XMMC Memory model with ActivityBot
Hello everybody.
I've spent a little time to learn programming my activitybot with the tutorials related to it.
I love this robot, especially the easy way we can program it. Parallax did a very good job.
Now i would like to make my own program, using and combine all that i've learned.
The problem is that the activitybot as insufficient memory to make all that i want.
So, i've searched for tutorials that explain how to use the xmm memory model, but i didn't find something that is understandable for me (i'm a beginner, sorry).
Is there a tutorial somewhere (or a documentation) that i can use for that ?
Perhaps i must learn Spin, but in that case, where can i find tutorial to learn this language ?
But honestly, I prefer the C language.
Thanks a lot.
Thanks a lot.
For prototyping, I'd recommend ditching the abdrive library, and use servodiffdrive.h instead. That should make enough room for your other libraries. The servodiffdrive library doesn't read the encoders, but neither does the Spin version.
To use servodiffdrive:
Remove the screws that hold the battery pack to the chassis and set it aside. Don't disconnect it or anything, we just need screwdriver access to the adjusting holes in the servos.
> Run a program that includes servodiffdrive.h and uses drive_speeds(0, 0) to send the stay still signal.
> Then, use a Phillips screwdriver to adjust the Pot behind the hole in the servo case to adjust each servo so that it stays still with that stay still signal.
> Experiment with servodiffdrive.h and use drive_speeds for speed control.
Also PM me if you are interested in testing a smaller footprint abdrive library when its ready for testing.
I will test the servodiffdrive library, and i sent you the PMs.
So, if the tests are ok for me, can i remove the wheel encoders ? You said that the servodiffdrive doesn't read the encoders, but does it mean that they are unnecessary in this case ?
(this allow me to have more connexions.
thank you in advance.
Yes, the servodiffdrive library does not use or need the encoders, so you could remove them. You may need to experiment with drive levels to get the servos to go the same speed. For example, if drive_speeds(100, 100) makes the bot curve left slightly, try slowing down the right wheel with drive_speeds(100, 90).
A side note, mainly for others who might read this thread:
IMPORTANT: If you follow the manual servo calibration procedure in post #2, and then decide to go back to using abdrive, make sure to re-run the automatic calibration procedure on this page: http://learn.parallax.com/activitybot/calibrate-your-activitybot
