Parallax CR servo speed modifications?
Hello, I am new here.
I joined because I have been using parallax CR servos in my combat robot projects. I was wondering if it was possible to change the gearing of the servo to upgrade the "zippyness factor" of my robot. Poor thing would be slaughtered at its current speed, and I really don't have any way to obtain high speed servos. So, can you chaps help me? The robot is an antweight-class combat machine, it uses dual stick "tank drive" systems for steering.
The short answer is no there isn't a way to change the speed of the servo. You can't change the gears around in the servo and still have them fit in the gearbox. You could add gears outside the servo's gearbox to increase the speed at the cost of lower torque. If you used a largish gear where the wheel normally connected to the servo and had the large gear drive a small gear on the wheel, then the wheel should spin faster. You might be able to do this with Lego gears. Here's a picture of a gear I added to a servo.
The gear attached to the wheel needs to be smaller than the gear attached to the servo in order to increase the speed of the wheel.
Parallax sells new "high speed" servos. It's a much easier way to increase the speed of your robot than adding gears.
What's next?
