2200mAh Portable Power Bank On Sale $10 til 3/31 - not useful w/ QuickStart
http://www.radioshack.com/product/index.jsp?productId=28733496&utm_campaign=pid28733496&utm_medium=RSCOM&utm_source=ProductPage&utm_content=OptionsBlue
Keep your devices powered up, even when there's no outlet available, with the RadioShack 2200mAh Portable Power Bank. It provides up to 6 hours of talk time and charges quickly from any USB port.
Provides up to 6 hours of talk time
Works with most micro USB devices
Maximizes standby time by automatically shutting off and maintaining its charge while not in use
LED indicator lets you see the energy level at the push of a button
Capacity: 2200mAh
Output: 5V DC, 1A
Battery charging time: 3.5 hours
Cable length: 13"
Good catch Phil!
Yep - just tried it - no go!
Of course that wasn't mentioned on the package.
Oh well I'm sure I'll find a use for it...
And it will not power a Rev A Quick Start.
http://www.radioshack.com/product/index.jsp?productId=17244076
Charge a Phone and Kindle with 80% left.
The Prop pin output pulses the MOSFET gate with a low duty cycle. If the Prop pin gets stuck low, the chip will reset, so it also acts as a watchdog of sorts.
Costco sells what I believe to be the 2200 mah units at 19.99 for a two-pack. Two USB cables included.
Cheers,
Peter(pjv)
