Propeller 1 in an 8 pin DIP — Parallax Forums
TubularTubular Posts: 4,745
edited 2014-03-05 22:55 in Propeller 1
I've wanted for some time to package the prop into a minimal 8 pin DIP format, and finally got around to making it.
This is an oshpark 4 layer board with prop qfn and passives on one side, and regulator, eeprom and xtal on the other side. An 8 pin DIP socket header brings out breadboard friendly pins.
One of the pins is "tv out", using the standard 3 resistor dac. The prop plug connects on the other side, ie
       _____
P30 --[o    ]-- +5V
P31 --[     ]-- SDA
RES --[     ]-- SCL
VSS --[_____]-- TV OUT
This board has an outline about 0.8 x 0.55", but the "core" is about 0.6 x 0.45" . Thanks to Phil and Jmg for the xtal / txco part numbers.
    edited 2014-03-03 17:11
    OK, that's pretty wild!
    Way to push (shrink?) the envelope!
    edited 2014-03-03 17:25
    Funny, but for what application?
    serial, I2C and tv. Hm.
    Enjoy!
  • jmgjmg Posts: 15,194
    edited 2014-03-03 17:37
    Tubular wrote: »
    Very Cute.
    Given the PCB is larger than DIP8, why not extend the 0.3" stitching to allow DIP14/DIP16 superset choices ?
  • TubularTubular Posts: 4,745
    edited 2014-03-03 17:50
    @mindrobots, it could go a bit smaller (0.45" wide), but I don't really want to risk sanding it while it works. Perhaps later!
    @msrobots, the current application is driving a couple of ws2812b led strips (via the i/o on ends).
    @jmg, yes I wanted to make sure the core is compact (~ 10mm square), then it can be extended out to 14/16/28 pins, and all the smd components may fit on one side then.
    I think a 14 pin version with VGA output (or gpio) along one side, and P0~2 (usb / gpio) and prop plug on the other side would be a good DIP14 variant.
    I'd like to think this would be a strong contender in the "ratio of 32 bit cores to pins" class (1 core per pin)
    edited 2014-03-04 18:25
    Very nice. If you change the pcb, you might consider placing the sda/scl/tv in the eeprom format ie tv to pin 7 (was wp) so that its similar to the standard 8 pin chips.
    P30 --[o    ]-- +5V
    P31 --[     ]-- TV OUT
    RES --[     ]-- SCL
    VSS --[_____]-- SDA
    edited 2014-03-04 22:01
    Presume you are using a 5MHz xtal?
    I am curious, what is its size and pn?
    I going to get some of these 12MHz 3.2x2.5mm DFN/LCC4 CTX839CT-ND (Element 14 1842056) to try.
    edited 2014-03-05 03:22
    Hi Ray
    Its a Fox924 tcxo module, 10MHz (using PLL8x). SIze is 5x3.2mm.
    You're right about the pinouts, you could make it fit in a DIP8 eeprom socket and share i2c (for one prop to boot another). You'd have to do something to make pin 3 (reset) edge triggered so the ground on pin 3 (normally an address pin) wouldn't hold it in reset.
    edited 2014-03-05 14:03
    Tubular wrote: »
    Hi Ray
    I was thinking more along the lines that you would only connect pins 4, 5, 6 & 8 (ie cut the others on the underside).
    Pins 4..1 make a nice propplug connection (on the top) and you have TV OUT (or a prop output pin with a series resistor).
    edited 2014-03-05 15:47
    Cluso99 wrote: »
    Ok yes that would work, just use one of the grounds on the end for the permanent (non prop plug) power.
    edited 2014-03-05 20:00
    Tubular wrote: »
    Another Oscillator module is the SiLabs Si504,
    Available at Digikey, but getting one it is a little like joining a secret society.
    Their stock says 0, but that just means it is special order-entry, ie you have to enter a frequency to get a part code, which you then order.
    They DO have them in stock !
    Rather a strange way to sell something, and I only found out after I emailed a query.
    Most would look, see Zero and move on...
    Comes in 2.5x2, 3.2 x 2.5 and 4 x 3.2mm, not quite as tightly spec'd as FOX924, but you buy a default frequency as any 32 bit real, and that is what it power up at, and then sending any other 32 bit real. sets a new Osc value.
    With this, you could order 5.00MHz or 6.00MHz or any other value up to 100MHz
    edited 2014-03-05 21:02
    Ok looks interesting.
    I did play with the Si570 a while back, on a dual prop board. They are nifty but you are right, I had to order through a ham operator group buy, from memory.
    I did some more pcb layout as you suggested jmg, putting all the components onto one side of the board (ie vaguely manufacturable), and a "DIP18" worked about right. I've sent it off to oshpark so I don't waste any more time on it until making sure it fits together. Will post detail in a separate thread soon
    Tubular wrote: »
    I did get my Si504's from Digikey, the process was just a little unusual.
    (oh and they miss-tagged 80MHz max as 100MHz, so I thought I was getting 100MHz, and when I asked for > 80MHz, it just looked at me. Turns out the SiLabs part code was actually 80MHz when I reversed the part ID.)
    I think Digikey have the same price on all, so smartest to buy 100MHz / ±20ppm = best spec variant.
    The Si570 I think is a higher spec again, and quote a bit more expensive.
