Propeller Activity Board USB hardware bug?
Peter Jakacki
I noticed on the Propeller Activity Board schematic that the USB circuit has a tristate gate between the FT231 Txd and the Prop's "Rxd" pin. Is that a mistake?.
It looks like it was meant to be from the Prop's "Txd" to the FT231's Rxd so that the Prop doesn't end up phantom powering the FT231 when the USB cable is unplugged.
Maybe there was still some concern over parasitic power. If it's a non-issue, then it's a cost reduction opportunity.
Personally I'd like to see a set of jumpers to choose between the USB IO and the XBee IO (default to USB of course). Alternatively one might replace the USB entirely with another XBee socket to allow choosing which type of interface to use in the event that another interface like a Wifi or Bluetooth module becomes a viable and popular option. There are already USB XBee modules.
— David Carrier
Parallax Inc.
Thanks for explaining that David, I wasn't sure what the real reason was
BTW, I would have just powered the whole darn board when USB was plugged in anyway!
Oh, and I love the 0.00003% - can't underestimate any savings you know.
