PPDB Breadboarding
Alexander (Sandy) Hapgood
I've attached two dxf files that show the layout for the breadboard area on both versions of the prop development board. I find it useful to do layout on a computer and then build the actual circuit. Saves quite a bit of rearranging during development. One of the first rules of project management to to have a plan!
The .dxf files were created using QCAD Pro on Linux ( Ubuntu ). I don't have AutoCad so I would be interested if others are able to open / view / edit these files.
Sandy
Sandy
Dunno about Autocad.
I threw that away 30 years ago.
What version of DesignCad do you have?? I have been using DC for years and love it.. It probably has gone through many updates since I got it...
Mike B.
AutoDesk DWG TrueView 2012
MS Visio 2010
Draftsight x64 2012 (had to change some layer colors because the background is black)
Attached is an example drawing and the corresponding pdf showing how it might be populated with wires and components.
Sandy
Started with DOS 2D version (mumble) years ago.
Right now I mostly use version 10 (DC2000) because it best suits my old HPs video drivers.
But I have V20 installed also so as to do the cool stuff in the later versions.
Like the real-time 3D rendering
