Help lcd issue 3 pin lcd
hi need help my code works on the BS2 but as soon as i load into the BS2sx the lcd does crazy stuff. help me please. here is my code.
' -----[ Title ]-----------------------------------------------------------
' Sonic Looper
' {$STAMP BS2}
' {$PBASIC 2.5}
' {$PORT COM10}
' -----[ Variables ]-------------------------------------------------------
time VAR Word ' Round trip echo time
LooperCnt VAR Byte ' Count of Loops
counter VAR Word ' Counter for FOR...NEXT loop
' -----[ Constants ]-------------------------------------------------------
maxDist CON 4000 ' Maximum distance for alarm trigger
' -----[ Jolly Roger Custom Characters ]-----------------------------------
SEROUT 8, 84, [248, 000, 000, 000, 100, ' Top left
110, 011, 001, 000] ' crossbone
SEROUT 8, 84, [249, 000, 001, 011, 110, ' Bottom left
100, 000, 000, 000] ' crossbone
SEROUT 8, 84, [250, 000, 110, 111, 111, ' Top half
101, 101, 111, 110] ' of skull
SEROUT 8, 84, [251, 110, 111, 111, 001, ' Bottom half
001, 111, 110, 000] ' of skull
SEROUT 8, 84, [252, 000, 011, 011, 110, ' Top right
110, 011, 011, 000] ' crossbone
SEROUT 8, 84, [253, 000, 011, 011, 110, ' Bottom right
' -----[ Initialization ]--------------------------------------------------
SEROUT 8, 84, [22,12] ' Initialize LCD
PAUSE 5
LooperCnt = 0 ' Reset Looper count to 0
' -----[ Main Routine ]----------------------------------------------------
DO
HIGH 4 ' Flash LEDs
PULSOUT 15, 5 ' Send pulse
PULSIN 15, 1, time ' Read echo time
IF (time < maxDist) THEN ' If Looper is triggered...
LooperCnt = LooperCnt + 1
SEROUT 8, 84, [128, 0, 129, 2, 130, 4, ' Display Jolly Roger
148, 1, 149, 3, 150, 5]
SEROUT 8, 84, [132, DEC LooperCnt, ' Display number of alarm
" Material "] ' triggers on the LCD
SEROUT 8, 84, [153, "Detected!! "]
FOR counter = 0 TO 0
HIGH 13 ' Flash LEDs
HIGH 12
PAUSE 600
LOW 13 ' Flash LEDs
LOW 12
NEXT
ELSEIF (LooperCnt = 0) THEN
SEROUT 8, 84, [133, "Looper",
153, "On!"]
SEROUT 8, 84, [141, 0, 142, 2, 143, 4, ' Display Jolly Roger
161, 1, 162, 3, 163, 5]
ENDIF
PAUSE 100
LOOP
Change the 84 to 240 or use code like this to handle various models
#SELECT $STAMP #CASE BS2, BS2E, BS2PE T2400 CON 396 T9600 CON 84 T19K2 CON 32 #CASE BS2SX, BS2P T2400 CON 1021 T9600 CON 240 T19K2 CON 110 #ENDSELECT LcdBaud CON T9600 SEROUT TX, LcdBaud, ["THE BASIC STAMP"]
