2200mAh Portable Power Bank On Sale $10 til 3/31 - not useful w/ QuickStart — Parallax Forums
edited 2014-03-30 15:16 in General Discussion
http://www.radioshack.com/product/index.jsp?productId=28733496&utm_campaign=pid28733496&utm_medium=RSCOM&utm_source=ProductPage&utm_content=OptionsBlue
Keep your devices powered up, even when there's no outlet available, with the RadioShack 2200mAh Portable Power Bank. It provides up to 6 hours of talk time and charges quickly from any USB port.
Provides up to 6 hours of talk time
Works with most micro USB devices
Maximizes standby time by automatically shutting off and maintaining its charge while not in use
LED indicator lets you see the energy level at the push of a button
Capacity: 2200mAh
Output: 5V DC, 1A
Battery charging time: 3.5 hours
Cable length: 13"
    edited 2014-03-30 12:32
    Just a heads up from the manual: you can't use it to charge devices with input currents less than 100 mA. IOW, if you're trying to use it to power, say, a QuickStart board that draws less than 100 mA, it will not work.
    edited 2014-03-30 12:41
    Good catch Phil!
    Yep - just tried it - no go!
    Of course that wasn't mentioned on the package.
    Oh well I'm sure I'll find a use for it...
    edited 2014-03-30 12:49
    So optionally switch a 50 ohm resistor across the 5V output to draw 100 mA. A bit wasteful, but do whatcha gotta do! Half watt ought to do it. Even a USB Multi splitter with a few LEDs might do it.
    edited 2014-03-30 12:58
    And it will not power a Rev A Quick Start.
    edited 2014-03-30 13:00
    Picked up this one last week for $24.97:
    http://www.radioshack.com/product/index.jsp?productId=17244076
    Charge a Phone and Kindle with 80% left.
    edited 2014-03-30 13:52
    I would almost bet that the charger/power source is looking for peak currents in excess of 100 mA. If that's the case, a simple addition to the QuickStart should remedy the problem without drawing excess average power form the battery:
    The Prop pin output pulses the MOSFET gate with a low duty cycle. If the Prop pin gets stuck low, the chip will reset, so it also acts as a watchdog of sorts.
    287 x 253 - 1K
  • pjvpjv Posts: 1,903
    Hi All
    Costco sells what I believe to be the 2200 mah units at 19.99 for a two-pack. Two USB cables included.
    Cheers,
    Peter(pjv)
