Help with converting SEROUT to propeller — Parallax Forums
MiniSumoManMiniSumoMan Posts: 1
edited 2014-04-01 12:31 in Propeller 1
I am working on a min-sumo project and am converting it chip from the BS2 to the Propeller. On the BS2 powered version, I ran the motors with a simple serout command: SEROUT 1, 84, [2, 127] where the pin is 1, the baud is 84, and two data values are transmitted. I have tried to convert this with both he BS2_FUNCTIONS object and the Full_Duplex_Serial object and have not been able to run the motors with the propeller. Any help would be appreciated!
  • JonnyMacJonnyMac Posts: 9,795
    edited 2014-03-31 19:12
    The value of 84 in a stock BS2 is 9600 baud which is a very tame baud rate -- you can do that in Spin. Here's a simple template that should get you going.
    ''   File.......
    ''   Purpose....
    ''   Author.....
    ''   E-mail.....
    ''   Started....
    ''   Updated....
    con { timing }
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000                                          ' use 5MHz crystal
      CLK_FREQ = ((_clkmode - xtal1) >> 6) * _xinfreq               ' system freq as a constant
      MS_001   = CLK_FREQ / 1_000                                   ' ticks in 1ms
      US_001   = CLK_FREQ / 1_000_000                               ' ticks in 1us
      BAUD     = CLK_FREQ / 9600
    con { io pins }
      RX1   = 31                                                    ' programming / terminal
      TX1   = 30
      SDA   = 29                                                    ' eeprom / i2c
      SCL   = 28
      MCTRL =  0
    obj
    var
    pub main
      high(MCTRL)                                                   ' set to idle state
      repeat
        waitcnt(0)
    pub update_motors(speed1, speed2)
      serout(speed1)
      serout(speed2)
    pub serout(b) | t
    '' TX single byte
    '' -- driven/true mode
      b := (b | $100) << 2                                          ' add start and stop bits
      t := cnt
      repeat 10
        waitcnt(t += BAUD)                                          ' hold for bit timing
        outa[MCTRL] := (b >>= 1)                                    ' output the bit
    con
      {  B A S I C S  }
    pub pause(ms) | t
    '' Delay program in milliseconds
      if (ms < 1)                                                   ' delay must be > 0
        return
      else
        t := cnt - 1776                                             ' sync with system counter
        repeat ms                                                   ' run delay
          waitcnt(t += MS_001)
    pub high(pin)
    '' Makes pin output and high
      outa[pin] := 1
      dira[pin] := 1
    pub low(pin)
    '' Makes pin output and low
      outa[pin] := 0
      dira[pin] := 1
    pub toggle(pin)
    '' Toggles pin state
      !outa[pin]
      dira[pin] := 1
    pub input(pin)
    '' Makes pin input and returns current state
      dira[pin] := 0
      return ina[pin]
    pub pulse_out(pin, us) | pwtix, state
      pwtix := us * (clkfreq / 1_000_000)                           ' pulse width in ticks
      state := ina[pin]                                             ' read incoming state of pin
      if (ctra == 0)                                                ' ctra available?
        if (state == 0)                                             ' low-high-low
          low(pin)                                                  ' set to output
          frqa := 1
          phsa := -pwtix                                            ' set timing
          ctra := (%00100 << 26) | pin                              ' start the pulse
          repeat
          until (phsa => 0)                                         ' let pulse finish
        else                                                        ' high-low-high
          high(pin)
          frqa := -1
          phsa := pwtix
          repeat
          until (phsa < 0)
        ctra := 0                                                   ' release counter
        return us
      elseif (ctrb == 0)
        if (state == 0)
          low(pin)
          frqb := 1
          phsb := -pwtix
          ctrb := (%00100 << 26) | pin
          repeat
          until (phsb => 0)
        else
          high(pin)
          frqb := -1
          phsb := pwtix
          repeat
          until (phsb < 0)
        ctrb := 0
        return us
      else
        return -1                                                   ' alert user of error
    dat
      Terms of Use: MIT License
      Permission is hereby granted, free of charge, to any person obtaining a copy of this
      software and associated documentation files (the "Software"), to deal in the Software
      without restriction, including without limitation the rights to use, copy, modify,
      merge, publish, distribute, sublicense, and/or sell copies of the Software, and to
      permit persons to whom the Software is furnished to do so, subject to the following
      conditions:
      The above copyright notice and this permission notice shall be included in all copies
      or substantial portions of the Software.
      THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
      INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
      PARTICULAR PURPOSE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
      HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
      CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
      OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    Hi MiniSumoMan,
    if you create an code-archive (zipfile) from within the propellertool and attach this to a posting we (the forum-members) can take a look into your code.
    Just a few guessings:
    - You have to start the FullDuplexSerial-object b ycalling the start-method before you can use it. Did you do that?
    - the propeller-chip is a 3.3V device. What voltage does the receiver use?
    - As JM mentioned 84 must be translated to 9600 for the propeller-chip FDX-method
    Did you do some basic tests with your code like a closed loop Tx to Rx trying to receive data?
    Did you test the propeller-chip sending some testdata to the PST.EXE?
    best regards
    Stefan
