Getting into Propeller from the Arduino — Parallax Forums
c.asmithc.asmith Posts: 15
edited 2014-01-23 13:35 in Propeller 1
Hi, Guys,
I work mostly with Arduinos and even SX micro-controllers in the past. I am looking at getting into the Propeller but I have some questions, which I hope you guys could help with:
1. I want my chips to be standalone in my projects. But I only see surface mounted versions. Is the not a verson for DIP chips? I know they sell DIP chips, but I cannot find the programmer?
2. I use a Mac, is the MAC supported and does it use USB?
3. Can you use Propellers in big commerical projects?
Cameron.
    edited 2014-01-22 11:19
    c.asmith wrote: »
    Hi, Guys,
    The Prop Plug can be used to program a Propeller chip DIP or otherwise.
    You'll also want to get some EEPROMs to store the Prop's programs.
    There are a bunch of links to tutorials in post #3 of my index (see signature). The Propeller Education Kit (PEK) pdf has instructions on how to program a Prop with a Prop Plug.
    c.asmith wrote: »
    There are several ways to program a Prop with a Mac. Brad's Spin Tool (BST) in one of them.
    c.asmith wrote: »
    Absolutely and they are.
    While I initially used DIP Props in my home made boards, I found soldering the SMT chips (the ones with leads) not so hard. I rarely use DIPs now.
  • JonnyMacJonnyMac Posts: 9,674
    edited 2014-01-22 11:27
    I do, and so do a lot of others. Legoland just selected the EFX-TEK HC-8+ controller and AP-16+ audio player (both Propeller powered) for animation controls they build for their parks and other Lego displays around the world. I helped several people with code and circuit assistance for commercial projects that use the Propeller.
  • c.asmithc.asmith Posts: 15
    edited 2014-01-22 11:32
    So, this might be an option then huh?
    http://www.parallax.com/product/32305
    Also, the Propeller doesn't have a built in EEPROM? What about code storage? Does that get stored on the chip or an external flash chip or EEPROM?
    Cameron.
    edited 2014-01-22 12:30
    c.asmith wrote: »
    Yes, I think that kit has everything to get you up and running.
    c.asmith wrote: »
    No internal EEPROM. I'm not sure if the Prop can boot from anything but EEPROM (or code being loaded from PC).
    edited 2014-01-22 15:16
    External EEPROM connected to pins 28 and 29; 32K; device address %000.
    In most of my designs I use 64K which gives me 32K of program space and 32K of non-volatile storage that is left untouched during reprogramming.
  • hacktorioushacktorious Posts: 72
    edited 2014-01-22 15:30
    I use a Mac with SimpleIDE for programming my propeller. However, I prefer C over spin.
    edited 2014-01-23 02:32
    You can actually build your own programming interface or buy a PropPlug.
    The DIY is an RS232 to Propeller affair.
    edited 2014-01-23 08:27
    Thank you everyone for your input :)
    I have another question, in reference to http://parallax.com/product/32305
    Why does the kit come with a 5Mhz crystal? Doesn't the chip run at 80Mhz? I know you can run chips at slower speeds, but why would you want something so slow at 5Mhz. Even the Arduino runs at 16Mhz
    Also, does the Propeller have a bootloader? Or does the language convert to 100% ASM and writes direct to the chip?
    Cameron.
    edited 2014-01-23 08:33
    With a 5Mhz crystal, the 16x phase lock loop mode drives the Propeller cogs at 80Mhz.
    Regarding the question of a boot loader, I would say yes But.
    The Propeller has a Spin interpreter internally that loads both Spin code to be interpreted as required and/or PASM assembler binaries in a 32K image. A traditional bootloader doesn't not include an interpreter for a specific tokenized language.
    The Propeller requires a 32K EEPROM to be availabe for the SPIN and PASM to be loaded. The ROM within the Propeller hold the Spin Interpreter, a Log Table, a Character set for video, a Sine Table, and the resident Boot Loader services.
    Cameron,
    Welcome!
    I just loaded the latest SimpleIDE onto my Mac and it compiles Spin/PASM programs just fine. SimpleIDE will also let you use C/C++ with the propeller which may ease your transition from the Arduino.
    The Parallax Learn site also has some great tutorials to help you with SimpleIDE and C (you should breeze through these just noting the difference between Arduino and the Propeller)
    The Propeller Education Kit is great for learning about the Propeller and has a great manual. It is targeted and breadboarding and circuit building. You may also want to check out the Propeller Activity Board or the Propeller Board of Education - they are also great for learning and also the SimpleIDE tutorials address features they have.
