P1 Verilog implementation: Alpha testers required - Page 2 — Parallax Forums
2»
  • jmgjmg Posts: 15,199
    edited 2014-04-06 12:15
    Ale wrote: »
    Everything is pipelined, so it should be fairly easy to modify. You will lose the possibility to use the next modified instruction (not available in P1 for another 4 clocks), and there will be some latency for opcodes after djnz, tjz and tjnz... but they are in the P1 anyways.
    Sounds great.
    Another suggestion is to make the opcode values as defines, so you can choose P1 Binary, or P2 Binary versions.
    This would allow a 2 Clock Shrink-P2 Cog, to be looked at, than can be driven from a P2 ASM (subset).
    Call this P2S for (Shrink/Subset)
    The idea is to clone the P1 core operation, and then add a sprinkle of P2 opcodes, but keeping the LOGIC area under the RAM area. (present P1 Logic is much less than P1 COG RAM area, Present P2 Logic is much larger than P2 COG RAM )
    edited 2014-04-06 14:11
    Cluso99 wrote: »
    David, look on the 5W thread from the date/time of my post above, backwards.
    Thanks! I see it now. It doesn't look like he's offering to make it available though. I'd still be interested in a port of Ale's P1 COG to the DE0-Nano.
    edited 2014-04-06 17:57
    Ale wrote: »
    I get the following for NEGC
    NEGC    ---D---- ---S---- ZC = ---Q---- ZC
            00000000 00000001 00 = 00000001 00
            00000000 00000001 10 = 00000001 00
            00000000 00000001 0[COLOR="#FF8C00"]1[/COLOR] = [COLOR="#FF8C00"]ffffffff[/COLOR] 00
            00000000 00000001 1[COLOR="#FF8C00"]1[/COLOR] = [COLOR="#FF8C00"]ffffffff[/COLOR] 00
    I get the following for NEGNZ
    NEGNZ   ---D---- ---S---- ZC = ---Q---- ZC
            00000000 00000001 [COLOR="#020FC0"]0[/COLOR]0 = [COLOR="#020FC0"]ffffffff[/COLOR] 00
            00000000 00000001 [COLOR="#020FC0"]0[/COLOR]1 = [COLOR="#020FC0"]ffffffff[/COLOR] 00
            00000000 00000001 11 = 00000001 00
    Looks fine to me, which bit do you have trouble with?
  • AleAle Posts: 2,363
    edited 2014-04-20 00:18
    It seems I posted the results of my ALU test :(... I should use more descriptive names for files.
    I updated the repository with a better and HUB-aware version. At least it sort of works for the bemicro. There is a serial console output with processor debug info.
    The serial output should show cog address, opcode and HUB address and data. At least it works in the simulator.
    Is someone there ?... it seems that all the excitement goes to the new P1+... That chip will be a blast !
    edited 2014-04-20 05:10
    Ale, I look here perhaps once a week. But yes, I think currently the action is on the P1+/P2.
    A couple of years ago and this would have been a killer thread! Once the other dust settles I am sure the interest will pick up here.
    It should be possible to test new instructions and features out here. Or just adding a fewmore i/o.
    So please don't lose heart due to the lack of enthusiasm.
    edited 2014-04-20 05:19
    Ale,
    For sure we are out here. And totally fascinated. Please continue. No time to play unfortunately.
    How about posting you project at opencores.org ?
    edited 2014-04-20 05:33
    Maybe when it is finished, I'll post it on opencores. For the time being there is quite a bit to do :)
    edited 2014-04-21 07:06
    Hi Ale,
    I'm out here. I've just never built anything for an FPGA before and haven't used the Altera tools (Quartus) for anything other than loading Chip's P2 emulation images. I'm facing a bit of a learning curve before I can get to doing anything useful with my BE Micro....I'll get there slowly but surely.
    What I've looked at is impressive and exciting!
