PPDB Breadboarding — Parallax Forums
PPDB Breadboarding
edited 2014-01-15 11:09 in Propeller 1
I've attached two dxf files that show the layout for the breadboard area on both versions of the prop development board. I find it useful to do layout on a computer and then build the actual circuit. Saves quite a bit of rearranging during development. One of the first rules of project management to to have a plan!
The .dxf files were created using QCAD Pro on Linux ( Ubuntu ). I don't have AutoCad so I would be interested if others are able to open / view / edit these files.
Sandy
  • cavelambcavelamb Posts: 724
    edited 2014-01-14 15:27
    Imports just fine with DesignCAD.
    Dunno about Autocad.
    I threw that away 30 years ago.
  • w4fejw4fej Posts: 264
    edited 2014-01-14 15:33
    cavelamb wrote: »
    What version of DesignCad do you have?? I have been using DC for years and love it.. It probably has gone through many updates since I got it...
    Mike B.
    edited 2014-01-14 15:53
    Opens fine in:
    AutoDesk DWG TrueView 2012
    MS Visio 2010
    Draftsight x64 2012 (had to change some layer colors because the background is black)
  • edited 2014-01-14 21:48
    Thanks everyone. I was hoping that would be the case.
    Attached is an example drawing and the corresponding pdf showing how it might be populated with wires and components.
    Sandy
    w4fej wrote: »
    Mike B.
    Hi Mike,
    Started with DOS 2D version (mumble) years ago.
    Right now I mostly use version 10 (DC2000) because it best suits my old HPs video drivers.
    But I have V20 installed also so as to do the cool stuff in the later versions.
    Like the real-time 3D rendering :).
