Xbee Kit + Activity Bot
So i'm quickly realizing the project I want to do is going to need significantly more computational muscle than my little propeller will likely give... I'd like to set up a link between MATLAB on my PC and the bot out on the floor so that I can control it remotely while I am developing its control system.
Would the XBee 802.15.4 Starter Kit provide the connection I am looking for?
The activity bot i have is using Rev A, 32910 as its board.
I have no experience of that XBee model, but be aware of that there's a XBee WiFi model available. There are threads about this in this Wireless forum and in the Propeller 1 forum. I've myself got the product.
-Thomas
Ultimately the goal is to be able to write my programs in matlab and command the bot from it, i'm still quite novice on C (don't know a thing about spin, realized the book in that kit is all spin). But I can usually work my way through a problem in matlab.
Data: I want to have the robot send its IO state back to the PC (incl sensor data).
PC will send back to the bot only wheel velocity commands initially, maybe later i can get fancier.
eventually i'd like to send standard def analog greyscale video back, but i figure that is a 2nd xmitter, and only needs to go one way. (long ways off from this)
