Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Changing status of prefix — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
General Discussion
ajit.nayak87
76
2014-01-09 21:04
edited 2014-01-09 22:04
in
General Discussion
Can someone share how to change prefix after problem being solved
davejames
4,047
2014-01-09 21:10
edited 2014-01-09 21:10
...sure!
Go into advanced edit mode, and change the "prefix" box selection to "solved". This is done on the 1st post in the thread.
Duane Degn
10,588
2014-01-09 22:04
davejames
Just to be clear (since I saw
a later post with <solved> in the title
) the menu which allows the thread to be changed to "solved" is only available from post #1 of the thread.
Sign In
Register
to comment.
Just to be clear (since I saw a later post with <solved> in the title) the menu which allows the thread to be changed to "solved" is only available from post #1 of the thread.
