Losing my mind, assembly variable addresses updating wrong variable (Free Beer)
I've been wanting a high resolution Digital Oscillator set-up for my analog synthesizer project. using the two 32bit counters in each cog to generate ramp waves that is fed into my 24bit DAC.
I had it working in spin fine with MIDI input and 6 voices but the samplerate was far too slow ~8KHz so i re-worked it in assembly but passing the main hub ram addresses never seemed to align properly with cog ram.
I've been debugging this for days and have now started from scratch several times but in PASDebugger it shows for example:
-MOV Sum, #12
will place 12 into Waittime
what am i doing wrong, originally i wanted interaction with hub ram to a mixer routine and im pretty sure i did it correctly but now its stripped to just one cog ,2 oscillators, and output directly but it still wont get jump & variable locations correct. ARRGHHHHHHHHHH, pleease help. I'll post a six pack to your house if you can fix it.
-MOV Sum, #12
{32bit to 16bit dual oscillator cog} VAR long oscaddr long astep long bstep long bits PUB start(_resolution) astep := 50_000 bstep := 0 bits := _resolution oscaddr := @astep + (@bstep<<16) cognew(@entry, @oscaddr) PUB seta(_astep) astep := _astep PUB setb(_bstep) bstep := _bstep DAT org 0 entry begin rdlong Addr, par mov CTRA, Cntset 'reset counters mov CTRB, Cntset mov DIRA, Pinset mov Clktime, CNT waitcnt Clktime, Waittime mov Aadd, #2 'clear increase value on every clock mov Badd, #4 mov FRQA, #0 'clear increasers mov FRQB, #0 mov PHSA, #0 mov PHSB, #0 mov Aaddr, Addr mov Baddr, Addr and Aaddr, LSB shl Baddr, #16 mov Clktime, CNT waitcnt Clktime, Waittime startLoop mov Sum, #0 mov Bval, #0 rdlong Aadd, Aaddr cmp Preva, Aadd WZ if_z jmp #noChangeA mov Prev, Aadd mov FRQA, Aadd mov PHSA, #0 noChangeA rdlong Badd, Baddr cmp Prevb, Badd WZ if_z jmp #noChangeB mov Prevb, Badd mov FRQB, Badd mov PHSB, #0 noChangeB tjz Preva, #addB mov Sum, PHSA shr Sum, #16 addB tjz Prevb, #update mov Bval, PHSB shr Bval, #16 update add Sum, Bval shl Sum, #8 mov OUTA, Sum jmp #startLoop Addr long 0 Aaddr long 0 Baddr long 0 Aadd long 0 Badd long 0 Cntset long %0_00001_000_00000000_000000_000_000000 'cnt settings Pinset long $00FFFF00 'pins 31-0 Sum long 0 Bval long 0 Waittime long 10_000_000 Clktime long 0 Preva long 0 Prevb long 0 LSB long $0000FFFF MSB long $FFFF0000 fit
{16bit MIDI Synth Routine 20:01, 04/03/2014} CON _clkmode = xtal1 + pll16x 'gives 64 MHz _xinfreq = 4_000_000 '48KHz sample rate, 1250 cycles per sample SAMPLE_RATE = 32_000 'Hz DA_BITS = 8 'Resolution SAMPLE_DELAY = 64_000_000/SAMPLE_RATE doNoteOn = $00000001 doNoteOff = $00000002 doAftertouch = $00000004 doController = $00000008 doProgramChange = $00000010 doChannelPressure = $00000020 doPitchWheel = $00000040 doSysex = $00000100 doMTC = $00000200 doSongPosPtr = $00000400 doSongSelect = $00000800 doTuneRequest = $00001000 doMidiClock = $00002000 doMidiTick = $00004000 doMidiStart = $00008000 doMidiContinue = $00010000 doMidiStop = $00020000 doActiveSense = $00040000 doReset = $00080000 OBJ debug : "Parallax Serial Terminal" midi : "MidiIn" f : "Float32" osc : "AsmDualOsc" VAR long oscaddr long astep long bstep long midevent long midnote long Voice long Note[6] long buttonstack[32] PUB Main DIRA[0..1] := %11 DIRA[2..3] := %00 OUTA[0..1] := %10 'start w/red loading light debug.Start(115_200) 'start serial terminal cog f.start 'start floating point cog midi.start(2, doNoteOn+doNoteOff) 'start MIDI cog osc.start(16) waitcnt(4_000_000 + cnt) 'start oscillator cog cognew(ButtonDebug, @buttonstack) waitcnt(1_000_000 + cnt) OUTA[0..1] := %01 'ready Green Light debug.Str(STRING("16-bit Zynth all booted up")) debug.NewLine waitcnt(8_000_000 + cnt) '-------------------------------------Start Note Loop----------------------------- repeat midevent := midi.evt debug.Bin(midevent, 32) debug.NewLine midnote := midevent & $0000FF00 midevent &= $000000FF midnote >>= 8 If midevent>0 'If velocity > 0 then noteon 'Find next free voice if Voice == 1 Voice := 0 else Voice := 1 'calculate note frequency and update note value if (Voice == 0) 'step = 29527.90016 * 2^((note-69)/12) astep := f.FRound(f.FMul(29527.90016, f.Pow(2.0, f.FDiv(f.FSub(f.FFloat(midnote), 69.0), 12.0)))) osc.seta(astep) debug.Dec(midnote) debug.Str(STRING(", ")) debug.Dec(astep) debug.NewLine elseif (Voice == 1) bstep := f.FRound(f.FMul(29527.90016, f.Pow(2.0, f.FDiv(f.FSub(f.FFloat(midnote), 69.0), 12.0)))) osc.setb(bstep) Note[Voice] := midnote 'else ' Voice := 0 ' repeat while midnote<>Note[Voice] AND Voice<1 ' Voice += 1 ' Freq[Voice] := 0 ' Note[Voice] := 0 ' debug.NewLine 'fn = 2^(n/12)*440 Hz referenced from 440Hz where n = 69 PUB ButtonDebug | a , maxval DIRA[3] := 0 DIRA[4] := 1 OUTA[4] := 0 a := 0 OUTA[4] := 1 waitcnt(10_000_000 + cnt) maxval := 70_000_000 '1 ramp wave '2 square '3 triangle '4 sine repeat if INA[3] == 1 if a<10 a += 1 else if a>0 a -= 1 if a>9 OUTA[4] := 1 if (astep < maxval) astep += 67 'bstep += 150 debug.Str(STRING("Inc")) else astep := 0 osc.seta(astep) osc.setb(bstep) debug.Str(STRING("Step:")) debug.Dec(astep) debug.Str(STRING(" ,")) debug.Dec(bstep) debug.NewLine 'debug.Str(STRING("Freq 1:")) 'debug.Dec(Freq[1]) 'debug.NewLine a := 0 else OUTA[4] := 0 waitcnt(400000 + cnt)
After disabling the waitcnt sequences, fixing Baddr and using counter mode LOGIC.always (instead of PLL, personal preference) I get some activity which looks reasonable. No further address issues whatsoever.
But when I add the debugger to your first code block and test it, all seems to be okay. I can step through the code and the registers are at the right places.
If you step thru the ASM init code you will find that the address for Baddr is set wrong. You do a SHL Baddr,#16 while it should be a SHR Baddr,#16 to get the right address.
Andy
Thanks for the quick responses these forums are great so is the chip and so are you two. If you live in london I'll bring you the beer as promised.
I'll soon be able to post the rest of my zynthesizer. I'm just now working on the analogue parts and implementing wavetable and sine.
Gawd bless, Milo
