Quickstart board Vin current rating — Parallax Forums
skylightskylight Posts: 1,915
edited 2014-01-31 19:18 in Propeller 1
Tried to look up the specs myself but downloads are in a strange .odt format which I can't open?
I'm trying to find out the maximum current draw that the tracks on the quickstart can cope with when drawing current from the Vin pin.
    edited 2014-01-03 10:31
    skylight wrote: »
    It's Open Office format. Free download:
    https://www.openoffice.org/
  • David CarrierDavid Carrier Posts: 294
    edited 2014-01-03 13:18
    There should be a PDF copy on the product page, but it is missing. I checked our internal network, and we have the file, so I'll let our web department know it is missing, and they'll get it up soon. Until then, I've attached a copy.
    — David Carrier
    Parallax Inc.
    edited 2014-01-03 14:03
    Thank you kindly David
    Thanks Publison I wasn't aware it was an open office format, unfortunately I have installed it before but had a lot of trouble on my XP machine so uninstalled it but thanks anyway.
    Just read the pdf file but it doesn't state how much current, looking at the tracks I don't think it would be much but are we talking at least an amp?
  • TubularTubular Posts: 4,771
    edited 2014-01-05 17:59
    Skylight, what are you trying to do exactly? Are you talking about the Vin pin on the 40 way header, or somewhere else?
    I've been driving these led strips using a 10A PSU using a quickstart protoboard, which feeds power down to the quickstart main board (via the Vin pin on the header), but only at a few hundred mA or whatever the Prop itself needs. Are you trying to run something hefty via the USB lead as a power supply?
  • MegamouseMegamouse Posts: 3
    edited 2014-01-31 18:38
    I've got the same question, if anybody has any ideas. I thought it would be really nice to be able to power some small 5V things with the Vin pin on the header when powering the board with USB. I was thinking up to a few hundred mA shouldn't hurt anything, but would like to hear to from someone with more QuickStart experience before I try it.
  • cavelambcavelamb Posts: 724
    refer to the last page of the Quickstart pdf...
    under Specifications
    Iin rev a - 80 Mhz all cogs running = 11 ma
    Iin rev b - 80 Mhz all cogs running = 9.8 ma
