Can't get the coginit working!! — Parallax Forums
Uncle GeorgeUncle George Posts: 14
edited 2014-02-24 12:25 in Propeller 1
Having trouble to start different cog to do the function. Each method works fine by itself when call by the main routine. When do a "coginit(2, Brinking, @stack)", nothing is happening. Anyone interest in helping, I can send the entire source code.
    edited 2014-02-22 22:13
    Yes please.
  • Uncle GeorgeUncle George Posts: 14
    edited 2014-02-22 22:18
    Here is the source code.
    CON
    _clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz
    _xinfreq = 5_000_000
    InputPin_Left = 17
    InputPin_Right = 18
    LED1 = 1
    LED2 = 2
    LED3 = 3
    LED4 = 4
    LED5 = 5
    LED6 = 6
    LED7 = 7
    LED8 = 8
    VAR
    Byte LEDOn ' No. of LED on
    Byte LEDOn1 ' No. of LED on for brinking default
    Long StackDefault[32] ' Stack workspace for cog 1
    Long StackLeft[32] ' Stack workspace for cog 2
    Long StackRight[32] ' Stack workspace for cog 3
    byte Brinking_Type ' Current brinking type
    byte Current_Input ' Current input
    PUB Main
    dira[LED1..LED8]~~ 'Set P1 thru P8 as outputs
    dira[InputPin_Left..InputPin_Right]~ 'Set P17 & P18 as inputs
    Brinking_Type := 0 'set switches to different values
    repeat
    if ina[InputPin_Left] == 1 'if P17 high
    Current_Input := 2 'change the input switch to brink left
    elseif ina[InputPin_Right] == 1 'if P18 high
    Current_Input := 3 'change the input switch to brink right
    else '
    Current_Input := 1 'otherwise, change input switch to brink default
    if Current_Input == Brinking_Type 'repeat same brinking fct if no change in input
    else
    Brinking_Type := Current_Input 'set the brink fct switch to same as input switch
    Initialization 'stop previous brinking fct by stopping the cog
    case Brinking_Type
    1 : coginit(1, Brinking, @StackDefault) 'turn on cog1 for default brinking
    2 : coginit(2, BrinkingLeft, @StackLeft) 'turn on cog2 for brinking left
    3 : coginit(3, BrinkingRight, @StackRight) 'turb on cog3 for brinking right
    Pri Initialization
    outa[LED1..LED8]~
    cogstop(1)
    cogstop(2)
    cogstop(3)
    Pri Brinking
    outa[LED1..LED8]~ 'turn off all LEDs
    repeat 'set starting brink left LED
    LEDOn := 5 'set starting brink right LED
    LEDOn1 := 4 'repeat 4 times
    repeat 4
    LEDOn -=1
    LEDOn1 +=1 'turn on LEDs
    outa[LEDOn]~~
    outa[LEDOn1]~~
    waitcnt(clkfreq / 6 + cnt) 'wait for 1/6 of a second before turn on next LEDs
    outa[LED1..LED8]~ 'turn off all the LEDs
    waitcnt(clkfreq / 2 + cnt) 'wait 1/2 second, repeat brinking
    Pri BrinkingLeft
    outa[LED1..LED8]~
    Repeat
    LEDOn := 0
    repeat 8
    LEDOn += 1
    outa[LEDOn]~~
    outa[LED1..LED8]~
    Pri BrinkingRight
    outa[LED1..LED8]~
    Repeat
    LEDOn := 9
    Repeat 8
    LEDOn -=1
    outa[LEDOn]~~
    outa[LED1..LED8]~
    Appreciate helping
    edited 2014-02-22 22:19
    Please wrap your code in [noparse]
    [/noparse] tags.
    edited 2014-02-22 22:21
    Common mistake. Each cog has its own set of dira/outa registers. Meaning any method started in a new cog should handle dira itself. When you run those methods in the context of the primary cog they inherit its dira settings.
    edited 2014-02-22 22:23
    Did the copy and paste and didn't realize all the indentation are gone. Here is how the source code with proper indentations.
    CON
    InputPin_Left = 17
    InputPin_Right = 18
    LED1 = 1
    LED2 = 2
    LED3 = 3
    LED4 = 4
    LED5 = 5
    LED6 = 6
    LED7 = 7
    LED8 = 8
    VAR
    Byte LEDOn
    Byte LEDOn1
    Long StackLeft[32]
    Long StackRight[32]
    byte Brinking_Type
    byte Current_Input
    PUB Main
    dira[LED1..LED8]~~
    Brinking_Type := 0
    repeat
    Current_Input := 2
    Current_Input := 3
    else
    Current_Input := 1
    else
    Initialization
    case Brinking_Type
    Pri Initialization
    outa[LED1..LED8]~
    cogstop(1)
    cogstop(2)
    cogstop(3)
    Pri Brinking
    outa[LED1..LED8]~
    repeat
    LEDOn := 5
    LEDOn1 := 4
    repeat 4
    LEDOn -=1
    LEDOn1 +=1
    outa[LEDOn]~~
    outa[LEDOn1]~~
    outa[LED1..LED8]~
    Pri BrinkingLeft
    outa[LED1..LED8]~
    Repeat
    LEDOn := 0
    repeat 8
    LEDOn += 1
    outa[LEDOn]~~
    outa[LED1..LED8]~
    Pri BrinkingRight
    outa[LED1..LED8]~
    Repeat
    LEDOn := 9
    Repeat 8
    LEDOn -=1
    outa[LEDOn]~~
    outa[LED1..LED8]~
    edited 2014-02-22 22:31
    Did the same thing. The main routine is the following:
    PUB Main
    dira[LED1..LED8]~~
    Brinking_Type := 0
    repeat
    Current_Input := 2
    Current_Input := 3
    else
    Current_Input := 1
    else
    Initialization
    case Brinking_Type
    Pri Initialization
    outa[LED1..LED8]~
    cogstop(1)
    cogstop(2)
    cogstop(3)
    That's the Main routine with proper indentation.
    edited 2014-02-22 22:33
    Thanks for the code tags.
    edited 2014-02-22 22:35
    Thanks. I'll try the dira/outa registers for each of the cog.
    edited 2014-02-22 22:55
    How do you do the
    tags?
    edited 2014-02-22 22:59
    How do you do the
    tags?
    Just type them as listed and insert the code inbetween.
    ' some code follows
    edited 2014-02-22 23:07
    Type something like this
    [ C O D E ]
    some code here
    [ / C O D E]
    and leave all the spaces out of the code tags I provided as demo.
    Enjoy!
    edited 2014-02-22 23:14
    ''    File: SequentialBrinkingLED.spin
    ''    Eight LED lights, 3 options of sequential brinking
    ''    Default : 4 LEDs brink left and 4 LEDs brink right sequentially
    ''    Switch left : 8 LEDs brink left sequentially
    ''    Switch right : 8 LEDs brink right sequentially
    ''    Default brinking frequency, 1 Hz, 1/2 second - clkfreq / 2 + cnt.
    ''    cog 0 -- scan for input for blinking direction control
    ''    cog 1 -- default brinking
    ''    cog 2 -- brinking left
    ''    cog 3 -- brinking right
    CON
      InputPin_Left = 17
      InputPin_Right = 18
      LED1 = 1
      LED2 = 2
      LED3 = 3
      LED4 = 4
      LED5 = 5
      LED6 = 6
      LED7 = 7
      LED8 = 8
    VAR
    PUB Main
      repeat
        else                                                '
        else
        case Brinking_Type
    Pri Initialization
      outa[LED1..LED8]~
      cogstop(1)
      cogstop(2)
      cogstop(3)
    Pri Brinking
        repeat 4
          LEDOn -=1
          outa[LEDOn]~~
          outa[LEDOn1]~~
    Pri BrinkingLeft
      outa[LED1..LED8]~
      Repeat
        LEDOn := 0
        repeat 8
          LEDOn += 1
          outa[LEDOn]~~
        outa[LED1..LED8]~
    Pri BrinkingRight
      outa[LED1..LED8]~
      Repeat
        LEDOn := 9
        Repeat 8
          LEDOn -=1
          outa[LEDOn]~~
        outa[LED1..LED8]~
    I hope I did it correctly.
    edited 2014-02-23 03:11
    took me a while to figure this out.
    you set
    in your main cog.
    I think this is wrong.
    outa[LED1..LED8]~ in Initialization is not needed, but does not harm either.
    but the main problem is that all the lines after else need to be indented
    NOT
        else
        case Brinking_Type
    BUT
        else
          case Brinking_Type
    Enjoy!
    edited 2014-02-23 09:11
    Thanks Mike. Indentation is extremely important for logical blocks. Now, it works perfect. Great help. Thanks again.
    Hi George you should'nt use coginit but COGNEW.
    if you use coginit YOU are responsible for using the right cognumbers. If you use COGNEW the spin-interpreter will do that for you.
    As long as a cog is available the CIGNEW-Command will start a cog and you NEVER have to worry about which cog-number to start or to stop.
    to stop a cog you simply call the cogstop-command by calling the cogstop-command from the method that was used in the cognew-command
    without worrying which cognumbers are used.
    best regards
    Stefan
