control a brushed motor? — Parallax Forums
johnprokojohnproko Posts: 121
edited 2014-02-10 08:59 in General Discussion
Hello everyone. i have a question. im trying to build a rc car that is going to be operated by a bs2, and hopefully later from a propeller multicore.
the problem is when i try to plug in the bushed motor it starts spinning even though there is no command like pulsout, high. is there a way to control it by default or do i need an esc (electonic speed controller)
thank you
p.s. i think that i have already answered my question but i need a second opinion.
    edited 2014-02-10 04:23
    It would be helpful to know how you connected it up.
  • johnprokojohnproko Posts: 121
    edited 2014-02-10 04:49
    1) directly from a pin and to ground
    2) pin, power going to + and from - to ground
  • Mark_TMark_T Posts: 1,981
    edited 2014-02-10 05:08
    You cannot power a motor from a microcontroller, period, you must use a motor driver circuit that can handle the
    voltage and the high currents. Without knowing what the motor is there's not much more to say.
    edited 2014-02-10 05:16
    Judging from the likely scale of the project an Ld298 might work well. Find a complete board kit
    www.micronauts.com may have that with a Propeller on the same board for sumobots
  • JonnyMacJonnyMac Posts: 9,709
    You'll want to move to the Propeller sooner than later. With the BS2, you probably won't be able to achieve clean speed control of the motor -- just simple on and off. With the Propeller, speed control fairly easy. As George points out, an H-Bridge needed in either case.
