Can't get the coginit working!!
Having trouble to start different cog to do the function. Each method works fine by itself when call by the main routine. When do a "coginit(2, Brinking, @stack)", nothing is happening. Anyone interest in helping, I can send the entire source code.
CON
_clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz
_xinfreq = 5_000_000
InputPin_Left = 17
InputPin_Right = 18
LED1 = 1
LED2 = 2
LED3 = 3
LED4 = 4
LED5 = 5
LED6 = 6
LED7 = 7
LED8 = 8
VAR
Byte LEDOn ' No. of LED on
Byte LEDOn1 ' No. of LED on for brinking default
Long StackDefault[32] ' Stack workspace for cog 1
Long StackLeft[32] ' Stack workspace for cog 2
Long StackRight[32] ' Stack workspace for cog 3
byte Brinking_Type ' Current brinking type
byte Current_Input ' Current input
PUB Main
dira[LED1..LED8]~~ 'Set P1 thru P8 as outputs
dira[InputPin_Left..InputPin_Right]~ 'Set P17 & P18 as inputs
Brinking_Type := 0 'set switches to different values
repeat
if ina[InputPin_Left] == 1 'if P17 high
Current_Input := 2 'change the input switch to brink left
elseif ina[InputPin_Right] == 1 'if P18 high
Current_Input := 3 'change the input switch to brink right
else '
Current_Input := 1 'otherwise, change input switch to brink default
if Current_Input == Brinking_Type 'repeat same brinking fct if no change in input
else
Brinking_Type := Current_Input 'set the brink fct switch to same as input switch
Initialization 'stop previous brinking fct by stopping the cog
case Brinking_Type
1 : coginit(1, Brinking, @StackDefault) 'turn on cog1 for default brinking
2 : coginit(2, BrinkingLeft, @StackLeft) 'turn on cog2 for brinking left
3 : coginit(3, BrinkingRight, @StackRight) 'turb on cog3 for brinking right
Pri Initialization
outa[LED1..LED8]~
cogstop(1)
cogstop(2)
cogstop(3)
Pri Brinking
outa[LED1..LED8]~ 'turn off all LEDs
repeat 'set starting brink left LED
LEDOn := 5 'set starting brink right LED
LEDOn1 := 4 'repeat 4 times
repeat 4
LEDOn -=1
LEDOn1 +=1 'turn on LEDs
outa[LEDOn]~~
outa[LEDOn1]~~
waitcnt(clkfreq / 6 + cnt) 'wait for 1/6 of a second before turn on next LEDs
outa[LED1..LED8]~ 'turn off all the LEDs
waitcnt(clkfreq / 2 + cnt) 'wait 1/2 second, repeat brinking
Pri BrinkingLeft
outa[LED1..LED8]~
Repeat
LEDOn := 0
repeat 8
LEDOn += 1
outa[LEDOn]~~
outa[LED1..LED8]~
Pri BrinkingRight
outa[LED1..LED8]~
Repeat
LEDOn := 9
Repeat 8
LEDOn -=1
outa[LEDOn]~~
outa[LED1..LED8]~
Appreciate helping
CON
InputPin_Left = 17
InputPin_Right = 18
LED1 = 1
LED2 = 2
LED3 = 3
LED4 = 4
LED5 = 5
LED6 = 6
LED7 = 7
LED8 = 8
VAR
Byte LEDOn
Byte LEDOn1
Long StackLeft[32]
Long StackRight[32]
byte Brinking_Type
byte Current_Input
PUB Main
dira[LED1..LED8]~~
Brinking_Type := 0
repeat
Current_Input := 2
Current_Input := 3
else
Current_Input := 1
else
Initialization
case Brinking_Type
Pri Initialization
outa[LED1..LED8]~
cogstop(1)
cogstop(2)
cogstop(3)
Pri Brinking
outa[LED1..LED8]~
repeat
LEDOn := 5
LEDOn1 := 4
repeat 4
LEDOn -=1
LEDOn1 +=1
outa[LEDOn]~~
outa[LEDOn1]~~
outa[LED1..LED8]~
Pri BrinkingLeft
outa[LED1..LED8]~
Repeat
LEDOn := 0
repeat 8
LEDOn += 1
outa[LEDOn]~~
outa[LED1..LED8]~
Pri BrinkingRight
outa[LED1..LED8]~
Repeat
LEDOn := 9
Repeat 8
LEDOn -=1
outa[LEDOn]~~
outa[LED1..LED8]~
PUB Main
dira[LED1..LED8]~~
Brinking_Type := 0
repeat
Current_Input := 2
Current_Input := 3
else
Current_Input := 1
else
Initialization
case Brinking_Type
Pri Initialization
outa[LED1..LED8]~
cogstop(1)
cogstop(2)
cogstop(3)
That's the Main routine with proper indentation.
[ C O D E ]
some code here
[ / C O D E]
and leave all the spaces out of the code tags I provided as demo.
Enjoy!
'' '' File: SequentialBrinkingLED.spin '' Eight LED lights, 3 options of sequential brinking '' Default : 4 LEDs brink left and 4 LEDs brink right sequentially '' Switch left : 8 LEDs brink left sequentially '' Switch right : 8 LEDs brink right sequentially '' Default brinking frequency, 1 Hz, 1/2 second - clkfreq / 2 + cnt. '' cog 0 -- scan for input for blinking direction control '' cog 1 -- default brinking '' cog 2 -- brinking left '' cog 3 -- brinking right '' CON _clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz _xinfreq = 5_000_000 InputPin_Left = 17 InputPin_Right = 18 LED1 = 1 LED2 = 2 LED3 = 3 LED4 = 4 LED5 = 5 LED6 = 6 LED7 = 7 LED8 = 8 VAR Byte LEDOn ' No. of LED on Byte LEDOn1 ' No. of LED on for brinking default Long StackDefault[32] ' Stack workspace for cog 1 Long StackLeft[32] ' Stack workspace for cog 2 Long StackRight[32] ' Stack workspace for cog 3 byte Brinking_Type ' Current brinking type byte Current_Input ' Current input PUB Main dira[LED1..LED8]~~ 'Set P1 thru P8 as outputs dira[InputPin_Left..InputPin_Right]~ 'Set P17 & P18 as inputs Brinking_Type := 0 'set switches to different values repeat if ina[InputPin_Left] == 1 'if P17 high Current_Input := 2 'change the input switch to brink left elseif ina[InputPin_Right] == 1 'if P18 high Current_Input := 3 'change the input switch to brink right else ' Current_Input := 1 'otherwise, change input switch to brink default if Current_Input == Brinking_Type 'repeat same brinking fct if no change in input else Brinking_Type := Current_Input 'set the brink fct switch to same as input switch Initialization 'stop previous brinking fct by stopping the cog case Brinking_Type 1 : coginit(1, Brinking, @StackDefault) 'turn on cog1 for default brinking 2 : coginit(2, BrinkingLeft, @StackLeft) 'turn on cog2 for brinking left 3 : coginit(3, BrinkingRight, @StackRight) 'turb on cog3 for brinking right Pri Initialization outa[LED1..LED8]~ cogstop(1) cogstop(2) cogstop(3) Pri Brinking dira[LED1..LED8]~~ 'Set P1 thru P8 as outputs outa[LED1..LED8]~ 'turn off all LEDs repeat 'set starting brink left LED LEDOn := 5 'set starting brink right LED LEDOn1 := 4 'repeat 4 times repeat 4 LEDOn -=1 LEDOn1 +=1 'turn on LEDs outa[LEDOn]~~ outa[LEDOn1]~~ waitcnt(clkfreq / 6 + cnt) 'wait for 1/6 of a second before turn on next LEDs outa[LED1..LED8]~ 'turn off all the LEDs waitcnt(clkfreq / 2 + cnt) 'wait 1/2 second, repeat brinking Pri BrinkingLeft dira[LED1..LED8]~~ 'Set P1 thru P8 as outputs outa[LED1..LED8]~ Repeat LEDOn := 0 repeat 8 LEDOn += 1 outa[LEDOn]~~ waitcnt(clkfreq / 6 + cnt) outa[LED1..LED8]~ waitcnt(clkfreq / 2 + cnt) Pri BrinkingRight dira[LED1..LED8]~~ 'Set P1 thru P8 as outputs outa[LED1..LED8]~ Repeat LEDOn := 9 Repeat 8 LEDOn -=1 outa[LEDOn]~~ waitcnt(clkfreq / 6 + cnt) outa[LED1..LED8]~ waitcnt(clkfreq / 2 + cnt)I hope I did it correctly.
you set
in your main cog.
I think this is wrong.
outa[LED1..LED8]~ in Initialization is not needed, but does not harm either.
but the main problem is that all the lines after else need to be indented
NOT
if Current_Input == Brinking_Type 'repeat same brinking fct if no change in input else Brinking_Type := Current_Input 'set the brink fct switch to same as input switch Initialization 'stop previous brinking fct by stopping the cog case Brinking_Type 1 : coginit(1, Brinking, @StackDefault) 'turn on cog1 for default brinking 2 : coginit(2, BrinkingLeft, @StackLeft) 'turn on cog2 for brinking left 3 : coginit(3, BrinkingRight, @StackRight) 'turb on cog3 for brinking rightBUT
if Current_Input == Brinking_Type 'repeat same brinking fct if no change in input else Brinking_Type := Current_Input 'set the brink fct switch to same as input switch Initialization 'stop previous brinking fct by stopping the cog case Brinking_Type 1 : coginit(1, Brinking, @StackDefault) 'turn on cog1 for default brinking 2 : coginit(2, BrinkingLeft, @StackLeft) 'turn on cog2 for brinking left 3 : coginit(3, BrinkingRight, @StackRight) 'turb on cog3 for brinking rightEnjoy!
if you use coginit YOU are responsible for using the right cognumbers. If you use COGNEW the spin-interpreter will do that for you.
As long as a cog is available the CIGNEW-Command will start a cog and you NEVER have to worry about which cog-number to start or to stop.
to stop a cog you simply call the cogstop-command by calling the cogstop-command from the method that was used in the cognew-command
without worrying which cognumbers are used.
best regards
Stefan
