New 16-Cog, 512KB: Instruction List plus Semantics & Naming discussion — Parallax Forums
Cluso99Cluso99 Posts: 18,069
edited 2014-04-11 16:21 in Propeller 2
Here is the latest instruction set posted by Chip ~9 Apr 2014
I will try and keep this updated until the next FPGA code release.
I have proposed a few changes in the posts below that may simplify things, make the manual easier to write, and reduce the perceived number of instructions.
Propeller P16X512x Instructions as of 2014/04/10
ZCxS Opcode  ZC I Cond  Dest       Source     Instr00 01      10      11        Operand(s)              Flags
ZCWS 00000ff ZC 1 CCCC  DDDDDDDDD  SSSSSSSSS  RDBYTE  RDBYTEC RDWORD  RDWORDC   D,PTRA/PTRB             ZC ZC ZC ZC
ZCWS 00001ff ZC 1 CCCC  DDDDDDDDD  SSSSSSSSS  RDLONG  RDLONGC RDQUAD  SYSOP     D,PTRA/PTRB ||| D,#     ZC ZC ZC ZC
ZCMS 00010ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  ISOB    NOTB    CLRB    SETB      D,S/#                   ZC ZC ZC ZC
ZCMS 00011ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  SETBC   SETBNC  SETBZ   SETBNZ    D,S/#                   ZC ZC ZC ZC
ZCMS 00100ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  ROR     ROL     SHR     SHL       D,S/#                   ZC ZC ZC ZC
ZCMS 00101ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  RCR     RCL     SAR     REV       D,S/#                   ZC ZC ZC ZC
ZCMS 00110ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  ANDN    AND     OR      XOR       D,S/#                   ZC ZC ZC ZC
ZCMS 00111ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  MUXC    MUXNC   MUXZ    MUXNZ     D,S/#                   ZC ZC ZC ZC
ZCMS 01000ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  ADD     SUB     ADDX    SUBX      D,S/#                   ZC ZC ZC ZC
ZCMS 01001ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  SUMC    SUMNC   SUMZ    SUMNZ     D,S/#                   ZC ZC ZC ZC
ZCWS 01010ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  MOV     NOT     ABS     NEG       D,S/#                   ZC ZC ZC ZC
ZCWS 01011ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  NEGC    NEGNC   NEGZ    NEGNZ     D,S/#                   ZC ZC ZC ZC
ZCMS 01100ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  SETS    SETD    SETCOND SETINST   D,S/#                   ZC ZC ZC ZC
ZCMS 01101ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  MIN     MAX     MINS    MAXS      D,S/#                   ZC ZC ZC ZC
ZCMS 01110ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  MUL     MULS    JMPSW   TOPBIT    D,S/# || D,S/@ | D,S/#  ZC ZC ZC ZC
ZCWS 01111ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  DECOD5  ESWAP8  SPLITW  MERGEW    D,S/#                   ZC ZC ZC ZC
ZCRS 10000ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  TESTB   TESTN   TEST    CMP       D,S/#                   ZC ZC ZC ZC
ZCRS 10001ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  CMPX    CMPS    CMPSX   CMPR      D,S/#                   ZC ZC ZC ZC
ZCMS 10010ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  INCMOD  DECMOD  CMPSUB  SUBR      D,S/#                   ZC ZC ZC ZC
ZCWS 10011ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  MSGINA  MSGINB  ROLNIB  ROLBYTE   D,S/#                   ZC ZC ZC ZC
ZCMS 10010ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  DJZ     DJNZ    TJZ     TJNZ      D,S/@                   ZC ZC ZC ZC
ZCMS 10011ff ZC I CCCC  DDDDDDDDD  SSSSSSSSS  WAITCNT                           D,S/#                   ZC
--WS 1010xnn nf I CCCC  DDDDDDDDD  SSSSSSSSS  GETNIB  SETNIB                    D,S/#,#0..7             -- --
--WS 1011xxn nf I CCCC  DDDDDDDDD  SSSSSSSSS  GETBYTE SETBYTE                   D,S/#,#0..3             -- --
--LS 1100000 fL 1 CCCC  DDDDDDDDD  SSSSSSSSS  WRBYTE          WRWORD            D/#,PTRA/PTRB           --    --
--LS 1100001 fL 1 CCCC  DDDDDDDDD  SSSSSSSSS  WRLONG          WRQUAD            D/#,PTRA/PTRB [s]| D/#,S/#[/s] --    --
--LS 1100010 fL I CCCC  DDDDDDDDD  SSSSSSSSS  WAITPAE         WAITPAN           D/#,S/#                 --    --
--LS 1100011 fL I CCCC  DDDDDDDDD  SSSSSSSSS  WAITPBE         WAITPBN           D/#,S/#                 --    --
--LS 1100100 fL I CCCC  DDDDDDDDD  SSSSSSSSS  MSGDIRA         MSGDIRB           D/#,S/#                 --    --
--LS 1100101 fL I CCCC  DDDDDDDDD  SSSSSSSSS  MSGOUTA         MSGOUTB           D/#,S/# [s]| D/#,S/@[/s]       --    --
--LS 1100110 fL I CCCC  DDDDDDDDD  SSSSSSSSS  JP              [s]JPD    [/s]           D/#,S/@                 --    --
--LS 1100111 fL I CCCC  DDDDDDDDD  SSSSSSSSS  JNP             [s]JNPD   [/s]           D/#,S/@ [s]| D/#,S/#[/s]       --    --
--LS 1101000 fL I CCCC  DDDDDDDDD  SSSSSSSSS  SETINDS         ADJINDS           D/#,S/#                 --    --
--LS 1101001 fL I CCCC  DDDDDDDDD  SSSSSSSSS  WAITVID         REP               D/#,S/# | #23bits       --    --
---- 11100xx x0 n nnnn  nnnnnnnnn  nnnnnnnnn  AUGS    AUGD    <AUGS>  <AUGD>    #23bits                 -- -- -- --
---- 11101xx 00 0 CCCC  fnnnnnnnn  nnnnnnnnn  JMP     JMP                       #abs | @rel             -- --
---- 11101xx 00 1 CCCC  fnnnnnnnn  nnnnnnnnn  CALL    CALL                      #abs | @rel             -- --
---- 11101xx 01 0 CCCC  fnnnnnnnn  nnnnnnnnn  CALLA   CALLA                     #abs | @rel             -- --
---- 11101xx 01 1 CCCC  fnnnnnnnn  nnnnnnnnn  CALLB   CALLB                     #abs | @rel             -- --
---- 11101xx 10 0 CCCC  fnnnnnnnn  nnnnnnnnn  LINK    LINK                      #abs | @rel             -- --
---- 11101xx 10 1 CCCC  fnnnnnnnn  nnnnnnnnn  LOCINST LOCINST                   #abs | @rel             -- --
---- 11101xx 11 0 CCCC  fnnnnnnnn  nnnnnnnnn  LOCPTRA LOCPTRA                   #abs | @rel             -- --
---- 11101xx 11 1 CCCC  fnnnnnnnn  nnnnnnnnn  LOCPTRB LOCPTRB                   #abs | @rel             -- --
--L- 1111xxx 00 L CCCC  DDDDDDDDD  xxx0000ff  OFFP    NOTP    CLRP    SETP      D/#                     -- -- -- --
--L- 1111xxx 00 L CCCC  DDDDDDDDD  xxx0001ff  SETPC   SETPNC  SETPZ   SETPNZ    D/#                     -- -- -- --
ZCL- 1111xxx ZC L CCCC  DDDDDDDDD  xxx0010ff  GETP    GETNP   WAITPR  WAITPF    D/#                     ZC ZC -- --
--L- 1111xxx 00 L CCCC  DDDDDDDDD  xxx0011ff  WAITPX  SETTASK SETPTRA SETPTRB   D/#                     -- -- -- --
--L- 1111xxx 00 L CCCC  DDDDDDDDD  xxx0100ff  SETINDA SETINDB ADJINDA ADJINDB   D/#                     -- -- -- --
--L- 1111xxx 00 L CCCC  DDDDDDDDD  xxx0101ff  JMPT0   JMPT1   JMPT2   JMPT3     D/#                     -- -- -- --
--L- 1111xxx 00 L CCCC  DDDDDDDDD  xxx0110ff  WAIT    SETVID  PUSH              D/#                     -- -- --
Z-W- 1111xxx Z0 0 CCCC  DDDDDDDDD  xxx1000ff  GETPTRA GETPTRB POP               D                       Z- Z- Z-
--R- 1111xxx 00 0 CCCC  DDDDDDDDD  xxx1100ff  LOCPTRA LOCPTRB JMP     CALL      D                       -- -- ZC ZC
--R- 1111xxx ZC 0 CCCC  DDDDDDDDD  xxx1101ff  CALLA   CALLB   LINK              D                       ZC ZC ZC
ZC-- 1111xxx ZC 0 CCCC  xxxxxxxxx  xxx1110ff  RET     <RET>   RETA    RETB                              ZC ZC ZC ZC
---- 1111xxx 00 0 CCCC  xxxxxxxxx  xxx1111ff  DCACHEX ICACHEX <empty> <empty>                           -- -- -- --
And here is the instructions grouped, together with comments and flag settings (some need to be added/corrected)
---------------------------------------------------------------------------------------------------------------------------------  -----Z-----          -----C-----
ZCWS    0000000 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  RDBYTE  D,PTRA/PTRB    Read into cog D(0-extended) from hub byte S[19..0]           Result=0             n/a
ZCWS    0000001 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  RDBYTEC D,PTRA/PTRB    Read into cog D(0-extended) from Cache or hub byte S[19..0]  Result=1             n/a
ZCWS    0000010 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  RDWORD  D,PTRA/PTRB    Read into cog D(0-extended) from hub word S[19..1]           Result=2             n/a
ZCWS    0000011 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  RDWORDC D,PTRA/PTRB    Read into cog D(0-extended) from Cache or hub word S[19..1]  Result=3             n/a
ZCWS    0000100 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  RDLONG  D,PTRA/PTRB    Read into cog D from hub long S[19..2]                       Result=4             n/a
ZCWS    0000101 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  RDLONGC D,PTRA/PTRB    Read into cog D from Cache or hub long S[19..2]              Result=5             n/a
ZCWS    0000110 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  RDQUAD  D,PTRA/PTRB    Read into cogs 4 x D from hub Quad S[19..4]                  Result=6             n/a
--LS    1100000 0L 1 CCCC DDDDDDDDD SSSSSSSSS  WRBYTE  D/#,PTRA/PTRB  Write from cog D[7..0] to hub byte S[17..0]                  n/a                  n/a
--LS    1100000 1L 1 CCCC DDDDDDDDD SSSSSSSSS  WRWORD  D/#,PTRA/PTRB  Write from cog D[15..0] to hub word S[17..1],0               n/a                  n/a
--LS    1100001 0L 1 CCCC DDDDDDDDD SSSSSSSSS  WRLONG  D/#,PTRA/PTRB  Write from cog D[31..0] to hub long S[17..2],00              n/a                  n/a
--LS    1100001 1L 1 CCCC DDDDDDDDD SSSSSSSSS  WRQUAD  D/#,PTRA/PTRB  Write quad cog D[31..0] to hub quad S[17..4],0000            n/a                  n/a
----    1111xxx 00 0 CCCC xxxxxxxxx xxx111100  DCACHEX                Invalidate Data Cache
----    1111xxx 00 0 CCCC xxxxxxxxx xxx111101  ICACHEX                Invalidate Instruction Cache
ZCMS    0010000 ZC I CCCC DDDDDDDDD SSSSSSSSS  ROR     D,S/#          Rotate D right by S[4..0] bits                               Result=0             D[0]
ZCMS    0010001 ZC I CCCC DDDDDDDDD SSSSSSSSS  ROL     D,S/#          Rotate D left by S[4..0] bits                                Result=0             D[31]
ZCMS    0010010 ZC I CCCC DDDDDDDDD SSSSSSSSS  SHR     D,S/#          Shift D right by S[4..0] bits                                Result=0             D[0]
ZCMS    0010011 ZC I CCCC DDDDDDDDD SSSSSSSSS  SHL     D,S/#          Shift D left by S[4..0] bits                                 Result=0             D[31]
ZCMS    0010100 ZC I CCCC DDDDDDDDD SSSSSSSSS  RCR     D,S/#          Rotate carry right into D by S[4..0] bits                    Result=0             D[0]
ZCMS    0010101 ZC I CCCC DDDDDDDDD SSSSSSSSS  RCL     D,S/#          Rotate carry left into D by S[4..0] bits                     Result=0             D[31]
ZCMS    0010110 ZC I CCCC DDDDDDDDD SSSSSSSSS  SAR     D,S/#          Shift D arithemtically right by S[4..0] bits                 Result=0             D[0]
ZCMS    0010111 ZC I CCCC DDDDDDDDD SSSSSSSSS  REV     D,S/#          Reverse 32-S[4..0] bottom bits in D and 0-extend             Result=0             D[0]
ZCMS    0011000 ZC I CCCC DDDDDDDDD SSSSSSSSS  ANDN    D,S/#          AND !S into D                                                Result=0             Parity
ZCMS    0011001 ZC I CCCC DDDDDDDDD SSSSSSSSS  AND     D,S/#          AND S into D                                                 Result=0             Parity
ZCMS    0011010 ZC I CCCC DDDDDDDDD SSSSSSSSS  OR      D,S/#          OR S into D                                                  Result=0             Parity
ZCMS    0011011 ZC I CCCC DDDDDDDDD SSSSSSSSS  XOR     D,S/#          XOR S into D                                                 Result=0             Parity
ZCMS    0011100 ZC I CCCC DDDDDDDDD SSSSSSSSS  MUXC    D,S/#          Copy C to bits in D using S as mask                          Result=0             Parity
ZCMS    0011101 ZC I CCCC DDDDDDDDD SSSSSSSSS  MUXNC   D,S/#          Copy !C to bits in D using S as mask                         Result=0             Parity
ZCMS    0011110 ZC I CCCC DDDDDDDDD SSSSSSSSS  MUXZ    D,S/#          Copy Z to bits in D using S as mask                          Result=0             Parity
ZCMS    0011111 ZC I CCCC DDDDDDDDD SSSSSSSSS  MUXNZ   D,S/#          Copy !Z to bits in D using S as mask                         Result=0             Parity
ZCMS    0100000 ZC I CCCC DDDDDDDDD SSSSSSSSS  ADD     D,S/#          Add S into D                                                 Result=0             unsigned Carry
ZCMS    0100001 ZC I CCCC DDDDDDDDD SSSSSSSSS  SUB     D,S/#          Subtract S from D                                            Result=0             unsigned Borrow
ZCMS    0100010 ZC I CCCC DDDDDDDDD SSSSSSSSS  ADDX    D,S/#          Add extended S+C into D                                      Z & (result=0)       unsigned Carry
ZCMS    0100011 ZC I CCCC DDDDDDDDD SSSSSSSSS  SUBX    D,S/#          Subtract extended S+C from D                                 Z & (result=0)       unsigned Borrow
ZCMS    0100100 ZC I CCCC DDDDDDDDD SSSSSSSSS  SUMC    D,S/#          Sum either -S if C or S if !C into D                         Result=0             signed Overflow
ZCMS    0100101 ZC I CCCC DDDDDDDDD SSSSSSSSS  SUMNC   D,S/#          Sum either S if C or -S if !C into D                         Result=0             signed Overflow
ZCMS    0100110 ZC I CCCC DDDDDDDDD SSSSSSSSS  SUMZ    D,S/#          Sum either -S if Z or S if !Z into D                         Result=0             signed Overflow
ZCMS    0100111 ZC I CCCC DDDDDDDDD SSSSSSSSS  SUMNZ   D,S/#          Sum either S if Z or -S if !Z into D                         Result=0             signed Overflow
ZCWS    0101000 ZC I CCCC DDDDDDDDD SSSSSSSSS  MOV     D,S/#          Move S into D                                                Result=0             S[31]
ZCWS    0101001 ZC I CCCC DDDDDDDDD SSSSSSSSS  NOT     D,S/#          Set D to !S                                                  Result=0             S[31]
ZCWS    0101010 ZC I CCCC DDDDDDDDD SSSSSSSSS  ABS     D,S/#          Set D to absolute S                                          Result=0             S[31]
ZCWS    0101011 ZC I CCCC DDDDDDDDD SSSSSSSSS  NEG     D,S/#          Set D to -S                                                  Result=0             S[31]
ZCWS    0101100 ZC I CCCC DDDDDDDDD SSSSSSSSS  NEGC    D,S/#          Set D to either -S if C or S if !C                           Result=0             S[31]
ZCWS    0101101 ZC I CCCC DDDDDDDDD SSSSSSSSS  NEGNC   D,S/#          Set D to either S if C or -S if !C                           Result=0             S[31]
ZCWS    0101110 ZC I CCCC DDDDDDDDD SSSSSSSSS  NEGZ    D,S/#          Set D to either -S if Z or S if !Z                           Result=0             S[31]
ZCWS    0101111 ZC I CCCC DDDDDDDDD SSSSSSSSS  NEGNZ   D,S/#          Set D to either -S if Z or S if !Z                           Result=0             S[31]
ZCMS    0110000 ZC I CCCC DDDDDDDDD SSSSSSSSS  SETS    D,S/#          Move S[8..0] into D[8..0]                                    Result=0             n/a
ZCMS    0110001 ZC I CCCC DDDDDDDDD SSSSSSSSS  SETD    D,S/#          Move S[8..0] into D[17..9]                                   Result=0             n/a
ZCMS    0110010 ZC I CCCC DDDDDDDDD SSSSSSSSS  SETCOND D,S/#          Move S[8..0] into D[21..18]                                  Result=0             n/a
ZCMS    0110011 ZC I CCCC DDDDDDDDD SSSSSSSSS  SETINST D,S/#          Move S[8..0] into D[31..23]                                  Result=0             n/a
ZCMS    0110100 ZC I CCCC DDDDDDDDD SSSSSSSSS  MIN     D,S/#          Set D to S if unsigned (D<S)                                 D=S                  unsigned(D<S)
ZCMS    0110101 ZC I CCCC DDDDDDDDD SSSSSSSSS  MAX     D,S/#          Set D to S if unsigned (D=>S)                                D=S                  unsigned(D<S)
ZCMS    0110110 ZC I CCCC DDDDDDDDD SSSSSSSSS  MINS    D,S/#          Set D to S if signed (D<S)                                   D=S                  signed(D<S)
ZCMS    0110111 ZC I CCCC DDDDDDDDD SSSSSSSSS  MAXS    D,S/#          Set D to S if signed (D=>S)                                  D=S                  signed(D<S)
ZCMS    0111000 ZC I CCCC DDDDDDDDD SSSSSSSSS  MUL     D,S/#
ZCMS    0111001 ZC I CCCC DDDDDDDDD SSSSSSSSS  MULS    D,S/#
ZCWS    0111011 ZC I CCCC DDDDDDDDD SSSSSSSSS  TOPBIT  D,S/#
ZCWS    0111100 ZC I CCCC DDDDDDDDD SSSSSSSSS  DECOD5  D,S/#
ZCWS    0111101 ZC I CCCC DDDDDDDDD SSSSSSSSS  ESWAP8  D,S/#
ZCWS    0111110 ZC I CCCC DDDDDDDDD SSSSSSSSS  SPLITW  D,S/#
ZCWS    0111111 ZC I CCCC DDDDDDDDD SSSSSSSSS  MERGEW  D,S/#
ZCMS    1001000 ZC I CCCC DDDDDDDDD SSSSSSSSS  INCMOD  D,S/#          Inc D modulo [#]S: D++; If D>S, D=0                          Result=0             wrap?
ZCMS    1001001 ZC I CCCC DDDDDDDDD SSSSSSSSS  DECMOD  D,S/#          Dec D modulo [#]S: D--; If D<0, D=S                          Result=0             wrap?
ZCMS    1001011 ZC I CCCC DDDDDDDDD SSSSSSSSS  SUBR    D,S/#          Subtract (reverse) D=S-D                                     result=0             unsigned Borrow
ZCMS    1001110 ZC I CCCC DDDDDDDDD SSSSSSSSS  ROLNIB  D,S/#
ZCMS    1001111 ZC I CCCC DDDDDDDDD SSSSSSSSS  ROLBYTE D,S/#
--WS    1010xnn n0 I CCCC DDDDDDDDD SSSSSSSSS  GETNIB  D,S/#,#0..7
--MS    1010xnn n1 I CCCC DDDDDDDDD SSSSSSSSS  SETNIB  D,S/#,#0..7
--WS    1011xxn n0 I CCCC DDDDDDDDD SSSSSSSSS  GETBYTE D,S/#,#0..3
--MS    1011xxn n1 I CCCC DDDDDDDDD SSSSSSSSS  SETBYTE D,S/#,#0..3
ZCRS    1000000 ZC I CCCC DDDDDDDDD SSSSSSSSS  TESTB   D,S/#
ZCRS    1000001 ZC I CCCC DDDDDDDDD SSSSSSSSS  TESTN   D,S/#          AND !S into D                                                Result=0             Parity
ZCRS    1000010 ZC I CCCC DDDDDDDDD SSSSSSSSS  TEST    D,S/#          AND S into D                                                 Result=0             Parity
ZCRS    1000011 ZC I CCCC DDDDDDDDD SSSSSSSSS  CMP     D,S/#          Subtract S from D                                            Result=0             unsigned Borrow
ZCRS    1000100 ZC I CCCC DDDDDDDDD SSSSSSSSS  CMPX    D,S/#          Subtract extended S+C from D                                 Z & (result=0)       unsigned Borrow
ZCRS    1000101 ZC I CCCC DDDDDDDDD SSSSSSSSS  CMPS    D,S/#          Compare signed D to S (ZC: D=                                Result=0             signed Borrow
ZCRS    1000110 ZC I CCCC DDDDDDDDD SSSSSSSSS  CMPSX   D,S/#          Compare sign extended D to S+C                               Z & (result=0)       signed Borrow
ZCRS    1000111 ZC I CCCC DDDDDDDDD SSSSSSSSS  CMPR    D,S/#          Subtract (reverse) D=S-D                                     result=0             unsigned Borrow
ZCMS    1001010 ZC I CCCC DDDDDDDDD SSSSSSSSS  CMPSUB  D,S/#          Subtract S from D if D=>S: If D=>S, D -= S                   D=S                  unsigned(D=>S)
ZCMS    0001000 ZC I CCCC DDDDDDDDD SSSSSSSSS  ISOB    D,S/#          Isolate bit D[S/#]
ZCMS    0001001 ZC I CCCC DDDDDDDDD SSSSSSSSS  NOTB    D,S/#          Invert  bit D[S/#]
ZCMS    0001010 ZC I CCCC DDDDDDDDD SSSSSSSSS  CLRB    D,S/#          Clear   bit D[S/#] = 0
ZCMS    0001011 ZC I CCCC DDDDDDDDD SSSSSSSSS  SETB    D,S/#          Set     bit D[S/#] = 1
ZCMS    0001100 ZC I CCCC DDDDDDDDD SSSSSSSSS  SETBC   D,S/#          Set     bit D[S/#] = C
ZCMS    0001101 ZC I CCCC DDDDDDDDD SSSSSSSSS  SETBNC  D,S/#          Set     bit D[S/#] = !C
ZCMS    0001110 ZC I CCCC DDDDDDDDD SSSSSSSSS  SETBZ   D,S/#          Set     bit D[S/#] = Z
ZCMS    0001111 ZC I CCCC DDDDDDDDD SSSSSSSSS  SETBNZ  D,S/#          Set     bit D[S/#] = !Z
[I]Now likely to be renamed PINOFF, PINNOT, PINCLR or PINLO, PINSET or PINHI, PINC, PINNC, PINZ, PINNZ[/I]
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx000000  OFFP    D/#            Pin[D/#]=0; Dir=0
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx000001  NOTP    D/#            Pin[D/#]=!Pin[D/#]; Dir=1
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx000010  CLRP    D/#            Pin[D/#]= 0; Dir=1
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx000011  SETP    D/#            Pin[D/#]= 1; Dir=1
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx000100  SETPC   D/#            Pin[D/#]= C; Dir=1
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx000101  SETPNC  D/#            Pin[D/#]=!C; Dir=1
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx000110  SETPZ   D/#            Pin[D/#]= Z; Dir=1
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx000111  SETPNZ  D/#            Pin[D/#]=!Z; Dir=1
ZCL-    1111xxx ZC L CCCC DDDDDDDDD xxx001000  GETP    D/#            !Z/C = Pin[D/#] via WZ/WC
ZCL-    1111xxx ZC L CCCC DDDDDDDDD xxx001001  GETNP   D/#            Z/!C = Pin[D/#] via WZ/WC
--LS    1100110 0L I CCCC DDDDDDDDD SSSSSSSSS  JP      D/#,S/@        Jump to S/@ if  PIN[D/#]
[s]--LS    1100110 1L I CCCC DDDDDDDDD SSSSSSSSS  JPD     D/#,S/@        Jump to S/@ if  PIN[D/#] Delayed                                                 [/s]
--LS    1100111 0L I CCCC DDDDDDDDD SSSSSSSSS  JNP     D/#,S/@        Jump to S/@ if !PIN[D/#]
[s]--LS    1100111 1L I CCCC DDDDDDDDD SSSSSSSSS  JNPD    D/#,S/@        Jump to S/@ if !PIN[D/#] Delayed                                               [/s]
ZCMS    1001000 ZC I CCCC DDDDDDDDD SSSSSSSSS  DJZ     D,S/@          Decrement D and Jump S/@ if  Z
ZCMS    1001001 ZC I CCCC DDDDDDDDD SSSSSSSSS  DJNZ    D,S/@          Decrement D and Jump S/@ if NZ
ZCRS    1001010 ZC I CCCC DDDDDDDDD SSSSSSSSS  TJZ     D,S/@          Test      D and Jump S/@ if  Z
ZCRS    1001011 ZC I CCCC DDDDDDDDD SSSSSSSSS  TJNZ    D,S/@          Test      D and Jump S/@ if NZ
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx010100  JMPT0   D/#            Jump Task 0
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx010101  JMPT1   D/#            Jump Task 1
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx010110  JMPT2   D/#            Jump Task 2
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx010111  JMPT3   D/#            Jump Task 3
ZCMS    0111010 ZC I CCCC DDDDDDDDD SSSSSSSSS  JMPSW   D,S/@          Z/C/PC --> D; S/# --> Z/C/PC
--R-    1111xxx ZC 0 CCCC DDDDDDDDD xxx110010  JMP     D              D[18:0] --> Z/C/PC via WZ/WC
----    11101xx 00 0 CCCC 0 nnnnnnnnnnnnnnnnn  JMP     #abs           D[18:0] --> Z/C/PC via WZ/WC
----    11101xx 00 0 CCCC 1 nnnnnnnnnnnnnnnnn  JMP     @rel           D[18:0] --> Z/C/PC via WZ/WC
--R-    1111xxx ZC 0 CCCC DDDDDDDDD xxx110011  CALL    D              Call   using 4-level stack
----    11101xx 00 1 CCCC 0 nnnnnnnnnnnnnnnnn  CALL    #abs           Call   using 4-level stack
----    11101xx 00 1 CCCC 1 nnnnnnnnnnnnnnnnn  CALL    @rel           Call   using 4-level stack
ZC--    1111xxx ZC 0 CCCC xxxxxxxxx xxx11100x  RET                    Return using 4-level stack
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx011010  PUSH    D/#            Push   using 4-level stack
Z-W-    1111xxx Z0 0 CCCC DDDDDDDDD xxx100010  POP     D              Pop    using 4-level stack
--R-    1111xxx ZC 0 CCCC DDDDDDDDD xxx110100  CALLA   D              Call   using PTRA stack
----    11101xx 01 0 CCCC 0 nnnnnnnnnnnnnnnnn  CALLA   #abs           Call   using PTRA stack
----    11101xx 01 0 CCCC 1 nnnnnnnnnnnnnnnnn  CALLA   @rel           Call   using PTRA stack
ZC--    1111xxx ZC 0 CCCC xxxxxxxxx xxx111010  RETA                   Return using PTRA stack
                                               PUSHA   D/#            Push   using PTRA stack
                                               POPA                   Pop    using PTRA stack
--R-    1111xxx ZC 0 CCCC DDDDDDDDD xxx110101  CALLB   D              Call   using PTRB  stack
----    11101xx 01 1 CCCC 0 nnnnnnnnnnnnnnnnn  CALLB   #abs           Call   using PTRB  stack
----    11101xx 01 1 CCCC 1 nnnnnnnnnnnnnnnnn  CALLB   @rel           Call   using PTRB  stack
ZC--    1111xxx ZC 0 CCCC xxxxxxxxx xxx111011  RETB                   Return using PTRB  stack
                                               PUSHB   D/#            Push   using PTRB  stack
                                               POPB                   Pop    using PTRB  stack
--R- wr 1111xxx ZC 0 CCCC DDDDDDDDD xxx110110  LINK    D              Call {0000000000000,Z,C,PC[16:0]} --> $1EF
---- wr 11101xx 10 0 CCCC 0 nnnnnnnnnnnnnnnnn  LINK    #abs           Call {0000000000000,Z,C,PC[16:0]} --> $1EF
---- wr 11101xx 10 0 CCCC 1 nnnnnnnnnnnnnnnnn  LINK    @rel           Call {0000000000000,Z,C,PC[16:0]} --> $1EF
---- wr 11101xx 10 1 CCCC 0 nnnnnnnnnnnnnnnnn  LOCINST #abs           17-bit instruction address --> $1EF
---- wr 11101xx 10 1 CCCC 1 nnnnnnnnnnnnnnnnn  LOCINST @rel           17-bit instruction address --> $1EF
--R-    1111xxx 00 0 CCCC DDDDDDDDD xxx110000  LOCPTRA D              {D[16:0],00}                    --> PTRA
----    11101xx 11 0 CCCC 0 nnnnnnnnnnnnnnnnn  LOCPTRA #abs           17-bit instruction address << 2 --> PTRA
----    11101xx 11 0 CCCC 1 nnnnnnnnnnnnnnnnn  LOCPTRA @rel           17-bit instruction address << 2 --> PTRA
--R-    1111xxx 00 0 CCCC DDDDDDDDD xxx110001  LOCPTRB D              {D[16:0],00}                    --> PTRB
----    11101xx 11 1 CCCC 0 nnnnnnnnnnnnnnnnn  LOCPTRB #abs           17-bit instruction address << 2 --> PTRB
----    11101xx 11 1 CCCC 1 nnnnnnnnnnnnnnnnn  LOCPTRB @rel           17-bit instruction address << 2 --> PTRB
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx011000  WAIT    D/#            Wait D/# clocks (0 same as 1)
ZCMS    1001100 ZC I CCCC DDDDDDDDD SSSSSSSSS  WAITCNT D,S/#          Wait CNT[31:0]=D; then D += S If WC, wait CNT[63:32]=D       n/a                  WC=wait upper
--LS    1100010 0L I CCCC DDDDDDDDD SSSSSSSSS  WAITPAE D/#,S/#        Wait PortA Pins EQ: D==(PINS & S), If WC, wait timeout       n/a                  C=timeout
--LS    1100010 1L I CCCC DDDDDDDDD SSSSSSSSS  WAITPAN D/#,S/#        Wait PortA Pins NE: D<>(PINS & S), If WC, wait timeout       n/a                  C=timeout
--LS    1100011 0L I CCCC DDDDDDDDD SSSSSSSSS  WAITPBE D/#,S/#        Wait PortB Pins EQ: D==(PINS & S), If WC, wait timeout       n/a                  C=timeout
--LS    1100011 1L I CCCC DDDDDDDDD SSSSSSSSS  WAITPBN D/#,S/#        Wait PortB Pins NE: D<>(PINS & S), If WC, wait timeout       n/a                  C=timeout
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx001010  WAITPR  D/#            Wait for Pin[D/#] Pos Edge
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx001011  WAITPF  D/#            Wait for Pin[D/#] Neg Edge
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx001100  WAITPX  D/#            Wait for Pin[D/#] Any Edge
--LS    1101001 0L I CCCC DDDDDDDDD SSSSSSSSS  WAITVID D/#,S/#        Wait for video generator to take D & S pixels                n/a                  n/a
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx001110  SETPTRA D/#            PTRA=D/#
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx001111  SETPTRB D/#            PTRB=D/#
Z-W-    1111xxx Z0 0 CCCC DDDDDDDDD xxx100000  GETPTRA D              D=PTRA                                                       Result=0             n/a
Z-W-    1111xxx Z0 0 CCCC DDDDDDDDD xxx100001  GETPTRB D              D=PTRB                                                       Result=0             n/a
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx010000  SETINDA D/#            Set INDA; INDA++ on each use
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx010001  SETINDB D/#            Set INDB; INDB++ on each use
--LS    1101000 0L I CCCC DDDDDDDDD SSSSSSSSS  SETINDS D/#,S/#        Set INDA=?/#; INDB=?/#
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx010010  ADJINDA D/#            Adj INDA+D/#
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx010011  ADJINDB D/#            Adj INDB+D/#
--LS    1101000 1L I CCCC DDDDDDDDD SSSSSSSSS  ADJINDS D/#,S/#        Adj INDA+?/#; INDB+?/#; INDA++ INDB++ each use
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx001101  SETTASK D/#
--L-    1111xxx 00 L CCCC DDDDDDDDD xxx011001  SETVID  D/#
--LS    1100100 0L I CCCC DDDDDDDDD SSSSSSSSS  MSGDIRA D/#,S/#        Send D/# message to DIRA[S/#]
--LS    1100100 1L I CCCC DDDDDDDDD SSSSSSSSS  MSGDIRB D/#,S/#        Send D/# message to DIRB[S/#]
--LS    1100101 0L I CCCC DDDDDDDDD SSSSSSSSS  MSGOUTA D/#,S/#        Send D/# message to OUTA[S/#]
--LS    1100101 1L I CCCC DDDDDDDDD SSSSSSSSS  MSGOUTB D/#,S/#        Send D/# message to OUTB[S/#]
ZCWS    1001100 ZC I CCCC DDDDDDDDD SSSSSSSSS  MSGINA  D,S/#          Recv D message from INA[S/#] (waits 64 clocks)                                    C=timeout
ZCWS    1001101 ZC I CCCC DDDDDDDDD SSSSSSSSS  MSGINB  D,S/#          Recv D message from INB[S/#] (waits 64 clocks)                                    C=timeout
----    0000000 00 0 0000 000000000 000000000  NOP
ZCWS    0000111 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  SYSOP   D,#            (waits for hub, # determines four write-long enables)
--LS    1101001 1L I CCCC DDDDDDDDD SSSSSSSSS  REP     D/#,S/#        Repeat D/#+1 loops of S/# instructions                       n/a                  n/a
----    11100xx x0 n nnnn nnnnnnnnn nnnnnnnnn  AUGS    #23bits        (appends n to upper bits of next immediate S in same task)
----    11100xx x1 n nnnn nnnnnnnnn nnnnnnnnn  AUGD    #23bits        (appends n to upper bits of next immediate D in same task)
    edited 2014-04-10 19:32
    Here is the latest Register Map...
    addr        read        write        name        background
    000..1EE    RAM        RAM           -           -
    1EF         RAM        RAM           (used by LINK to save return address)
    1F0         CNT        -             CNT         DCACHE0
    1F1         RND        -             RND         DCACHE1
    1F2         INA        -             INA         DCACHE2
    1F3         INB        -             INB         DCACHE3
    1F4         RAM        RAM+OUTA      OUTA        -
    1F5         RAM        RAM+OUTB      OUTB        -
    1F6         RAM        RAM+DIRA      DIRA        -
    1F7         RAM        RAM+DIRB      DIRB        -
    1F8         RAM        RAM+CTRA      CTRA        -
    1F9         RAM        RAM+CTRB      CTRB        -
    1FA         RAM        RAM+FRQA      FRQA        -
    1FB         RAM        RAM+FRQB      FRQB        -
    1FC         PHSA       PHSA          PHSA        ICACHE0
    1FD         PHSB       PHSB          PHSB        ICACHE1
    1FE         indirect   indirect      INDA        ICACHE2
    1FF         indirect   indirect      INDB        ICACHE3
    Thanks for the info ozpropdev.
    edited 2014-04-10 19:40
    Cluso99 wrote: »
    I am going to suggest the instructions be simplified (from a users point of view). Here is one example...
    become...
                                                        ' was...    sssssssss
                  SETPIN    D/#,#0      ' or #LO        ' CLRP      xxx000000
                  SETPIN    D/#,#1      ' or #HI        ' SETP      xxx000001
                  SETPIN    D/#,#XOR                    ' NOTP      xxx000010
                  SETPIN    D/#,#OFF                    ' OFFP      xxx000011
                  SETPIN    D/#,#Z                      ' SETPZ     xxx000100
                  SETPIN    D/#,#C                      ' SETPC     xxx000101
                  SETPIN    D/#,#NZ                     ' SETPNZ    xxx000110
                  SETPIN    D/#,#NC                     ' SETPNC    xxx000111
    Note I fixed the missing "D/#,"
    This only changes the compiler, which now must recognize #LO, #HI, #XOR, #OFF, #Z, #NZ, #C, #NC as reserved names, but simplifies it down to one instruction.
    This reduces the instruction count (theoretically) and simplifies the manual.
    The only change to the existing instruction coding is I have rearranged the lower 3 bits of "S" (mainly to permit #0 and #1 for CLR and SET).
    Thoughts anyone???
    Replies were as follows:
    mindrobots wrote: »
    Does GETP become GETPIN and GETNP become GETNPIN so it's consistent?
    Yes, I think there are quite a few simple changes that could be made to simplify things.
    jmg wrote: »
    Did you mean one assembler mnemonic, rather than one instruction.
    There are still 8 unique opcodes/instructions.
    A single form has merit, but if you want to use a param to indicate the action then SETPIN is better as MOVPIN, or WRPIN
    SETP was already use to SET the pin - most programmers expect SET to do what it says
    MOVPIN/WRPIN semantics work on all cases, except for the XOR case, where #XOR is a little confusing.
    To keep a common name of WRPIN & using your form, then this would do what it says.
    WRPIN #NOTPIN
    and pairs with
    RDPIN
    Yes, one mnemonic. Yes MOVPIN or WRPIN/RDPIN might be better, and #NOT or #NOTPIN.
    While I am at it, I think SETS / SETD / SETCOND / SETINST were nicer as MOVS / MOVD / MOVCOND / MOVI or MOVINST.
    Thoughts?
    edited 2014-04-10 20:24
    Following on from...
    OFFP/NOTP/CLRP/SETP/SETPC/SETPNC/SETPZ/SETPNZ
    replaced with the single instruction...
    WRPIN D/#, #0 / #1 / #NOT / #OFF / #Z / #C / #NZ / NC
    and...
    GETP/GETNP
    replaced with...
    RDPIN [#NOT], D/# WZ,WC
    thoughts??
    Does this make sense...
    ISOB/NOTB/CLRB/SETB/SETBC/SETBNC/SETBZ/SETBNZ
    WRBITS #0/#LO/#1/#HI/#NOT/#ISO/#Z/#C/#NZ/#NC, D,S/#
    (maybe change the operand positions???)
    #ISO might be (not quite sure what it does)
    RDBITS #ISO, D, S/#
    Similarly...
    SETPTRA, SETPTRB, SETINDA, SETINDB, SETINDS, GETPTRA, GETPTRB, ADJINDA, ADJINDB, ADJINDS
    might be better as...
    SET #PTRA/#PTRB/#INDA/#INDB/#INDS, D/# [,S/#]
    GET #PTRA/#PTRB, D
    ADJ #INDA/#INDB/#INDS, D/# [,S/#]
  • potatoheadpotatohead Posts: 10,255
    To be honest, I find the SETP, CLRP, etc... easier to remember. The absolute number of instructions isn't a big deal to me. Mnemonics that resonate with a simple verbal representation of the function are more valuable.
    One general SETPIN with odd modes is non-optimal, particularly given the reserved names. Much prefer the simpler case for readability, ease of discovery, etc...
    I also prefer the simple D & S argument form. That's an awful nice attribute of PASM. Going to 2 and sometimes 3 and maybe one is something I would prefer minimized.
    Focusing on the number of primary instruction mnemonics at the expense of more arguments and or fiddly keyword space doesn't add value, IMHO.
  • rjo__rjo__ Posts: 2,114
    edited 2014-04-10 20:36
    I think the semantics are critically important at every stage. The actual names are not… what seems like a perfect name for an instruction to one person might just as easily create confusion in the next for reasons that really cannot be controlled or anticipated. Clear semantic representation and a good cheat sheet are probably all that can really be achieved by mashing the subject.
    I would like to see any suggestions for simple name changes wait until the work is mostly done. At this point, it is really best that Chip use names that make the most sense to him.
    So, I am happy that this is about semantics and not about names!:)
    Heater has correctly identified the area of stack memory and utilization to be one of those areas that troubles new(and old) users and could use a good semantic overhaul. When I first encounter the area, I was surprised that "stack" was not a reserved word with special meaning to the compiler. The user shouldn't be forced to use this keyword, but it should be a keyword with special meaning.
    edited 2014-04-10 20:52
    Cluso,
    Do you need these pin instructions? I know they are convenient, but if they didn't exist, would you really suffer? I realize that this is not an issue of semantics, but this is your thread so I know you won't miss my question… and I don't want to start a new thread just to ask you a question. Would it slow down execution?
    Rich
    edited 2014-04-10 21:44
    Here are the instructions grouped differently
    ZCWS    0000000 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  RDBYTE  D,PTRA/PTRB    (waits for hub)
    ZCWS    0000001 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  RDBYTEC D,PTRA/PTRB    (waits for hub if dcache miss)
    ZCWS    0000010 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  RDWORD  D,PTRA/PTRB    (waits for hub)
    ZCWS    0000011 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  RDWORDC D,PTRA/PTRB    (waits for hub if dcache miss)
    ZCWS    0000100 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  RDLONG  D,PTRA/PTRB    (waits for hub)
    ZCWS    0000101 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  RDLONGC D,PTRA/PTRB    (waits for hub if dcache miss)
    ZCWS    0000110 ZC 1 CCCC DDDDDDDDD SSSSSSSSS  RDQUAD  D,PTRA/PTRB    (waits for hub)
    --LS    1100000 0L 1 CCCC DDDDDDDDD SSSSSSSSS  WRBYTE  D/#,PTRA/PTRB  (waits for hub)
    --LS    1100000 1L 1 CCCC DDDDDDDDD SSSSSSSSS  WRWORD  D/#,PTRA/PTRB  (waits for hub)
    --LS    1100001 0L 1 CCCC DDDDDDDDD SSSSSSSSS  WRLONG  D/#,PTRA/PTRB  (waits for hub)
    --LS    1100001 1L 1 CCCC DDDDDDDDD SSSSSSSSS  WRQUAD  D/#,PTRA/PTRB  (waits for hub, zero-extends #)
    ----    1111xxx 00 0 CCCC xxxxxxxxx xxx111100  DCACHEX                (invalidate data cache)
    ----    1111xxx 00 0 CCCC xxxxxxxxx xxx111101  ICACHEX                (invalidate instruction cache)
    --L-    1111xxx 00 L CCCC DDDDDDDDD xxx000000  OFFP    D/#            (pin operations that affect DIR and OUT simultaneously)
    ZCL-    1111xxx ZC L CCCC DDDDDDDDD xxx001000  GETP    D/#            (pin into !Z/C via WZ/WC)
    ZCL-    1111xxx ZC L CCCC DDDDDDDDD xxx001001  GETNP   D/#            (pin into Z/!C via WZ/WC)
    ZCMS    0111010 ZC I CCCC DDDDDDDDD SSSSSSSSS  JMPSW   D,S/@          (save Z/C/PC into D, load Z/C/PC from S/#)
    --R-    1111xxx ZC 0 CCCC DDDDDDDDD xxx110010  JMP     D              (D[18:17] into Z/C via WZ/WC for JMP..LINK D)
    --R-    1111xxx ZC 0 CCCC DDDDDDDDD xxx110011  CALL    D              (call using 4-level stack)
    ZC--    1111xxx ZC 0 CCCC xxxxxxxxx xxx11100x  RET                    (return using 4-level stack)
    --L-    1111xxx 00 L CCCC DDDDDDDDD xxx011010  PUSH    D/#            (pushes into 4-level stack)
    Z-W-    1111xxx Z0 0 CCCC DDDDDDDDD xxx100010  POP     D              (pops from 4-level stack)
    --R-    1111xxx ZC 0 CCCC DDDDDDDDD xxx110100  CALLA   D              (call using PTRA)
    ZC--    1111xxx ZC 0 CCCC xxxxxxxxx xxx111010  RETA                   (return using PTRA)
                                                   PUSHA   D/#            (alias for WRLONG D/#,PTRA++)
                                                   POPA                   (alias for RDLONG D,--PTRA)
    --R-    1111xxx ZC 0 CCCC DDDDDDDDD xxx110101  CALLB   D              (call using PTRB)
    ZC--    1111xxx ZC 0 CCCC xxxxxxxxx xxx111011  RETB                   (return using PTRB)
                                                   PUSHB   D/#            (alias for WRLONG D/#,PTRB++)
                                                   POPB                   (alias for RDLONG D,--PTRB)
    --R- wr 1111xxx ZC 0 CCCC DDDDDDDDD xxx110110  LINK    D              (jump and write {%0000000000000,Z,C,PC[16:0]} to $1EF)
    ---- wr 11101xx 10 0 CCCC 0 nnnnnnnnnnnnnnnnn  LINK    #abs           (jump and write {%0000000000000,Z,C,PC[16:0]} to $1EF)
    ---- wr 11101xx 10 0 CCCC 1 nnnnnnnnnnnnnnnnn  LINK    @rel           (jump and write {%0000000000000,Z,C,PC[16:0]} to $1EF)
    ---- wr 11101xx 10 1 CCCC 0 nnnnnnnnnnnnnnnnn  LOCINST #abs           (write 17-bit instruction address to $1EF)
    ---- wr 11101xx 10 1 CCCC 1 nnnnnnnnnnnnnnnnn  LOCINST @rel           (write 17-bit instruction address to $1EF)
    --R-    1111xxx 00 0 CCCC DDDDDDDDD xxx110000  LOCPTRA D              (PTRA = {D[16:0],%00})
    ----    11101xx 11 0 CCCC 0 nnnnnnnnnnnnnnnnn  LOCPTRA #abs           (write 17-bit instruction address << 2 to PTRA)
    ----    11101xx 11 0 CCCC 1 nnnnnnnnnnnnnnnnn  LOCPTRA @rel           (write 17-bit instruction address << 2 to PTRA)
    --R-    1111xxx 00 0 CCCC DDDDDDDDD xxx110001  LOCPTRB D              (PTRB = {D[16:0],%00})
    ----    11101xx 11 1 CCCC 0 nnnnnnnnnnnnnnnnn  LOCPTRB #abs           (write 17-bit instruction address << 2 to PTRB)
    ----    11101xx 11 1 CCCC 1 nnnnnnnnnnnnnnnnn  LOCPTRB @rel           (write 17-bit instruction address << 2 to PTRB)
    --L-    1111xxx 00 L CCCC DDDDDDDDD xxx011000  WAIT    D/#            (waits 1+ clocks, 0 same as 1)
    --LS    1100010 0L I CCCC DDDDDDDDD SSSSSSSSS  WAITPAE D/#,S/#        (waits for INA)
    --LS    1100010 1L I CCCC DDDDDDDDD SSSSSSSSS  WAITPAN D/#,S/#        (waits for INA)
    --LS    1100011 0L I CCCC DDDDDDDDD SSSSSSSSS  WAITPBE D/#,S/#        (waits for INB)
    --LS    1100011 1L I CCCC DDDDDDDDD SSSSSSSSS  WAITPBN D/#,S/#        (waits for INB)
    --L-    1111xxx 00 L CCCC DDDDDDDDD xxx001010  WAITPR  D/#            (waits for pos edge on pin)
    --L-    1111xxx 00 L CCCC DDDDDDDDD xxx001011  WAITPF  D/#            (waits for neg edge on pin)
    --L-    1111xxx 00 L CCCC DDDDDDDDD xxx001100  WAITPX  D/#            (waits for any edge on pin)
    --LS    1101001 0L I CCCC DDDDDDDDD SSSSSSSSS  WAITVID D/#,S/#        (waits for vid)
    --L-    1111xxx 00 L CCCC DDDDDDDDD xxx010000  SETINDA D/#            (set INDA/INDB, INDA/INDB increment on each use)
    --L-    1111xxx 00 L CCCC DDDDDDDDD xxx010010  ADJINDA D/#            (adjust INDA/INDB by adding value)
    ZCWS    1001100 ZC I CCCC DDDDDDDDD SSSSSSSSS  MSGINA  D,S/#          (waits up to 64 clocks to receive %010_data32 message on INA, C=timeout)
    ZCWS    1001101 ZC I CCCC DDDDDDDDD SSSSSSSSS  MSGINB  D,S/#          (waits up to 64 clocks to receive %010_data32 message on INB, C=timeout)
    edited 2014-04-10 21:47
    rjo__ wrote: »
    Cluso,
    Rich
    Chip put them in, so I presume they don't take much.
    However, they do make life easier to write directly to a pin (each of the 64 pins can be addressed, but only 1 at a time), so it does make some drivers much simpler to code, and perhaps faster to execute.
    edited 2014-04-10 21:48
    Looks good Cluso. Filed for cheat sheet later on.
    You know, once we get the FPGA, it might be worthwhile to knock out some little samples and truth tables. I had some notes on the other design that were getting there.
    edited 2014-04-10 21:54
    potatohead wrote: »
    Then perhaps the names should be more in line with a family. It is so much easier to read the instruction manual if the instructions can be grouped by naming.
    So if the pin instructions were PINOFF, PINNOT, PINCLR/PINLO, PINSET/PINHI, PINC, PINNC, PINZ, PINNZ they could be under the heading PINxxx and be describe simply. They can then be counted as a single group of instructions - means a lot when you say you have 160+ instructions or 80 base instructions. We don't want it to look too complex (remember the comments about the 400+ instructions.
    And yes, its worthwhile discussing while Chip is doing other things. We can suggest, but of course he is the arbiter. Currently we don't have an fpga to really play with so we might as well discuss something useful.
    edited 2014-04-10 21:57
    potatohead wrote: »
    Interested by what you mean by truth tables? Do you mean when Z & C are set?
    I would like comments to go with some of those more obscure instructions if anyone has the time and knows what they do. (We don't need to bother Chip).
    edited 2014-04-10 22:14
    Sort of.
    Truth tables isn't quite right, but for the logical operators. For other ones, there are key inputs and outputs, like the ones we would use for testing that would be nice to have.
    Remember how Moto did it's programmers manuals? Sometimes a code fragment made sense. Other times, the edge conditions and boundary conditions were listed along with unambigious arguments. That kind of thing.
    The groups you have make sense. Rather than pack the header info into the instruction, which reduced clarity, simply add headers to the groups! Then the instructions can be as they mostly are, easy to remember.
    PIN, PIN, PIN, PIN...
    So we have group header
    Pins
    SETP, NOTP, CLRP, etc...
    Less overall to type, groups remembered once, etc...
    Of course a list of instructions looks complex! So does a simple number of instructions. In some basic sense, they are, but grouping things simply does a lot more damage on that problem than attempting to sort it all in the name of things, which generally fattens those up a lot, adds no more value than the group headings and other simple presentation devices do, and we type a lot more than we otherwise would in the end.
    Most of the instructions names are down to the nubs. There are some like the wait ones that aren't but they sure read well.
    So yeah, I really like the groups and would add headers and when we produce some reference material, can add some stuff there that I mentioned above. I don't mean to imply you should do it, or that it needs to be done now either. Wasn't my intent at all. I like your lists. And they are useful, and a great start for lots of other things!
  • ElectrodudeElectrodude Posts: 1,633
    edited 2014-04-10 22:33
    The fact that the R bit was repurposed into another instruction bit has confirmed my suspicion that, in the end, this chip and the original P2 will be nearly indistinguishable. It opens the door to 500+ instructions like there are on the P2. Now all we need is the CLUT and the fancy video hardware (and hubexec if it wasn't added yet) and the two chips will be completely indistinguishable. Please stop adding features and release something simple, like the P1, very soon, where the main difference is that there's just more preexisting stuff and no new features except encrypted bootloader, because that was one of the things high-volume people wanted, and really simple things like more pins (and dacs because they can be borrowed from the original P2) and hardware multiply.
    If this chip is too similar to the original P2, no one (i.e. high volume customers) will use the what was originally supposed to be P2 when it is finally released, and, even worse, the original P2 might never be released because there won't be enough incentive to release it. I probably missed something because there's been too much going on for me to keep up with, but wasn't this new chip supposed to just be something new that was a lot faster and had more cogs, pins, ram, etc. to increase the Propeller's usability and popularity so Parallax could get enough money to make what was supposed to be the P2?
    Does Parallax have names for these two chips yet? The original P2 is the P8X32C, right? What's the new 16 cog chip called? found it... P16X512x
    electrodude
    EDIT: And yes, there will be 500 instructions in this chip if things keep going the way they are now. Most of the instructions on the original P2 were added because they were necessary to complete recently added features or because they were easy. For example, taking away the R bit means you have to add TARG and friends, and adding hubexec means you have to add AUGx and screw up jmpret. Most of the instructions in the table above aren't on the P1 - they were taken directly from the P2. There are already 169 instructions, up from only 64 on the P1.
    Is it really worth it to rewrite the P2? If you're going to add almost everything in the original P2, why not just strip down the P2 instead of building everything back up on top of the P1?
    edited 2014-04-10 22:50
    potatohead wrote: »
    Sort of.
    Pins
    PINS are a good example where PINHI, PINLO, PINOFF, PINXOR or PINNOT (nice wine ;) ), PINC PINNC, PINZ, PINNZ, PINGET, PINGETN make more sense (at least to me) and can be grouped onto the same page in the manual, instead of requiring a page for each instruction.
  • whickerwhicker Posts: 749
    edited 2014-04-10 22:54
    The fact that the R bit was repurposed into another instruction bit has confirmed my suspicion that, in the end, this chip and the original P2 will be nearly indistinguishable. It opens the door to 500+ instructions like there are on the P2. Now all we need is the CLUT and the fancy video hardware (and hubexec if it wasn't added yet) and the two chips will be completely indistinguishable...
    Reading a lot of comments this past week, I don't think the fancy video hardware is going to go in this 16-cog chip. It may have been a big part of what made it infeasible at 180 nm.
    I too am just resigned to taking what I can get from the P2 project.
    It's also a matter of perspective, is it fortifying and building up a P1? or is it stripping down a P2? Isn't it kind of the same thing at this point?
    P2 is obviously going to morph into something unique, with its own reason to exist.
    The awesome thing about the hardware description code at this point, is it can be moved around in large chunks. Entire features brought in or left out with a copy and paste and some glue statements. Size up or down some array elements. etc.
    edited 2014-04-10 23:03
    It's not. In this process, that video hardware is too aggressive. What we do get is a waitvid that has more bits per transfer, and a fast, direct connection to the DACS. This is great! The old P1 waitvid can't move enough data to make both effective use of the additional RAM we've got, nor effective use of the DACS. From the description we have so far, it's been expanded enough to make some really great displays possible.
    VGA only, at this process, makes a lot of sense too. TV, Component and some other things we might want can be done in software. And they can be done well too.
    Some day, when we can get the other design in a process to match it, that video system is really great! And by the time it gets realized, the display tech will be well matched to it. Honestly, that video system is a great piece of engineering that needs to get out there someday.
    But this one will punch well above it's weight, and it will work more P1 style, which is just fine. We know how to do that too.
    What Chip is doing is a refactor, taking the good things he can, optimizing for power, and in a few cases, like the pins, thinking in new ways to realize some of the basic goals he has for the device.
    I doubt we will see that huge number of instructions. And we really should maximize what we can do in this process! It's to the benefit of everyone IMHO. Let him work a bit. Good things are gonna happen.
    edited 2014-04-10 23:12
    Re: Pages
    Well, I see it a few ways. There is the programmers quick reference, and some programming model, block diagram, data sheet. For a lot of people, that's the primary tool.
    Having a page per instruction is killer otherwise! That's where a code sample, key cases, truth tables, logic diagrams, etc.. go. Some of those pages won't have much, but others will have a ton.
    Wrap that all into an online system, and anybody anywhere can type part of an instruction, get a code snippet, understand the cases they need to, and carry on just fine, quick and easy.
    Or, if they are older school, they can print it off and have a manual too. Personally, I'm beyond manuals when I can get resources like that. And as time goes on, those pages can be augmented with whatever comes up on the support side of things too. No need to republish, or anything like that either. Simply change the date stamp, and or post up a notification, and everybody goes to it when they need to / want to.
    What I still think is nice for manuals, books, is more cookbook, how to, philosophy, tutorial types of things. Moto had it right way back when, and that's precisely what they did. One page per, and some were filled, others simple, with wide margins so people could scribble all over the place. Map that to the tech we have today, and it's excellent, easy to maintain, and the work to populate it can be distributed among as many people as is necessary, up to one person per instruction!
    Imagine we all took 5 - 10 instructions and over the course of a month, produced those pages, simple. We would be done! And it would be excellent!
    Somebody else can package that down into the lean, mean reference docs, etc...
  • ozpropdevozpropdev Posts: 2,792
    edited 2014-04-10 23:32
    @Cluso
    Thanks for the formatted list!
    @Chip
    --LS 1100110 fL I CCCC  DDDDDDDDD  SSSSSSSSS  JP              JPD               D/#,S/@                 --    --
    --LS 1100111 fL I CCCC  DDDDDDDDD  SSSSSSSSS  JNP             JNPD              D/#,S/@ | D/#,S/#       --    --
    Do the delayed JPD and JNPD need to be removed from the list?
    edited 2014-04-10 23:58
    ozpropdev wrote: »
    @Cluso
    @Chip
    No. I just realised they were missing and have been trying to update my post. But the forum software is broken if you have a "percent sign" embedded. I just cannot fix it so, here is the full list again
    --R- wr 1111xxx ZC 0 CCCC DDDDDDDDD xxx110110  LINK    D              (jump and write {0000000000000,Z,C,PC[16:0]} to $1EF)
    ---- wr 11101xx 10 0 CCCC 0 nnnnnnnnnnnnnnnnn  LINK    #abs           (jump and write {0000000000000,Z,C,PC[16:0]} to $1EF)
    ---- wr 11101xx 10 0 CCCC 1 nnnnnnnnnnnnnnnnn  LINK    @rel           (jump and write {0000000000000,Z,C,PC[16:0]} to $1EF)
    --R-    1111xxx 00 0 CCCC DDDDDDDDD xxx110000  LOCPTRA D              (PTRA = {D[16:0],00})
    --R-    1111xxx 00 0 CCCC DDDDDDDDD xxx110001  LOCPTRB D              (PTRB = {D[16:0],00})
    ZCWS    1001100 ZC I CCCC DDDDDDDDD SSSSSSSSS  MSGINA  D,S/#          (waits up to 64 clocks to receive 010_data32 message on INA, C=timeout)
    ZCWS    1001101 ZC I CCCC DDDDDDDDD SSSSSSSSS  MSGINB  D,S/#          (waits up to 64 clocks to receive 010_data32 message on INB, C=timeout)
    IIRC Chip is going to add the SETZC D/#, #0..32 'position to put D[nn] into Z & C (b1=Z, b0=C if #0)
    Postedit: See the first post for the latest update !!!
    edited 2014-04-11 00:23
    Thanks Ray
    My question was that as their are no delayed instructions, the JPD and JPND are invalid now.
    Another query on LINK, In P2(is that called P3 now?) the return address was saved to COG address 0.
    Cheers
    Brian
    edited 2014-04-11 00:45
    ozpropdev wrote: »
    Thanks Ray
    Cheers
    Brian
    Chip was still listing the JPD and JPND although maybe he forgot to remove them.
    The LINK has the notation that the return address is stored to cog $1EF.
    Do you know what the register layout is in $1Fx ?
    edited 2014-04-11 01:03
    This is what I know so far.
    000..1EF	RAM		RAM		-		-
    On LINK, thanks I missed that note.
  • Kerry SKerry S Posts: 163
    edited 2014-04-11 05:26
    Just my 2 cents.
    When it comes to naming op codes I believe that it is better to have individual names for functions that a reader can spot and go "THAT looks like what I want".
    If you cram a bunch of modes into one op code (name) then it can make it very hard for someone new to find what they are looking for.
    edited 2014-04-11 05:44
    Kerry S wrote: »
    Just my 2 cents.
    Conversely, it is harder to find an opcode mnemonic when you don't know what its called. Much easier if they at least all begin similarly. Like WAITxxx groupings and BITS grouping and PIN grouping, etc.
    I have worked on so many micros, sometimes I draw a blank for a mnemonic and I have to look thru a list. Oh, and I might be having a "senior moment" ;)
    edited 2014-04-11 05:46
    I have updated the first post with the Instruction set sorted into groupings, and I have added instruction operation comments and Z & C flag settings. They are those that I think I know - please let me know here if you find any errors or can fill in the blanks.
    edited 2014-04-11 05:57
    Cluso99 wrote: »
    So THAT is what I am having when I constantly have to go back and relocate that instruction that I know I just used the other day... LOL.
    Yes I agree common functions need common grouped naming formats so that it is easy to scan a list and see what is there.
    I drove my self CRAZY for weeks when I started with the P1 looking for the 'SETBIT' function command... Kept thinking I must be missing something somewhere and that was why I could not find it...
    edited 2014-04-11 07:49
    ozpropdev wrote: »
    @Cluso
    @Chip
    Because there is no pipeline in this new chip, there are no delayed branches. So, all those -D branches are gone.
    edited 2014-04-11 07:51
    Cluso99 wrote: »
    I put the PICKZC D/#,S/# instruction in, since it provides the most flexibility.
    edited 2014-04-11 07:53
    Cluso99 wrote: »
    Yes, I don't know what I was thinking. JPD and JNPD won't exist.
    edited 2014-04-11 07:56
    I agree that it would probably be a good thing to name all the pin instructions "PINxxx".
