CatWave interactive art installation — Parallax Forums
mparkmpark Posts: 1,322
edited 2014-02-12 22:43 in Propeller 1
I helped an artist build an interactive art piece. Under the covers there's a Propeller, a couple of X-band motion sensors, and a bunch o' servos. Check out the video:
https://vimeo.com/82151118
Edit: Press release
    edited 2013-12-17 20:58
    Hey Michael,
    That's something I might visit Seattle just to see! :)
    edited 2013-12-17 22:02
    Very nice project.
    edited 2013-12-18 00:13
    Very cool.
    Thanks for posting the link to the video. It was fun to watch.
  • HughHugh Posts: 362
    edited 2013-12-18 00:58
    Cool!
    If you had a couple of hundred of those, a cat-wave transmitter and a cat-wave receiver you would be able to send information over cat-wave - one of the lesser-known, but most significant, constituents to the sub-ethernet communications so beloved of sci-fi writers...
  • mparkmpark Posts: 1,322
    edited 2013-12-18 08:35
    Phil, you totally should (let me know if you're coming)!
    Glad you all enjoyed the video. I updated the top post with a link to the press release. It was a fun project to work on. Unfortunately I couldn't get the x-band sensors to work reliably, so sometimes you have to stand in front of the window and jump around until the cats deign to acknowledge your existence. I suppose it's more realistic that way.
    edited 2013-12-18 09:23
    How do the cats react to a red laser pointer? :)
    edited 2013-12-18 10:55
    @ Michael, Nice!
    @ Phil
    LOL
    If I remember, Browser did not react to the red dot? My Mom's cat just yawns at it.
  • John KauffmanJohn Kauffman Posts: 653
    edited 2014-02-12 12:27
    Is it one cog per cat? If 8 cats then wouldn't you need 1 cog for main, leaving only 7? I know it is not hard to run >1 servo per cog, but just curious.
    Was the sound part of install or added to video? Controlled by Prop?
    Would be cool to have each cat on a platform servo so could rotate to greet neighbor cat.
    edited 2014-02-12 13:51
    Publison,
    Amazing. That's the first such report I ever heard.
    I discovered the miracle of exercising a cat with a laser when I built a laser using a helium-neon tube back in the 1980's.
    Since then I have never met a cat that would not chase that red dot to exhaustion.
    (Well, not the same red dot of course, sadly that tube laser is long since expired)
    edited 2014-02-12 15:07
    Heater. wrote: »
    I'm sorry to hear your cat exhausted your laser to the point of expiring.
    Ha! You are right Duane, the cat outlived that laser.
    I built the laser from a kit from Maplin Electronics in England. So that I could make some white light viewable holograms. Anyway, it was a very good kit except the mains transformer was under specified and many of them overheated and failed. For a while I ran it with a rather dangerously connected external transformer.
    Those tubes loose their helium quite quickly anyway.
    We are so spoiled to have all those cheap solid state lasers now a days. But I haven't heard so much about people making holograms at home recently.
