understanding string manipulations
                    Hello:
In attempting to do some string manipulation, I quickly figured out that I'm not sure of what I'm doing.
I had wanted to concatenate 2 strings into a single variable, and found other posts on the forum showing how to do so with some ByteMove statements. But it's not working for me; obviously I went south somewhere here... I was attempting to simply concatenate src1 with src2 into dest. My first ByteMove statement works, but the second one doesn't do anything. And by putting the addresses out to the serial terminal, I see that when it's all done, both the dest and the src1 variables have the same address? Doesn't seem right to me. I've played with adding/removing the "@" to/from the variables within ByteMove, and it only seems to work with @ in place like it is below.
I'm probably not understanding some fundamental aspect here, and am hoping somebody can clear up my misunderstanding.
thanks!
-marc
thanks!
-marc
CON
  _clkmode  = xtal1 + pll16x
  _xinfreq  = 5_000_000
OBJ
  PST           : "Parallax Serial Terminal"
VAR
  byte dest[10]
  byte src1
  byte src2
PUB Main
  PST.Start(115200)
  PST.Home
  PST.Clear
  Src1 := String("abc")
  Src2 := String("def")
  PST.Str(String("Src1: "))
  PST.Str(src1)
  PST.NewLine
  PST.Str(String("Src2: "))
  PST.Str(src2)
  PST.NewLine
  PST.Hex(src1, 2)
  PST.NewLine
  PST.Hex(src2, 2)
  PST.NewLine
  ByteMove(@dest, @src1, StrSize(src1))
  ByteMove(@dest + StrSize(src1), @src2, StrSize(src2) + 1)
  PST.Str(String("Dest: "))
  PST.Str(dest)
  PST.NewLine
  PST.Hex(dest, 2)
  PST.NewLine
  PST.Hex(src1, 2)
PST.Str(String("Dest: ")) PST.Str([COLOR="#FF0000"]@[/COLOR]dest) PST.NewLine PST.Hex([COLOR="#FF0000"]@[/COLOR]dest, 4) PST.NewLine PST.Hex(src1, 4)a longer time ago I made a oo-sheet explaining stringmanipulation
see attachment
best regards
Stefan
Hi Stephan,
Can't open the file.
My apologies for being a pain about this - but could you post that in a more accessible form?
Text maybe?
No. The main purpose is to show how strings are handled and what pointers are. If you're asking this way I guess you found bugs.
Please report them
best regards
Stefan
