Quickstart board Vin current rating
skylight
Tried to look up the specs myself but downloads are in a strange .odt format which I can't open?
I'm trying to find out the maximum current draw that the tracks on the quickstart can cope with when drawing current from the Vin pin.
It's Open Office format. Free download:
https://www.openoffice.org/
David Carrier
Parallax Inc.
Thanks Publison I wasn't aware it was an open office format, unfortunately I have installed it before but had a lot of trouble on my XP machine so uninstalled it but thanks anyway.
Just read the pdf file but it doesn't state how much current, looking at the tracks I don't think it would be much but are we talking at least an amp?
I've been driving these led strips using a 10A PSU using a quickstart protoboard, which feeds power down to the quickstart main board (via the Vin pin on the header), but only at a few hundred mA or whatever the Prop itself needs. Are you trying to run something hefty via the USB lead as a power supply?
under Specifications
Iin rev a - 80 Mhz all cogs running = 11 ma
Iin rev b - 80 Mhz all cogs running = 9.8 ma
