CatWave interactive art installation
I helped an artist build an interactive art piece. Under the covers there's a Propeller, a couple of X-band motion sensors, and a bunch o' servos. Check out the video:
https://vimeo.com/82151118
Edit: Press release
Edit: Press release
That's something I might visit Seattle just to see!
Thanks for posting the link to the video. It was fun to watch.
If you had a couple of hundred of those, a cat-wave transmitter and a cat-wave receiver you would be able to send information over cat-wave - one of the lesser-known, but most significant, constituents to the sub-ethernet communications so beloved of sci-fi writers...
Glad you all enjoyed the video. I updated the top post with a link to the press release. It was a fun project to work on. Unfortunately I couldn't get the x-band sensors to work reliably, so sometimes you have to stand in front of the window and jump around until the cats deign to acknowledge your existence. I suppose it's more realistic that way.
@ Phil
LOL
If I remember, Browser did not react to the red dot? My Mom's cat just yawns at it.
Was the sound part of install or added to video? Controlled by Prop?
Would be cool to have each cat on a platform servo so could rotate to greet neighbor cat.
I discovered the miracle of exercising a cat with a laser when I built a laser using a helium-neon tube back in the 1980's.
Since then I have never met a cat that would not chase that red dot to exhaustion.
(Well, not the same red dot of course, sadly that tube laser is long since expired)
I'm sorry to hear your cat exhausted your laser to the point of expiring.
I built the laser from a kit from Maplin Electronics in England. So that I could make some white light viewable holograms. Anyway, it was a very good kit except the mains transformer was under specified and many of them overheated and failed. For a while I ran it with a rather dangerously connected external transformer.
Those tubes loose their helium quite quickly anyway.
We are so spoiled to have all those cheap solid state lasers now a days. But I haven't heard so much about people making holograms at home recently.
