Jumbled Code Posts on Forum in Chrome Browser — Parallax Forums
artkennedyartkennedy Posts: 174
edited 2014-02-17 14:43 in General Discussion
Can anyone tell me why I'm seeing this when reading posts on the Forum that contain Code examples? I'm using the Chrome Browser under Windows 7.
    edited 2014-02-15 14:58
    It looks like an issue with the Parallax font. Try deleting and reinstalling it.
    edited 2014-02-15 15:04
    Nothing to do with the Parallax font. I don't think I have ever installed it on any machine I use. I have not seen this problem before though,
    Does this happen all the time or is there a specific example you can point us at?
  • trookstrooks Posts: 228
    edited 2014-02-15 15:17
    Loose the chrome.
    Their browser returns 100s of 1000s of results from the same search that returned 60+ results using MS IE in private mode.
    MS IE warns me of unsafe sites and lets none change a single thing on my computer. I go to those same sites using Gaggle and hear not a peep.
    I can go to the same sites with MS IE and Goggle and get a different front page depending on the browser I am using.
    Tim
    edited 2014-02-15 15:28
    Then how would you know it's not a font issue? The font displayed in the top post is definitely the Parallax font and shows symptoms I've seen with it in other contexts.
    edited 2014-02-15 15:31
    trooks,
    Fascinating, I have no such problems.
    Could you pleas post such a search and links to examples of pages that are "unsafe" or different on IE.
    Of course many things will be different on IE given that unless it is a very new version it does not support a lot of nice HTM5 features.
    Web pages were never intended to be rendered exactly the same on all browsers anyway.
    If a site checks your browser type and serves up different stuff that is hardly the browsers fault.
    And what has any of this got to do with the problem in hand?
    edited 2014-02-15 15:35
    aPhil,
    It clearly is a font issue. Or possibly an encoding issue.
    My claim is that it's nothing to do with installing the Parallax font on your machine. Simply because I have never done so and I don't see that problem.
    Edit: Ah I see what you mean, the Parallax font may be installed and used but is somehow corrupt. In that case removing it would be a good experiment.
  • fengfeng Posts: 39
    edited 2014-02-15 15:36
    This has been discussed before. Adjust the zoom level (Ctrl+mousewheel).
    Doesn’t solve the browser problem but make the text readable.
    edited 2014-02-15 15:53
    It absolutely is the font. This will also happen with some other fonts that do not have as many hints in them causing poor / jumbled rendering at some point sizes and not others.
    As feng mentioned, adjusting the view size with either the [ctrl+mousewheel], or [ctrl and + -] keys will help you find screen display sizes that render properly.
    edited 2014-02-15 15:57
    Can somebody point me at an example?
    I have never seen this happen at any font size. Well, perhaps it does happen when the size is so small I would not expect to be able to read it anyway.
  • KMyersKMyers Posts: 433
    edited 2014-02-15 16:04
    @Heater I create this by zooming to anything OVER 125%. 125 displays fine any over that and its strange. Of course I am on win 7.
    edited 2014-02-15 16:08
    Still would like an example link though.
    edited 2014-02-15 16:11
    Heater. wrote: »
    I use Firefox and see the same jumble fairly often.
    edited 2014-02-15 16:35
    So I had to make my own "test card" out of all the characters in the Parallax font. Made in the Propeller Tool on Windows 7.
    [code]ABCDEFGHIJKLMNOPQRSTUVWXYZ
    abcdefghijklmnopqrstuvwxyz
    edited 2014-02-15 16:58
    Well what do you know. The "test card" posted above does indeed get jumbled.
    On Windows 7 in Chrome 32 at anything over 250%.
    Hardly an issue as that is already too huge to be required normally.
    All my other browsers on Windows and Debian are just fine at all zoom levels.
    I have no Parallax font installed so I get square boxes for the 10th and 12th rows. The schematic symbols, lines and such.
    Recommend a switch from Win to Debian.
    edited 2014-02-15 17:24
    I get this on XP also when zooming over %125 using Chrome
    edited 2014-02-15 18:02
    Heater if you are talking about the text you posted in #14 I am able to zoom in to the max 400% using Win7 and I.E.11 and it looks ok.
    edited 2014-02-15 19:44
    Yes I meant the font example in the post above. I should have listed my browsers when I said "all":
    FireFox on Win 7 and Debian.
    Chrome on Win 7 and Debian.
    IE 11 on Win 7
    Only Chrome on Win 7 has the problem.
    The old XP box here is feeling very sick. Takes about ten minutes to load a forum page. No idea why it's on the same network. I gave up with it.
    One should up grade to Debian just to be on the safe side though :)
    edited 2014-02-15 21:03
    In my previous post I should have mentioned that I am using Firefox on Win7 and occasionally see the same type of jumble.
    Heater. wrote: »
    IE 11 on Win 7
  • jazzedjazzed Posts: 11,803
    edited 2014-02-15 21:08
    LOL
    I get the same problem for different zoom levels in Chrome on Windows. Using Chromium on Linux usually fails in other disastrous ways.
    edited 2014-02-16 04:17
    Jazzed,
    Curious as ever, what disastrous ways does Chrome fail on Linux?
    Any links to examples?
    I have two Chrome issues bugging be at the moment:
    1) That pesky memory leaking in openspin.js
    2) webgl is terrible slow. Not usually a problem but on this old AMD64 with integrated graphics it's very sluggish and worst of all jerky.
    edited 2014-02-16 06:59
    Looks like he is referring to one of my posts here, but I can't seem to make it display like that on Win7 Chrome or Linux Mint 16 Chrome etc.
    edited 2014-02-16 09:13
    Had to bug out last night and didnt reply any further. Was thinking about this some more which can be dangerous. It seams that this also happens mostly in code copied and pasted with the code start and end tags. I dont remermber seeing this with out the tags.. Never see this on Firefox. Also have not seen this on other websites but I could be wrong about this!
    Heater I have thought about changing to Debian but not comfortable in doing so. Also not liking the cryptic command line as I have been dumbed down by windows. Was thinking also about Cygwin but at its heart its still windows. Debian at this time is beyond my skill level.
    edited 2014-02-16 09:43
    KMyers wrote: »
    Don't bother with Cygwin ... it's horrible. Just use VirtualBox (free) to make a Virtual Machine "VM" and install linux there. Then you can test that. There are some very good window managers for Linux these days. Mint or Ubuntu are good examples. If you don't like anything, you can simply remove the VM(s) and uninstall VirtualBox.
    edited 2014-02-16 10:18
    Thanks Jazzed will look into that as I am fed up with windows...
    edited 2014-02-16 11:38
    Kmyers,
    I agree with Jazzed. Cygwin has it's uses but what you get is all the crypticness of the Unix command line and all the weirdness of Windows.
    Firing up Debian or Mint or whatever in Virtual Box is a much nicer idea.
    Don't be afraid of the command line. It's a lot to learn for sure but you will be happy you did.
    edited 2014-02-16 11:49
    Heater,
    I think I agree about Cygwin. Every time I re read the Wiki pages on it I feel less confident about it. I tried the Raspberry Pi to try Debian and had some success but needed something more to get comfortable with it. Had no issues with CPM back in the S100 days. Now command line intimidates me!!
    edited 2014-02-16 12:36
    KMyers,
    OK, now we are talking!
    If you could handle CP/M you can handle a Linux shell. It's a lot bigger with a lot more features in the shell and a lot more commands available. It's all good stuff that you will appreciate after a you gain a little mastery.
    edited 2014-02-16 13:57
    Jazzed and Heater...
    Well took my first step at leaving windows, I downloaded VirtualBox. Will read more on Wiki before I install it tomorrow. I had been under the impression it was only for Mac's to run windows for heavens sake. Wish me luck!
    Back to topic at hand and sorry for hijacking this thread. I went to MicroElectronica forum to look at code snippets with my existing Chrome. Looked at several listing with different levels of zoom. They ALL displayed fine! Not conclusive I know but what do you all think?
    edited 2014-02-16 14:24
    KMyers wrote: »
    Hi Ken, most distros allow you to do a live boot and then if you want you can install Linux so that it boots into Linux or Windows. I normally manually repartition the drive for this. Although I use VirtualBox to run WINXP in Linux, I can't see the advantage of running Linux in VirtualBox in Windows, it's still sitting on a flimsy and bloated platform.
    My personal preference is for Linux Mint running Cinnamon desktop but the good thing about these distros is that you can have more than one to boot into plus each one can have different desktop managers to log into.
    edited 2014-02-16 14:33
    Thanks Peter!
    I am conservative here so it will be baby steps. As I said I played with th RasPi and had some sucess with it but the cryptic nature of command line sti;; concerns me!
