Propeller 1 in an 8 pin DIP
I've wanted for some time to package the prop into a minimal 8 pin DIP format, and finally got around to making it.
This is an oshpark 4 layer board with prop qfn and passives on one side, and regulator, eeprom and xtal on the other side. An 8 pin DIP socket header brings out breadboard friendly pins.
One of the pins is "tv out", using the standard 3 resistor dac. The prop plug connects on the other side, ie
This board has an outline about 0.8 x 0.55", but the "core" is about 0.6 x 0.45" . Thanks to Phil and Jmg for the xtal / txco part numbers.
_____ P30 --[o ]-- +5V P31 --[ ]-- SDA RES --[ ]-- SCL VSS --[_____]-- TV OUT
Way to push (shrink?) the envelope!
serial, I2C and tv. Hm.
Enjoy!
Very Cute.
Given the PCB is larger than DIP8, why not extend the 0.3" stitching to allow DIP14/DIP16 superset choices ?
@msrobots, the current application is driving a couple of ws2812b led strips (via the i/o on ends).
@jmg, yes I wanted to make sure the core is compact (~ 10mm square), then it can be extended out to 14/16/28 pins, and all the smd components may fit on one side then.
I think a 14 pin version with VGA output (or gpio) along one side, and P0~2 (usb / gpio) and prop plug on the other side would be a good DIP14 variant.
I'd like to think this would be a strong contender in the "ratio of 32 bit cores to pins" class (1 core per pin)
I am curious, what is its size and pn?
I going to get some of these 12MHz 3.2x2.5mm DFN/LCC4 CTX839CT-ND (Element 14 1842056) to try.
Its a Fox924 tcxo module, 10MHz (using PLL8x). SIze is 5x3.2mm.
You're right about the pinouts, you could make it fit in a DIP8 eeprom socket and share i2c (for one prop to boot another). You'd have to do something to make pin 3 (reset) edge triggered so the ground on pin 3 (normally an address pin) wouldn't hold it in reset.
Pins 4..1 make a nice propplug connection (on the top) and you have TV OUT (or a prop output pin with a series resistor).
Ok yes that would work, just use one of the grounds on the end for the permanent (non prop plug) power.
Another Oscillator module is the SiLabs Si504,
Available at Digikey, but getting one it is a little like joining a secret society.
Their stock says 0, but that just means it is special order-entry, ie you have to enter a frequency to get a part code, which you then order.
They DO have them in stock !
Rather a strange way to sell something, and I only found out after I emailed a query.
Most would look, see Zero and move on...
Comes in 2.5x2, 3.2 x 2.5 and 4 x 3.2mm, not quite as tightly spec'd as FOX924, but you buy a default frequency as any 32 bit real, and that is what it power up at, and then sending any other 32 bit real. sets a new Osc value.
With this, you could order 5.00MHz or 6.00MHz or any other value up to 100MHz
I did play with the Si570 a while back, on a dual prop board. They are nifty but you are right, I had to order through a ham operator group buy, from memory.
I did some more pcb layout as you suggested jmg, putting all the components onto one side of the board (ie vaguely manufacturable), and a "DIP18" worked about right. I've sent it off to oshpark so I don't waste any more time on it until making sure it fits together. Will post detail in a separate thread soon
I did get my Si504's from Digikey, the process was just a little unusual.
(oh and they miss-tagged 80MHz max as 100MHz, so I thought I was getting 100MHz, and when I asked for > 80MHz, it just looked at me. Turns out the SiLabs part code was actually 80MHz when I reversed the part ID.)
I think Digikey have the same price on all, so smartest to buy 100MHz / ±20ppm = best spec variant.
The Si570 I think is a higher spec again, and quote a bit more expensive.
