////////////////////PID Variables//////////////////////////////////////////////////////////////////////////////////////////
PIDCurrentError res 1
PIDBuffer res 1
fit 496
// TERMS OF USE: MIT License
// Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation
// files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy,
// modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the
// Software is furnished to do so, subject to the following conditions:
// The above copyright notice and this permission notice shall be included in all copies or substantial portions of the
// Software.
// THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE
// WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
// COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
// ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
speedTarget := PID
[edit]
I am curious, was this part of the original? How can the output ever reach 0? In this equation, it looks like you will have many cases of P being divided by a larger number.
You will need the target position, and the current encoder position to derive the error. At a glance I am not sure how you' is working. Are the encoders zero'd out on bootup at a home position, such that the range must always be positive?
In fact 90% of velocity or temperature or fill PID applications I only used P & I with great success. I simply start with P raise it until I get over shoot and back it down a bit then add I-gain until I reach SP. This usually worked even on systems which may have huge variations of the mass being controlled like critical tension/speed of large rolls of paper into a printing press were you start off with a ton or so of paper but need to control it until there is almost nothing left.
In all honesty the only times I used D-gain was on a system where the running velocity could be changed by the operator prior to the system starting and I needed more or less gain from zero to running speed. I would pre-populate the D-gain based upon operator entered run speeds.
