HUB EXEC Update Here - Page 15 — Parallax Forums
11011121315
  • SapiehaSapieha Posts: 2,964
    edited 2014-02-21 05:20
    Hi Chip.
    Found 18 bits CRS function.
    Maybe it can help with made CRC for USB and more
      // 18-bit CRC polynomial calculator
      function    [17:0] crc18gen ;
        input    [ 9:0] i ;
        input    [17:0] c ;
      begin
        crc18gen[0]  = c[10] ;
        crc18gen[1]  = c[11] ;
        crc18gen[2]  = c[12] ;
        crc18gen[3]  = i[0] ^ c[0] ^ c[13] ;
        crc18gen[4]  = i[0] ^ i[1] ^ c[0] ^ c[1] ^ c[14] ;
        crc18gen[5]  = i[1] ^ i[2] ^ c[1] ^ c[2] ^ c[15] ;
        crc18gen[6]  = i[2] ^ i[3] ^ c[2] ^ c[3] ^ c[16] ;
        crc18gen[7]  = i[3] ^ i[4] ^ c[3] ^ c[4] ^ c[17] ;
        crc18gen[8]  = i[0] ^ i[4] ^ i[5] ^ c[0] ^ c[4] ^ c[5] ;
        crc18gen[9]  = i[1] ^ i[5] ^ i[6] ^ c[1] ^ c[5] ^ c[6] ;
        crc18gen[10] = i[2] ^ i[6] ^ i[7] ^ c[2] ^ c[6] ^ c[7] ;
        crc18gen[11] = i[3] ^ i[7] ^ i[8] ^ c[3] ^ c[7] ^ c[8] ;
        crc18gen[12] = i[4] ^ i[8] ^ i[9] ^ c[4] ^ c[8] ^ c[9] ;
        crc18gen[13] = i[5] ^ i[9] ^ c[5] ^ c[9] ;
        crc18gen[14] = i[6] ^ c[6] ;
        crc18gen[15] = i[7] ^ c[7] ;
        crc18gen[16] = i[8] ^ c[8] ;
        crc18gen[17] = i[9] ^ c[9] ;
      end
      endfunction
  • SeairthSeairth Posts: 2,474
    edited 2014-02-21 05:27
    JMPTASK currently only affects tasks' PCs. The tasks' Z/C flags are unchanged by JMPTASK.
    It seems that JMPTASK should at least set them to a known state. If you do hook it up to S[31:30], then the current usage will be the same as implicitly clearing the flags. Allowing JMPTASK to explicitly set those bits would also allow for simple 2-bit parameters to be passed to the task. For instance, an async continuation callback could use the C flag to indicate the success of an async request.
    edited 2014-02-21 05:34
    Seairth wrote: »
    I'll make JMPTASK affect the flags, too.
    Maybe what we really need is an instruction to swap Z/C/PC of any task with a register. That would take care of everything at once. The only rule would be: don't use REPS/REPD/TLOCK in the task that is going to be redirected.
    edited 2014-02-21 05:35
    Sapieha wrote: »
    Hi Chip.
        input    [ 9:0] i ;
        input    [17:0] c ;
      begin
      end
      endfunction
    Thanks for finding this, Sapieha.
    edited 2014-02-21 05:39
    Sapieha: What protocol uses crc18?
    edited 2014-02-21 05:43
    Hi Cluso.
    As You can read in 1 row of Code.
    Cluso99 wrote: »
    edited 2014-02-21 07:12
    Hi Chip.
    One more version with CRC 16
    // File:  CRC16.v
    //     Verilog module containing a synthesizable CRC function
    module CRC16(
             input    [ 7:0] D,
             output    [15:0] C
      // polynomial: (0 5 12 16)
      // data width: 8
      // convention: the first serial data bit is D[7]
      always @(D, C)
      begin
      end
     assign  C[0] = D[4] ^ D[0] ^ C[8] ^ C[12];
     assign  C[1] = D[5] ^ D[1] ^ C[9] ^ C[13];
     assign  C[2] = D[6] ^ D[2] ^ C[10] ^ C[14];
     assign  C[3] = D[7] ^ D[3] ^ C[11] ^ C[15];
     assign  C[4] = D[4] ^ C[12];
     assign  C[5] = D[5] ^ D[4] ^ D[0] ^ C[8] ^ C[12] ^ C[13];
     assign  C[6] = D[6] ^ D[5] ^ D[1] ^ C[9] ^ C[13] ^ C[14];
     assign  C[7] = D[7] ^ D[6] ^ D[2] ^ C[10] ^ C[14] ^ C[15];
     assign  C[8] = D[7] ^ D[3] ^ C[0] ^ C[11] ^ C[15];
     assign  C[9] = D[4] ^ C[1] ^ C[12];
     assign  C[10] = D[5] ^ C[2] ^ C[13];
     assign  C[11] = D[6] ^ C[3] ^ C[14];
     assign  C[12] = D[7] ^ D[4] ^ D[0] ^ C[4] ^ C[8] ^ C[12] ^ C[15];
     assign  C[13] = D[5] ^ D[1] ^ C[5] ^ C[9] ^ C[13];
     assign  C[14] = D[6] ^ D[2] ^ C[6] ^ C[10] ^ C[14];
     assign  C[15] = D[7] ^ D[3] ^ C[7] ^ C[11] ^ C[15];
    endmodule
  • jazzedjazzed Posts: 11,803
    edited 2014-02-21 07:17
    Which CRC-16 is that? There are a few different standards.
    edited 2014-02-21 07:32
    Hi jazzed.
    As You can read in code.
    // data width: 8
    jazzed wrote: »
    edited 2014-02-21 08:03
    So is it CCITT CRC16 or not?
    What is the result of CRC over this string "123456789" ?
    edited 2014-02-21 08:14
    edited 2014-02-21 08:33
    Hi Chip.
    On this site You can generate correct verilog else VHDL code for any of CRC needed for USB --- and much more
    http://www.easics.com/webtools/crctool
    Ps. this site have both protocols for USB 5 and 16 bits.
    Defined in firtst part by SET
    edited 2014-02-21 09:18
    Excellent find Sapieha!
    Sapieha wrote: »
    Hi Chip.
    edited 2014-02-21 11:07
    Do the LOCKxxx instructions still use the simple round-robin arbitration, or do they also benefit from the "work stealing" round-robin that's been added for hub memory?
    edited 2014-02-21 16:35
    Seairth wrote: »
    They are the same as Prop1, currently. And I'm not sure what you mean about the hub memory, but cogs are still only using their own hub cycles.
    edited 2014-02-21 18:25
    Oh! I thought cogs could now access hub memory more frequently than every 8 clocks. Never mind, then. I guess this means the 8-clock rule still applies for all hub resources.
    edited 2014-02-21 18:33
    So the hub sharing mode isn't going to be implemented? If not, that would be a shame.
    edited 2014-02-21 18:54
    Dave Hein wrote: »
    I just haven't gotten there yet.
  • evanhevanh Posts: 17,160
    edited 2014-02-21 19:04
    Breaking the 8-clock rule was always a big ask. There is a lot of shuffling already going on in that area and we've got such a lot of bandwidth available already. Be happy.
    edited 2014-02-21 19:28
    I suspect that feature is less important now that the WIDE instructions exist. If you do decide to implement it, take a look at my recent blog entry. I don't know if my approach works with your design, but you may find it helpful nonetheless.
    edited 2014-02-21 20:27
    evanh wrote: »
    If you get a chance you might want to try running some code under spinsim. It can show all of the wait cycles due to hub accesses, along with the unused cycles due to invalidated instructions after jumps. The use of delayed jumps will help to reduce the amount of invalidated instructions, but it might be difficult to consistently hit the hub slot with code that does a lot of random hub accesses. Hub sharing would be very useful for that kind of code.
    EDIT: If you try spinsim use the first version that I posted, which doesn't support the hub exec mode. It seems that the latest version is incorrectly generating hub waits for some instructions.
    edited 2014-02-21 20:32
    re:On this site You can generate correct verilog else VHDL code for any of CRC needed for USB --- and much more
    T
    he website was very slow to generate the code but it was fun to generate it in both Verilog and VHDl to compare them. :cool:
    edited 2014-02-21 20:56
    Hi
    Good PDF on CRC standards
    edited 2014-02-22 11:26
    ctwardell wrote: »
    Here are the connections for using a Prop Plug without the add-on board.
    C.W.
    Attachment not found.Attachment not found.
    Thanks for this, by the way! I finally got around to firing up the Feb 6 build! One additional note (which others may have already noted elsewhere): The RX/TX pins on the Prop Plug will plug in to the DE0 board directly. So without any additional wires, anyone with a DE0 and a Prop Plug can at least run the monitor. Just follow ctwardell's diagram for matching up the RX/TX pins. No need to plug in GND/RST.
    edited 2014-02-22 17:04
    Re: Feb 6 build
    I'm using:
    - DE0 Nano
    - add-on board.
    [FONT=Arial, Tahoma, Verdana, Geneva, sans-serif]- Prop Plug [/FONT]
    [FONT=Arial, Tahoma, Verdana, Geneva, sans-serif]Is their anything special required to get the monitor to work with this version?[/FONT]
    [FONT=Arial, Tahoma, Verdana, Geneva, sans-serif]Everything else seems to work but I don't get any response from the monitor. I remember that I had to remove the memory chip in a earlier version to get it to work but that's been corrected in this version .[/FONT]
    edited 2014-02-22 17:23
    Bob,
    I've got the same configuration. I never put my memory chip back in. I can try it with the chip later tonight to see if/how it works.
    edited 2014-02-22 18:05
    Rick,
    re:
    I haven't put the chip back in mine either, not yet.. Does it currently work with the chip out?
    edited 2014-02-22 18:34
    Rick,
    re:
    Hi Bob
    I have a DE0 with the latest build (feb 6) + add on board + prop plug and no flash chip installed.
    Monitor works fine with PST from 600 baud to 460800 baud. :)
    Cheers
    Brian
    edited 2014-02-22 18:51
    Hi Brian,
    re:
    Ok great!! that's what I needed to know. I'll check the monitor code to see if the pin setup changed.
    Bob
    edited 2014-02-22 19:28
    Hi Brian,
    re:
    Bob
    There may be a bug in the monitor on the last release. It doesn't process hex that you type. It's something trivial, I'm sure, and the next release will have it fixed. The monitor DOES come up, though.
