Getting into Propeller from the Arduino
Hi, Guys,
I work mostly with Arduinos and even SX micro-controllers in the past. I am looking at getting into the Propeller but I have some questions, which I hope you guys could help with:
1. I want my chips to be standalone in my projects. But I only see surface mounted versions. Is the not a verson for DIP chips? I know they sell DIP chips, but I cannot find the programmer?
2. I use a Mac, is the MAC supported and does it use USB?
3. Can you use Propellers in big commerical projects?
Cameron.
Cameron.
You'll also want to get some EEPROMs to store the Prop's programs.
There are a bunch of links to tutorials in post #3 of my index (see signature). The Propeller Education Kit (PEK) pdf has instructions on how to program a Prop with a Prop Plug.
There are several ways to program a Prop with a Mac. Brad's Spin Tool (BST) in one of them.
Absolutely and they are.
While I initially used DIP Props in my home made boards, I found soldering the SMT chips (the ones with leads) not so hard. I rarely use DIPs now.
I do, and so do a lot of others. Legoland just selected the EFX-TEK HC-8+ controller and AP-16+ audio player (both Propeller powered) for animation controls they build for their parks and other Lego displays around the world. I helped several people with code and circuit assistance for commercial projects that use the Propeller.
http://www.parallax.com/product/32305
Also, the Propeller doesn't have a built in EEPROM? What about code storage? Does that get stored on the chip or an external flash chip or EEPROM?
Cameron.
Yes, I think that kit has everything to get you up and running.
No internal EEPROM. I'm not sure if the Prop can boot from anything but EEPROM (or code being loaded from PC).
External EEPROM connected to pins 28 and 29; 32K; device address %000.
In most of my designs I use 64K which gives me 32K of program space and 32K of non-volatile storage that is left untouched during reprogramming.
The DIY is an RS232 to Propeller affair.
I have another question, in reference to http://parallax.com/product/32305
Why does the kit come with a 5Mhz crystal? Doesn't the chip run at 80Mhz? I know you can run chips at slower speeds, but why would you want something so slow at 5Mhz. Even the Arduino runs at 16Mhz
Also, does the Propeller have a bootloader? Or does the language convert to 100% ASM and writes direct to the chip?
Cameron.
Regarding the question of a boot loader, I would say yes But.
The Propeller has a Spin interpreter internally that loads both Spin code to be interpreted as required and/or PASM assembler binaries in a 32K image. A traditional bootloader doesn't not include an interpreter for a specific tokenized language.
The Propeller requires a 32K EEPROM to be availabe for the SPIN and PASM to be loaded. The ROM within the Propeller hold the Spin Interpreter, a Log Table, a Character set for video, a Sine Table, and the resident Boot Loader services.
Welcome!
I just loaded the latest SimpleIDE onto my Mac and it compiles Spin/PASM programs just fine. SimpleIDE will also let you use C/C++ with the propeller which may ease your transition from the Arduino.
The Parallax Learn site also has some great tutorials to help you with SimpleIDE and C (you should breeze through these just noting the difference between Arduino and the Propeller)
The Propeller Education Kit is great for learning about the Propeller and has a great manual. It is targeted and breadboarding and circuit building. You may also want to check out the Propeller Activity Board or the Propeller Board of Education - they are also great for learning and also the SimpleIDE tutorials address features they have.
