Active RFID tag - small, light and long range?
We need a very small, very light tag with 200yd read range.
The tag cannot be larger than 1/6 inches in diameter.
We have some flexibility about the length and the tag could be 12 inches or longer.
I am seeking guidance on how to source and develop this unit.
Any and all suggestions are welcome.
I have seen some active RFID with specs of 100yds, 200yds.
A transmitter will be fine.
My true requirement is to track an item. My tracker has to be small, light and be identifiable within a couple hundred yards.
The length of the tag/transmitter is not as critical but the diameter is very important. I have to produce this tag/transmitter in a unit size that is less than 1/6 inch diameter.
Any suggestions for a transmitter in this size are also greatly appreciated.
Not sure if you realize the transmitter, (the active tag), will also need a power source, such as a battery. That might not fight your size restraints.
They claim a range of 1/3 mile. I'm highly skeptical for various reasons, but there you have it. It is DIY. The battery pictured is the biggest item, maybe 1/6 inch--I hope it is less for the bee's sake.
I have a battery for the project that is already available.
However, I am not quite capable of building this device without some type of a schematic.
Does anyone have a suggestion where I can obtain some drawings and/or a parts list?
Thanks for the help!!
Another more technical article on the wireless network is in Computer Journal, Tracking Animal Location and Activity with an Automated Radio Telemetry System in a Tropical Rainforest
It appears that the tracking tags were supplied by Sparrow Systems of Fisher IL, but there is not info there about much of anything.
I learned about this stuff from Stuart Mackay's classic, [URL="http://Bio-Medical Telemetry: Sensing and Transmitting Biological Information from Animals and Man"]Bio-Medical Telemetry: Sensing and Transmitting Biological Information from Animals and Man[/URL]. (Note that there are used library copies going for a song) It is long out of date, except for the fundamentals, but it appears to me that the bee tags may indeed utilize that old KISS technology.
All I know about the bee tag is that it puts out pulses, ~2Hz at ~378MHz, no digital coding mentioned, and that it weighs 300mg including the battery.
