Help lcd issue 3 pin lcd — Parallax Forums
thomas.saddlerthomas.saddler Posts: 2
edited 2014-02-26 04:30 in General Discussion
hi need help my code works on the BS2 but as soon as i load into the BS2sx the lcd does crazy stuff. help me please. here is my code.
' -----[ Title ]-----------------------------------------------------------
' Sonic Looper
' {$STAMP BS2}
' {$PBASIC 2.5}
' {$PORT COM10}
' -----[ Variables ]-------------------------------------------------------
time         VAR   Word            ' Round trip echo time
LooperCnt    VAR   Byte            ' Count of Loops
counter      VAR   Word            ' Counter for FOR...NEXT loop
' -----[ Constants ]-------------------------------------------------------
maxDist      CON   4000            ' Maximum distance for alarm trigger
' -----[ Jolly Roger Custom Characters ]-----------------------------------
SEROUT 8, 84, [248, 000, 000, 000, 100,       ' Top left
                110, 011, 001, 000]            ' crossbone
SEROUT 8, 84, [249, 000, 001, 011, 110,       ' Bottom left
                100, 000, 000, 000]            ' crossbone
SEROUT 8, 84, [250, 000, 110, 111, 111,       ' Top half
                101, 101, 111, 110]            ' of skull
SEROUT 8, 84, [251, 110, 111, 111, 001,       ' Bottom half
               001, 111, 110, 000]             ' of skull
SEROUT 8, 84, [252, 000, 011, 011, 110,       ' Top right
                110, 011, 011, 000]            ' crossbone
SEROUT 8, 84, [253, 000, 011, 011, 110,       ' Bottom right
' -----[ Initialization ]--------------------------------------------------
SEROUT 8, 84, [22,12]             ' Initialize LCD
PAUSE 5
LooperCnt = 0                    ' Reset Looper count to 0
' -----[ Main Routine ]----------------------------------------------------
DO
  HIGH 4                                ' Flash LEDs
  PULSOUT 15, 5                              ' Send pulse
  PULSIN  15, 1, time                        ' Read echo time
  IF (time < maxDist) THEN                   ' If Looper is triggered...
    LooperCnt = LooperCnt + 1
    SEROUT 8, 84, [128, 0, 129, 2, 130, 4,  ' Display Jolly Roger
                    148, 1, 149, 3, 150, 5]
    SEROUT 8, 84, [132, DEC LooperCnt,    ' Display number of alarm
                    " Material "]            ' triggers on the LCD
    SEROUT 8, 84, [153, "Detected!! "]
    FOR counter = 0 TO 0
      HIGH 13                                ' Flash LEDs
      HIGH 12
      PAUSE 600
      LOW 13                                 ' Flash LEDs
      LOW 12
    NEXT
  ELSEIF (LooperCnt = 0) THEN
    SEROUT 8, 84, [133, "Looper",
                    153, "On!"]
    SEROUT 8, 84, [141, 0, 142, 2, 143, 4,  ' Display Jolly Roger
                    161, 1, 162, 3, 163, 5]
  ENDIF
  PAUSE 100
LOOP
    edited 2014-02-25 12:33
    The baud mode is different for the BS2sx (see page 423 of the manual).
    Change the 84 to 240 or use code like this to handle various models
    #SELECT $STAMP  #CASE BS2, BS2E, BS2PE
        T2400       CON     396
        T9600       CON     84
        T19K2       CON     32
      #CASE BS2SX, BS2P
        T2400       CON     1021
        T9600       CON     240
        T19K2       CON     110
    #ENDSELECT
    LcdBaud         CON     T9600
      SEROUT TX, LcdBaud, ["THE BASIC STAMP"]
  • thomas.saddlerthomas.saddler Posts: 2
    thank yo so much
