propgcc default branch, load_cog_driver_xmm is not found
Hi all,
I try to start a .cogc program in XMMC mode using the latest propgcc default branch build Steve posted here:
https://drive.google.com/file/d/0BzcfH7bdVTbtNkRRbmE5TUVtTnM/edit?usp=sharing
When using load_cog_driver_xmm, the compiler throws an undefined reference error message.
Does load_cog_driver_xmm no longer exist in the default branch?
I found the following definition in the propeller.h source:
Do I have to use load_cog_driver(id, param) when using the default branch? The syntax with this function is different. I have to provide an id but
I haven't found an example using the load_cog_driver function to load a .cogc program from another c program.
Does anyone have sample code how this is done or a solution to use the load_cog_driver_xmm function and get rid of the undefined reference compiler error message?
Any help is really appreciated :-)
Christian
propeller-elf-gcc.exe -v GCC 4.6.1 (propellergcc-alpha_v1_9_0_2408) propeller-elf-gcc.exe -r -Os -mcog -o xmmc/IODriver.cog -xc IODriver.cogc propeller-elf-objcopy --localize-text --rename-section .text=IODriver.cog xmmc/IODriver.cog propeller-elf-gcc.exe -I . -L . -I mailbox -I IODriver -o xmmc/IOTest.elf -Os -mxmmc -Wall -m32bit-doubles -fno-exceptions -Dprintf=__simple_printf xmmc/IODriver.cog IOTest.cpp IOTest.cpp: In function 'int main()': IOTest.cpp:40:11: warning: unused variable 'cogId' [-Wunused-variable] C:\Users\CHRIST~1\AppData\Local\Temp\ccyNXX1n.o: In function `start(void volatile*)': (.text+0x20): undefined reference to `load_cog_driver_xmm(unsigned int*, unsigned int, unsigned int*)' collect2: ld returned 1 exit status
* @brief Load a COG driver
* @param id The COG driver name
* @param param Parameter to pass to the driver
* @returns the id of the COG that was loaded
#define load_cog_driver(id, param) \
load_cog_driver_xmm( \
binary_##id##_dat_start, \
binary_##id##_dat_end - binary_##id##_dat_start, \
(uint32_t *)(param))
uint32_t *get_cog_driver_xmm(uint32_t *code, uint32_t codelen);
int load_cog_driver_xmm(uint32_t *code, uint32_t codelen, uint32_t *params);
Christian
Hi Eric,
I had a look at the load_cog_driver_xmm function which just copies the code from xmm to an array in hub by using memcpy and then uses cognew. When I'm at home, I will try to do it that way because it looks like the xmm libraries are somehow missing in Steve's latest build.
Just because of curiosity: Can the load_cog_driver() function also be used with cogc programs or only with spin programs having a DAT section (I'm assuming this only because I see binary_##id##_dat_start as identifier in the header file).
If it can be used with .cogc programs, is there somewhere example code I can look at?
Christian
All the libraries seem to be in the package.
That's really interesting. I don't know why I get
If I compile the same program with the release branch, the build succeeds.
When I'm at home I will post a zip file containing the complete SimpleIDE project.
If you have time, maybe you could try to build the project.
Christian
Everyone please remember that the default branch alpha_1_9_2408 package is not released. I heard we may be running a test program with it before summer because Andy needs XMMC multi-cog capabilities.
Thanks.
Here is a pasm project using propellergcc-alpha_v1_9_2408.
The only differences between this and the repository is that it is built with SimpleIDE instead of make and this start() function changed a bit.
// C stub function to start the PASM routine // need to be able to provide the entry point to the PASM // and a pointer to the STATIC HUB mailbox // the cognew function in the propeller.c library returns the COG # // int start(unsigned int *pinptr) { // The label binary_toggle_dat_start is automatically placed // on the cog code from toggle.dat by objcopy (see the Makefile). extern unsigned int binary_toggle_dat_start[]; extern unsigned int binary_toggle_dat_end[]; // <+++++++++++++++ added +++++++++++++++> //return cognew(&binary_toggle_dat_start, pinptr); // commented return load_cog_driver(toggle,pinptr); // <+++++++++++++++ added +++++++++++++++> }Thanks for trying it out and attaching the project! :-)
I will try to compile the project at home.
But it looks like only load_cog_driver() is used instead of load_cog_driver_xmm().
Christian
Eric
Notice that in this example (and the other) load_cog_driver_xmm is used by a macro. In this case the equivalent cogc macro has been added.
There is a problem with the simpletools print library for this example. Use printf which does proper locking.
Another issue with the Simple Libraries seems to be some propeller-gcc branch incompatibility.
/** * @brief Load a COGC driver * @param id The COGC driver name * @param param Parameter to pass to the driver * @returns the id of the COG that was loaded */ #define load_cogc_driver(id, param) \ load_cog_driver_xmm( \ _load_start_##id##_cog, \ _load_stop_##id##_cog - _load_start_##id##_cog, \ (uint32_t *)(param))Steve, both examples work. I will use them as reference implementation.
I have attached the project I did which doesn't work. Maybe you have luck to find out, why it doesn't work ;-)
Thanks again!
Christian
It looks like the only way to find the load_cog_driver_xmm function is by using a .c file.
The forward declaration is not included in the propeller.h #ifdef cplusplus wrapper.
If I move the propeller.h cplusplus wrapper to near the end of the file, then .cpp will work fine.
Other issues:
1. Stack not big enough. Should be: unsigned stack[EXTRA_STACK_LONGS + 16];
static struct {
unsigned stack[16];
volatile ioDriverMailbox_t ioDriverMailbox;
} ioDriverPar;
2. Wrong symbol for load_cog_driver_xmm. That macro doesn't expand IODriver_code to _load_start_IODriver_code_cog.
3. Also IODriver_code is not the right symbol for SimpleIDE, it's the same name as the file. You can always check these by doing Show Map File in the project manager.
uint8_t start(volatile void *parptr) {
extern uint32_t *IODriver_code;
#if defined(__PROPELLER_XMM__) || defined(__PROPELLER_XMMC__)
return load_cog_driver_xmm(IODriver_code, 496, (uint32_t *)parptr);
#else
return cognew(IODriver_code, parptr);
#endif
Thanks very much for analyzing the project and finding all these issues.
It was 2am in the morning when I put that all together so maybe I was more asleep than awake :-)
I used the demos\toggle\cogc_toggle example as reference. There I saw this:
/* * function to start up a new cog running the toggle * code (which we've placed in the toggle_fw.cog section) */ void start(volatile void *parptr) { extern unsigned int *toggle_fw_code; #if defined(__PROPELLER_XMM__) || defined(__PROPELLER_XMMC__) load_cog_driver_xmm(toggle_fw_code, 496, (uint32_t *)parptr); #else cognew(toggle_fw_code, parptr); #endif }With regards to EXTRA_STACK_LONGS: Shouldn't that only be used when starting a cog in XMM mode where the XMM VM is executing the code from
external memory? When a driver is copied and executed directly in the cog ram without any VM involved, I thought the stack size is only needed, when the code uses
stack. The toggle cogc example also defines a stack size of 16 and should run in LMM and XMM mode.
Yesterday evening I also noticed the issue with C++. Your example worked well until I switched to C++. Then it also stopped working with the unknown reference
error message.
So I ended up using a workaround instead of the load_cog_driver or load_cog_driver_xmm.
I copy the code from xmm memory to an array and use cognew handing over the array. Works well.
But the part with the stack size still puzzles me. Are you sure that such a big stack size (EXTRA_STACK_LONGS is > 1kbyte when I remember correctly) is needed
when a cogc program is directly executed in cog ram by using cognew?
Christian
Oops.
No it is not necessary for cogc. Sorry about the confusion.
