A Discovery about finding the answer immediately after posting to the Forum
A strange phenom some may have experienced is that you can be stumped on a problem for many hours, but within minutes of posting the question to the forum... you get the answer from out of no where. I have now found out that even the act of starting to post the question, and leaving the post in the screen for a few minutes WITHOUT submitting can accomplish the same thing. Very strange. I was about to post a question and got the answer, and meant to put this in general.
Maybe the Forums are morphing into the Borg Collective...
If you get an email or some other communication from an external source while still working on your post, well, then we're back to the "collective" theory!
And how my colleagues hate it when I use them as rubber ducks. Call them away from their work and spend 20 minutes explaining to them a problem that they don't understand and aren't much interested in only to end up with "Ah...err...never mind, my fault...thanks anyway".
When I have a problem, BEFORE posting I usually search the forum if this problem was already known. However, the serach function is very bad or somehow I don't understand how to use it correctly. Ok... I don't find anything useful and post a question. AFTER that, I see a "similar threads"-list displayed below my post, generated by the forum software. And you can guess what I often find there: Some thread about the exact same problem.:blank:
You may have better luck searching the forums with Google: just enter "site:forums.parallax.com thing I want to find" into the search box.
@Heater,
You might have a typo in there. I believe it's
You think you understand a topic - maybe you do. You try explaining a topic to someone else, you'll quickly find out if you really
understand it!
If you have a question, probably 100 other folks do too
You can't get it if you don't ask for it clearly (or you get the monkey's paw)
You don't REALLY know it until you explain it to somebody else.
When somebody does "rubber duck debugging" at you , look them in the eye and say nothing. When they get to the point where they stop and look puzzled, repeat (one key word) form the topic immediately before. Often their eyes go funny and they walk away babbling, and come back later to say how brilliant the suggestion was.
